Topic: help in stream function (Read 591 times) previous topic - next topic
ambuj
hi all,
        when i try this function this function gives me compile time error
   "error: 'stream' was not declared in this scope"
every time give me the same error can any one help me
  stream.available();
dxw00d
What are you trying to do? You should be using Serial.available(), although just using it as a statement is a bit pointless.
Stream is the base class for character and binary based streams. It is not called directly, but invoked whenever you use a function that relies on it.
