Topic: bad coding in setCursor example (Read 1 time) previous topic - next topic
keithb1
Feb 04, 2012, 11:37 am Last Edit: Feb 05, 2012, 04:55 pm by keithb1 Reason: 1
The setCursor.pde example has some bad coding:
   // loop over the columns:
   for (int thisCol = 0; thisCol < numRows; thisCol++) {
     // loop over the rows:
     for (int thisRow = 0; thisRow < numCols; thisRow++) {
       // set the cursor position:
       lcd.setCursor(thisRow,thisCol);
Note that "thisCol < numRows", "thisRow < numCols" are inconsistent and this is corrected in the last line by reversing the variables in the library call. This would be better as follows:
   for (int thisRow = 0; thisRow < numRows; thisRow++) {
     for (int thisCol = 0; thisCol < numCols; thisCol++) {
       lcd.setCursor(thisCol,thisRow);
Here is a unified patch:
--- /usr/share/arduino/libraries/LiquidCrystal/examples/setCursor/setCursor.pde 2011-10-20 09:04:08.000000000 +0100
+++ setCursor_modified.pde 2012-02-04 09:59:23.000000000 +0000
@@ -54,12 +54,12 @@
  // loop from ASCII 'a' to ASCII 'z':
  for (int thisLetter = 'a'; thisLetter <= 'z'; thisLetter++) {
-    // loop over the columns:
-    for (int thisCol = 0; thisCol < numRows; thisCol++) {
-      // loop over the rows:
-      for (int thisRow = 0; thisRow < numCols; thisRow++) {
+    // loop over the rows:
+    for (int thisRow = 0; thisRow < numRows; thisRow++) {
+      // loop over the columns:
+      for (int thisCol = 0; thisCol < numCols; thisCol++) {
-        lcd.setCursor(thisRow,thisCol);
+        lcd.setCursor(thisCol,thisRow);
        // print the letter:
        lcd.print(thisLetter, BYTE);
        delay(200);
Keith
AWOL
Could you maybe edit one of those code boxes, please?
keithb1
In what way? I don't understand what you want me to do?
Keith
AWOL
keithb1
Ah, good point. It's changed now.
Thanks.
Keith
Best thIng is to open an issue on the google code tracker, and include the patch.
