Topic: problema utilizzo shiftin (Read 464 times) previous topic - next topic
stefa24
ciao
per leggere lo stato LOW di 6 sensori voglio utilizzare shiftin, sto provando con un solo sensore ma non riesco a rilevare lo stato LOW, la durata LOW è forse troppo bassa?
Code: [Select]
int latchPinIN = 8;//Pin connected to P/SC of 4021
int dataPinIN = 9;//Pin connected to Q8 of 4021
int clockPinIN = 7;//Pin connected to CLOCK of 4021
//Define variables to hold the data
//for shift register.
//starting with a non-zero numbers can help troubleshoot
byte switchVar1 = 78;  //01001110
int i;  //contatore
   //shiftin define pin modes
  pinMode(latchPinIN, OUTPUT);
  pinMode(clockPinIN, OUTPUT);
  pinMode(dataPinIN, INPUT);
  unsigned long time;
  digitalWrite(latchPinIN,1);  //set it to 1 to collect parallel data, wait
  delayMicroseconds(50);
  digitalWrite(latchPinIN,0); //set it to 0 to transmit data serially
   switchVar1 = shiftIn(dataPinIN, clockPinIN);
Serial.println(switchVar1,BIN);
//------------------------------------------------end main loop
//     shiftIn function
///// just needs the location of the data pin and the clock pin
///// it returns a byte with each bit in the byte corresponding
///// to a pin on the shift register. leftBit 7 = Pin 7 / Bit 0= Pin 0
byte shiftIn(int myDataPin, int myClockPin)
  int i;
  int temp = 0;
  int pinState;
  byte myDataIn = 0;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, INPUT);
  //we will be holding the clock pin high 8 times (0,..,7) at the
  //end of each time through the for loop
  //at the begining of each loop when we set the clock low, it will
  //be doing the necessary low to high drop to cause the shift
  //register's DataPin to change state based on the value
  //of the next bit in its serial information flow.
  //The register transmits the information about the pins from pin 7 to pin 0
  //so that is why our function counts down
  for (i=7; i>=0; i--)
    digitalWrite(myClockPin, 0);
    delayMicroseconds(2);
    temp = digitalRead(myDataPin);
    if (temp) {
      pinState = 1;
      //set the bit to 0 no matter what
      myDataIn = myDataIn | (1 << i);
    else {
      //turn it off -- only necessary for debuging
      //print statement since myDataIn starts as 0
      pinState = 0;
    //Debuging print statements
    //Serial.print(pinState);
    //Serial.print("     ");
    //Serial.println (dataIn, BIN);
    digitalWrite(myClockPin, 1);
  //debuging print statements whitespace
  //Serial.println();
  //Serial.println(myDataIn, BIN);
  return myDataIn;
con questo output
Code: [Select]
11111111
11111111
11111111
per come ho fatto i collegamenti mi aspetto questo
Code: [Select]
11011111
al verificarsi del segnale LOW allegato
grazie
stefano
https://sites.google.com/site/agritronica/
https://sites.google.com/site/t3chconcrete/
https://www.youtube.com/channel/UCnY1DNrSywgadjyqqtbvyew
arduino UNO rev 3
ide 1.6.0
leo72
Ma non è che ti confondi con pulseIn?
shiftIn serve per leggere dei dati seriali e ricostruire un byte, ad esempio quando devi leggere uno shift register parallel-to-serial.
Difatti la shiftIn spedisce tramite il pin di clock 8 impulsi ed "importa" 8 bit dallo stesso pin, ma legge in sequenza.
Tu invece vuoi leggere degli impulsi che possono arrivare a caso?
stefa24
ciao
sto lavorando con pulsein(), ma le soluzioni provate finora le trovo un pò lente, lo sketch è solo provvisorio, la funzione shiftin la sto usando per leggere lo stato dei sensori, forse è un uso improprio ma efficace, in una altra applicazione che stò sviluppando funziona egregiamente, gli impulsi arriveranno si a caso e con millis vorrei riuscire a determinare per quanto tempo un determinato sensore (posizione nel byte) rimane in un determinato stato.
In pratica considero lo shiftin come una macchina fotografica che fotografa lo stato degli ingressi, contando poi il tempo che passa tra un cambio di immagine e l'altro (per quel dato bit) determinare il tempo LOW
grazie
stefano
arduino UNO rev 3
ide 1.6.0
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
