Topic: how to use a mma7361 accelerometer what is wrong? (Read 5351 times) previous topic - next topic
victorjung
Hi every body! i bought a mma7361 accelerometer like this:
http://thmb.inkfrog.com/thumbn/geiliablestore/mma7361_conew1.jpg=450
I guess it could be use through i2c or analog in, and i want to use it via analog in!
I plugged like this:
A0 to X
A1 to Y
A2 to Z
3.3V to  3V3
GND to GND
and i had this code:
#include <SoftwareSerial.h>
int axe_x=0;
int axe_y=0;
int axe_z=0;
  axe_x=analogRead(A0);
  axe_y=analogRead(A1);
  axe_z=analogRead(A2);
  Serial.print(axe_x);
  Serial.print("\n");
  Serial.print(axe_y);
  Serial.print("\n");
  Serial.print(axe z);
Serial.print("\n");
but in the terminal there is only some strange values, all the same for each axis, and wich don't move when shaking the accelerometer!
Any ideas what i m doing wrong?
johnwasser
SL is the SLEEP signal.  Connect it to 3.3V or the accelerometer will stay in a low-power sleep mode.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
victorjung
thanks fo your help, now i have new questions :)
how can i smooth a little bit the values i get? i guess there is already an RC filter on the pcb.
Thanks for help!!
robtillaart
try this ...
Code: [Select]
long axe_x=0;
long axe_y=0;
long axe_z=0;
  axe_x = (90* axe_x + 10 * analogRead(A0)) / 100;
  axe_y = (90* axe_y + 10 * analogRead(A1)) / 100;
  axe_z = (90* axe_z + 10 * analogRead(A2)) / 100;
  Serial.print("\n");
  Serial.print("\n");
Serial.print("\n");
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
johnwasser
For a little more versatility:
Code: [Select]
const int STABILITY = 10;
long axe_x=0;
long axe_y=0;
long axe_z=0;
  axe_x = ((STABILITY-1)* axe_x + analogRead(A0)) / STABILITY;
  axe_y = ((STABILITY-1)* axe_y + analogRead(A1)) / STABILITY;
  axe_z = ((STABILITY-1)* axe_z + analogRead(A2)) / STABILITY;
  Serial.println(axe_x);
  Serial.println(axe_y);
  Serial.println(axe z);
studioj
Maybe this can help future readers
https://code.google.com/p/mma7361-library/
robtillaart
Thanks for the link!
(There are several optimizations possible in this lib by the way e.g. using bytes for pin numbers reducing the footprint)
Rob Tillaart
Francesco_Noto
Hello everybody,
i have an MMA7361 accelerometer...
How i can obtain the value of linear acceleration and rotational acceleration?
My idea is to see falling detection..
Can you help me please?
thanks
F.N.
JimboZA
What have you tried? Have you used the library mentioned in #5? I see it has some examples....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
