Loading...
Pages: 1 2 [3] 4   Go Down
Author Topic: Steering Movement Problem  (Read 1362 times)
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Look carefully at the relays.
Tell me how they're supposed to work.
Think "electrical circuit".
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Full Member
View Profile
dear if voltage is applied to the diode this will pass the voltage to the relay and motor will be connected and if the voltage gets off pin get disconnected and the inductor in the relay will be dischrged that'll produce back emf so for that i have placed a diode for that
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Most relays I've seen need at least two wires connected to them to energise the coil.
That's why I said "think electrical circuit".
( I hope this thread isn't going to degenerate into another "pulling teeth" sessions)
Logged
Offline Offline
Full Member
View Profile
well i don't understand what you just said but what do you mean by two wires
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
How does your "circuit" allow current through the relay coils?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You may be asking a bit much. smiley-sad
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
you can tell me if i am missing
You should put Ground symbols on all of the parts that are connected to Ground.  Current won't flow into the relay coils unless the other side of the relay coil is grounded.
Logged
Offline Offline
Full Member
View Profile
i have made modified the circuitry
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Why did you ground pin 9? That ain't gonna get you very far...
/pulling teeth, indeed! smiley-grin
Logged
Offline Offline
Full Member
View Profile
i have not grounded the 9th but the 8 is grounded
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
My bad - was reading your schematic wrong... smiley
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Still not seeing very much decoupling or common grounds.
Logged
Offline Offline
Full Member
View Profile
if u can identify it with arrows or circle
Logged
Offline Offline
Full Member
View Profile
dear this is the circuit thats completed and why its not working keen to know it
Logged
Offline Offline
Full Member
View Profile
let me Explain you when it gets restarted/reset
when i say my steering to go Left it goes to left and when it starts to go left it restarts
and when its already left it doesnot restart
if i say it to go left and its turns the steering on left then its also get restarted
tell me please
Logged
Pages: 1 2 [3] 4   Go Up
Print
Jump to:
