Topic: Ethernet UDP hang (Read 16279 times) previous topic - next topic
motote
Hello,
I'm getting mad trying to solve a random hang with arduino mega and ethernet shield...
I tried with latest ethernet library, stop interrupts before any ethernet lib call.
Even tried with a watchdog, but when the arduino hangs the watch dog doesn't reboot. Sometimes is also imposible to upload anything and I need to remove power.
The incoming message rate is 10ms, and the loop never takes longer, it usually takes 7/8 ms
The code is more or less like this....
Any cue?
Thanks!
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <util.h>
#include <avr/wdt.h>
//Other declaration stuff
{ //--- Create an interrupt to update a multiplexed display
  TIMSK2 &= ~(1<<TOIE2);
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
  TCCR2B &= ~(1<<WGM22);
  ASSR &= ~(1<<AS2);
  TIMSK2 &= ~(1<<OCIE2A);
  TCCR2B |= (1<<CS22)  | (1<<CS20);
  TCCR2B &= ~(1<<CS21);
  TCNT2 = 0; //tcnt2;
  TIMSK2 |= (1<<TOIE2);
  Ethernet.begin(mac,ip);
  Udp.begin(localPort);
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
ISR(TIMER2_OVF_vect) {
  iCount++;
  if (iCount == 5) {
    LCD.update();
    iCount = 0;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
  _dataIn in;
  _dataOut out;
  cli();
  int packetSize = Udp.parsePacket();   //The packet sended is 1 byte long, but packetSize is usually 10,11 or 12 ???
  if (packetSize) {
    Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
    if (Udp.remotePort() == remotePort) {   //Sometimes the remotePort is different... I not sure why.
      memcpy((byte *)&in, packetBuffer, sizeof(_dataIn));
      //Assign incoming value to local variable
      //Prepare the output struct
      Udp.beginPacket(remoteIp, remotePort);
      Udp.write((byte *)&out, sizeof(_dataOut));
      Udp.endPacket();
  sei();
  //Do thing with the incoming values
hardcore
Just looking at it ,
The code will not even compile  take a look at the memcpy line.
Why should people waste their time, if you cannot take the time to supply a valid test case?
HC
zoomkat
More or less most people will ignore those that won't post the actual code that is causing a problem.
motote
Well, I was trying to make things as simple as possible, that's why I removed all not ethernet related stuff.
Anyways... digging into the problem I realizes that it gets stuck in a loop inside sendUDP. I need to investigate in depth what's happening, but I supposed it can't send the package and never gets timeout.
int sendUDP(SOCKET s)
  W5100.execCmdSn(s, Sock_SEND);
  /* +2008.01 bj */
  while ( (W5100.readSnIR(s) & SnIR::SEND_OK) != SnIR::SEND_OK )
    if (W5100.readSnIR(s) & SnIR::TIMEOUT)
      /* +2008.01 [bj]: clear interrupt */
      W5100.writeSnIR(s, (SnIR::SEND_OK|SnIR::TIMEOUT));
      return 0;
  /* +2008.01 bj */
  W5100.writeSnIR(s, SnIR::SEND_OK);
  /* Sent ok */
  return 1;
SurferTim
Have you tried applying this fix?
http://code.google.com/p/arduino/issues/detail?id=605
It affects any 16 bit register read from the w5100. It has been around long enough to pick up the nickname "the 605 bug".
motote
Yep, actually I'm using the latest git version of ethernet library that already have the patch.
SurferTim
#6
Feb 09, 2012, 01:28 pm Last Edit: Feb 09, 2012, 01:49 pm by SurferTim Reason: 1
OK. That takes that out of the picture.
Next, this:
     Udp.endPacket();
I presume this is the server end. Is that correct? Your "server" is responding to another device UDP request?
What type device is on the other end, sending the request?
The reason the remote port is different is most of the time is that the client will not normally use the destination port. All my clients use ports other than port 80 on the client end to make http requests.
What is the value assigned to remotePort in your code? Maybe you should be using the port sent by the requesting device to reply to the request.
edit: If your ethernet shield is exposed to the internet, it may not be your device making some of the requests. It could be a port scanner looking for open ports to exploit.
motote
The remote machine is a windows machine that sends to arduino's port 8888, and is always one machine and always the same one, then the arduino reads the package, compose the answer and send it back to windows machine on port 8888.
_dataIn size is 1 byte, and I just check that "int packetSize = Udp.parsePacket();" not always return 1 byte
SurferTim
#8
Feb 09, 2012, 04:36 pm Last Edit: Feb 09, 2012, 04:44 pm by SurferTim Reason: 1
OK. I see. Not sure I can help you with that.
But it might help if you could be more specific about this?
How often is "not always"?
What does it return when it isn't 1 byte? 2? 9?
edit: I just saw the comment in the original code. Between 10 and 12. And never less than 9?
motote
You almost hit!... 10
Here you see only 8888 port incoming packages because I filtered all others before "167" are different traces inside sendUDP
PacketSize: 1   Port: 8888      Power: 1      Write: Ok167END Cycle time: 8
PacketSize: 10  Port: 8888      Cycle time: 3
        Cycle time: 3
PacketSize: 1   Port: 8888      Power: 1      Write: Ok167END Cycle time: 7
PacketSize: 1   Port: 8888      Power: 1      Write: Ok167END Cycle time: 6
        Cycle time: 3
PacketSize: 10  Port: 8888      Cycle time: 4
        Cycle time: 1
        Cycle time: 1
        Cycle time: 3
        Cycle time: 1
        Cycle time: 1
        Cycle time: 3
        Cycle time: 1
        Cycle time: 1
        Cycle time: 3
        Cycle time: 1
        Cycle time: 1
PacketSize: 10  Port: 8888      Cycle time: 5
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
        Cycle time: 3
        Cycle time: 1
        Cycle time: 1
        Cycle time: 2
        Cycle time: 1
        Cycle time: 2
        Cycle time: 2
        Cycle time: 1
        Cycle time: 1
        Cycle time: 1
PacketSize: 1   Port: 8888      Power: 1      Write: Ok167END Cycle time: 9
        Cycle time: 3
        Cycle time: 3
        Cycle time: 1
SurferTim
I'm not sure where that output came from.
Have you tried the example code here?
http://arduino.cc/en/Reference/EthernetUDPAvailable
Does that serial output help?
I don't see a "Serial.begin(9600);" in the setup function tho. ??
motote
#11
Feb 09, 2012, 05:39 pm Last Edit: Feb 09, 2012, 08:58 pm by motote Reason: 1
Arduino 1.0 UDP sample doesn't have the call to available, anyways, the available() call is embedded in parsePacket().
I will try in my next run.
There's a Serial.begin(115200)
Edit: It seems to solve the wrong packet size... now is always 1, except very seldom 0 sizes, like data arrives between parsePacket() and available() calls
        Let's see what happens after a few hours.....
Edit2: Nop... even the wrong packet size appears again.... I think my next step is to  allow only a few retries in the loop of death
          Maybe is some timing issue, the "print" fail rate is much more smaller than the no serial output version
Edit3: SnIR::TIMEOUT is always 8 when the problem happend, rx light in the ethernet shield is always blinking (http://db.tt/bgB1VQLK in the video 1 and 2 are stucked and 3 is running fine)
hardcore
Inside this loop....
can you dump SnIR
HC
motote
HardCore, you mean dumping the result of W5100.readSnIR(s). no?
hardcore
Same thing.
I'm asking for the register to be dumped your asking for a function returning the register to be dumped.
I wanted to see the bottom 2 bits of SnIR  whilst this was going on.
Because UDP does not require an 'ACK' there should be absolutely no reason it does not (SEND_OK), other than the external network cable is already busy/ no destination.
