UK
Offline
Tesla Member
« Reply #15 on: February 04, 2012, 06:03:15 pm » |
Looks like you need pedantic warnings:
I'm surprised that the compiler accepted that code. I'm even more surprised what happens if you put a delay() in: int i; void setup() { Serial.begin(9600);
delay(50); i = millis(); char global[i]; Serial.println(sizeof (global));
int j = millis(); char local[j]; Serial.println(sizeof (local)); } void loop() { }
49 52
Um, is it allowed to do that?
Logged
Offline
God Member
« Reply #16 on: February 04, 2012, 06:08:07 pm » |
I'm suprised he had any RAM left after dimensioning an array to the return from millis().
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #17 on: February 04, 2012, 06:10:20 pm » |
Why are you surprised? Read the code again.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Des Moines, WA - USA
Offline
God Member
« Reply #18 on: February 04, 2012, 06:23:58 pm » |
C++ allows the size of stack based arrays to be dynamically stated (within the limits of stack size), but not resized. It is valid code.
« Last Edit: February 04, 2012, 06:27:52 pm by lloyddean »
Logged
SF Bay Area (USA)
Offline
Faraday Member
Strongly opinionated, but not official!
« Reply #19 on: February 04, 2012, 06:53:09 pm » |
Note, by the way, that you can not use the "sizeof" operator on arrays that have been passed to a function, since arrays are always passed by reference (a pointer), and the size of a pointer is always 2. int myarray[15]; void loop() { operate(myarray); } void operate(int arr[]) { Serial.print(sizeof(arr)); } Will print "2." Yes, there are reasons to support things like dynamically sized arrays, and arrays that contain information about their actual size. But the C language doesn't support either one; it's a "primitive" language.
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #20 on: February 04, 2012, 07:33:16 pm » |
Well, you learn something new every day! I didn't know you could do that.
Logged
UK
Offline
Tesla Member
« Reply #21 on: February 04, 2012, 08:13:08 pm » |
Well, you learn something new every day! I didn't know you could do that.  Nor me, although to be fair my 'C' is a few decades rusty and my C++ coding has all been pretty mundane stuff. How is 'sizeof' worked out, then? I thought this was a compile time expression. Is the compiler creating an honorary class and using rtti, or something?
Logged
Offline
Jr. Member
« Reply #22 on: February 04, 2012, 08:48:32 pm » |
Well, this whole conversation has gone well over my head in terms of what I can personally relate to, but I get that the general answer is that there isn't a simple function I can call that will return the number of indexes in an Array.
I'm glad people are having good discussion.
I'm sure I will have many more questions soon. Going from a very high level language such as PHP to ... whatever it is that Arduino uses (it's C right?) certainly has it's challenges. I'm only just beginning to realize how much processing power and ram a modern day web server actually has. Kind of boggles my mind!
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #23 on: February 04, 2012, 08:59:27 pm » |
Well this is interesting: char array[i]; f0: 2d b7 in r18, 0x3d ; 61 f2: 3e b7 in r19, 0x3e ; 62 f4: 26 1b sub r18, r22 f6: 37 0b sbc r19, r23 f8: 0f b6 in r0, 0x3f ; 63 fa: f8 94 cli fc: 3e bf out 0x3e, r19 ; 62 fe: 0f be out 0x3f, r0 ; 63
I bet you didn't realize that doing this: char array[i]; ... fiddled with the interrupt enable flag.  How is 'sizeof' worked out, then? I thought this was a compile time expression. Is the compiler creating an honorary class and using rtti, or something? Well the mind boggles a bit here too, but it appears that the compiler has saved the size of the array into temporary registers and passed that (in this case) to Serial.println().
Logged
SF Bay Area (USA)
Offline
Faraday Member
« Reply #24 on: February 04, 2012, 09:07:59 pm » |
fiddled with the interrupt enable flag? it has to, since it modifies the 16bit stack pointer one byte at a time: f0: 2d b7 in r18, 0x3d ; read stack pointer low byte f2: 3e b7 in r19, 0x3e ; stack pointer high byte f4: 26 1b sub r18, r22 ; create stack frame by f6: 37 0b sbc r19, r23 ; adjusting SP f8: 0f b6 in r0, 0x3f ; get status register fa: f8 94 cli ;; don't want interrupts while writing SP fc: 3e bf out 0x3e, r19 ; write new stack pointer fe: 0f be out 0x3f, r0 ; restore interrupt status I don't see the other half of the stack pointer being written, though !!??
Logged
Offline
God Member
« Reply #25 on: February 04, 2012, 09:14:59 pm » |
In the case of dynamic arrays, to expand an existing populated array I must make a new array at the larger proportions then copy the old elements into the new, swap ppointers and destroy the old array?
Logged
Offline
Jr. Member
« Reply #26 on: February 04, 2012, 09:16:18 pm » |
Yes, that appears to be the case.
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #27 on: February 04, 2012, 09:28:36 pm » |
I left that line out: f8: 0f b6 in r0, 0x3f ; 63 fa: f8 94 cli fc: 3e bf out 0x3e, r19 ; 62 fe: 0f be out 0x3f, r0 ; 63 100: 2d bf out 0x3d, r18 ; 61 I presume it's done in this order because the processor guarantees to execute one instruction after setting the interrupt flag, so the instruction at 0x100 is executed before an interrupt. Although I can't see exactly where it says that in the datasheet. It says after a SEI it executes the next instruction, that's not quite the same as saying "after enabling interrupts with the SREG register".
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #28 on: February 04, 2012, 09:30:08 pm » |
Bear in mind these are local variables, not global ones. So you can't exactly do anything really useful with them (like, saving them from one function call to the next), and you can't destroy them as such.
Logged
Offline
God Member
« Reply #29 on: February 04, 2012, 09:45:20 pm » |
In the case of: void foo(int newBound) { static char arrElements[]; ..... }
In other languages the static keyword keeps the scope variable arrElements persistent across calls to foo, and of course is only accessible within foo. Is this also apply in C? If so then I could simply return the pointer to arrElement[] to use it globally.
Logged
