Topic: Burning Bootloader: Expected signature for ATMEGA328P is 1E 95 0F (Read 17988 times) previous topic - next topic
littlethommy
Hi
I am trying to burn the bootloader on a blank Atmega328p-pu chip with an AVRISP MKii. But when I try to write the bootoader with the arduino IDE it gives the following error:
Quote
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
         Double check chip, or use -F to override this check.
Somtimes it gives the following error:
Quote
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
I tried to read the signature of the chip in avrstudio and it there it says it matches with 1E 95 0F
What could be the solution to this?
Thanks
KirAsh4
Are all your connections correct?  Do you have a crystal in the circuit?  Are your wires making good contact?  Is your reset wires connected properly?  How do you have things connected?  No one can help you unless you give us more details.
littlethommy
I pulled my good arduino chip out of the board and replaced it with a blank chip. And I used the icsp connecter on the arduino uno board to connect the programmer.
westfw
Does it say what the signature IS?  Most likely cause: you have an ATmega328-PU chip instead of an ATmega328P-PU chip.
They're nearly identical, but the 328 has a signature ending in 0x14
If this is your problem, you can probably temporarily change the "uno.build.mcu" in boards.txt from "atmega328p" to just "atmega328" and burn the bootloader.  Then change it back, because the bootloader will happily lie to the Arduino IDE and claim to be a 328p.
littlethommy
No it doesn't say what the signature is. It only gives the errors seen in the OP. I'm sure it is an Atmega328P-PU i checked it. I bought them because they were identical to the chip that came originally on the board.
littlethommy
JoeO
It could be:
Bent pin on the 328
328 Put into the socket backwards
Something else went bad
You wrote that you bought 'them" when you referred to the 328.  Did you try another 328?
littlethommy
I bought two atmega 328P-PU's but both don't work. But when I try to write the bootloader on the chip that came with the arduino it goes without a problem.
mmcp42
I had that problem when I didn't have correct connection to the target chip
how are you connecting what?
there are only 10 types of people
them that understands binary
and them that doesn't
littlethommy
I removed the original arduino chip, placed a blank atmega in the socket. Connected the avrISP mkII with the ICSP connector on the board.
westfw
Can you run avrdude in verbose mode?  Clicking the "burn bootloader" button while having compile/upload (in options vo 1.0)  set to "verbose" should do it.
Usually if you can get as far as an "invalid signature", it means that a fair amount of the chip is actually working, but that's when using ArduinoISP, and the official programmer might behave differently.
littlethommy
#11
Feb 11, 2012, 11:17 am Last Edit: Feb 11, 2012, 12:10 pm by littlethommy Reason: 1
I've put it in verbose mode and this is the output:
Code: [Select]
C:\Users\Thomas\Documents\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\Users\Thomas\Documents\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "C:\Users\Thomas\Documents\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
        Using Port                    : usb
        Using Programmer              : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000B0041068
avrdude: usbdev_open(): using read endpoint 0x82
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P [50] _ [5f] M [4d] K [4b] 2 [32]
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
        AVR Part                      : ATMEGA328P
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : STK500V2
        Description     : Atmel STK500 Version 2.x firmware
        Programmer Model: AVRISP mkII
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [91]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [0c]
        Hardware Version: 1
        Firmware Version Master : 1.12
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] 0 [30]
        Vtarget         : 4.8 V
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [02]
        SCK period      : 0.50 us
avrdude: Sent: . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [00]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [00] . [00]
avrdude: Recv: . [1d] . [00] . [00] . [00] . [00] . [00] . [00]
avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [01] . [00]
avrdude: Recv: . [1d] . [00] . [00] . [00] . [00] . [1f] . [00]
################avrdude: Sent: . [1d] . [04] . [04] . [00] 0 [30] . [00] . [02] . [00]
avrdude: Recv: . [1d] . [00] . [ff] . [ff] . [ff] . [ff] . [00]
################################## | 100% 0.00s
avrdude: Device signature = 0x001fff
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done.  Thank you.
Would it help if I changed the signature in the config file to 0x001fff?
JoeO
littlethommy
from conrad.be one of the biggest online elektronics webshop in the BENELUX
rhood15
Hi guys,
I'd been trying to burn my first bootloaders onto a couple of chips with my 'Uno' and was getting the same message. I was starting the wonder if the chips were dodgy, as I'd got them quite cheap on the net.
After an hour or two of googling, editing the boards.txt file, checking and rechecking the wiring, adding a capacitor etc... I exactly mirrored the breadboard setup on the other half of the breadboard to try my other chip without moving the first chip and it's wiring...I also pushed the chips more firmly into the breadboard and socket on the 'Uno' (they were originally not so tight to allow easy removal). The burn was successful, so I put chip #1 into the place of chip #2 and it burned successfully too.
I'm not sure what exactly made the difference, but the physical connections seem to be quite important.
In the end, it worked as per this instructable with no modifications:
http://www.instructables.com/id/2-Arduino-the-ATMEGA328-As-a-Stand-alone-Easy-Chea/?ALLSTEPS
As the knowledgeable lads above have said, check your connections are solid!
