Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: Steering Movement Problem  (Read 1240 times)
Offline Offline
Full Member
View Profile
yes but Now my IC is not working its not Loading the Program
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
that Is unfortunate.  Time To replace That Ic.
Logged
Offline Offline
Full Member
View Profile
i want to now what i have done wrong with my arduino that my IC is not working
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Please, everyone, hands on the ouija board.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Me too!
Logged
Offline Offline
Full Member
View Profile
thats a good Question John
But i have done some work to see my IC is working but my IC is doing good on My friends Board
Why its Not working on my Board
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
That question brings us back to Reply #8:
1) Programming error
2) Insufficient RAM
3) Electrical problem such as voltage drop.
Logged
Offline Offline
Full Member
View Profile
i think that Programming is not the Issue the Voltage Drop is the Issue because i have made my own arduino On PCB
what should i check Transistors,Resistor or capacitor
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
I'd try to unstick your shift-key too.
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
the when it on Moving Left it require a Lot of power to move it i think that the motor and the relay is Producing Back emf i have place diode for it and don't know the other concerned issue
Please - post some pics of your setup, your board, your schematic, your code...!
Are you saying it takes more power to move it to the left than to the right? If it is the same motor, that could be a mechanical issue?
Do you have decoupling caps on your Arduino board?
Are the relays identical to each other? How are they wired (once again - pics and a schematic could help us immensely)...?
If the motor is producing a lot of back EMF (or EMF in general - do you have caps across the terminals, and to the case of the motor?) - have you measured the noise using an oscilloscope (mainly between the line from the Arduino and the Arduino's ground) - to see if any back EMF is being injected in some manner that could cause a reset?
Does the system work correctly when "toggled" by hand - that is, when applying 5 volts/ground simulated HIGH/LOW to the transistors that control the relays (just like the Arduino would)? Have you tried using an optocoupler (well, probably two in your case - one for each relay) to completely isolate (both signal and ground) the Arduino from the motor controller?
Logged
Offline Offline
Full Member
View Profile
ok
I want to know why my board is getting reset i have attached the circuitry with it
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
How are those relays supposed to work?
Logged
Offline Offline
Full Member
View Profile
when the my Control will send high to the ULN2003 it will pass it to relay and the following relay will switch to ON
-->if the Right relay will On the motor will run clockwise
-->if the Left motor will get on the Motor will run anti-clockwise
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
I think there is much still missing from your schematic.
Logged
Offline Offline
Full Member
View Profile
no this is it
you can tell me if i am missing
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
