Loading...
Pages: [1]   Go Down
Author Topic: does not fire if quick  (Read 304 times)
Offline Offline
Newbie
View Profile
Hi. I am a newbie in Arduino. I am fighting with this issue for quite some time. I am trying to implement a classic Arduino project: flash triggered by a sensor. I have a laser that shines on a DFRobot light sensor, when laser light is blocked (value becomes more than the threshold), Arduino sends signal that goes through an optoisolator and triggers a Canon flash. (similar to mrichardson23's project from Make magazine) . For now there is no camera. Everything works - I photographed a Coke can falling into an aquarium (without fish) - looks good! But I wanted to photograph a much faster event - a whip overcoming sound barrier. My setup does not work for fast traveling objects, even a finger quickly moved through the beam does not fire the flash. Below is my code. Please help.
P.S. My threshold is just over the light level when the laser shines.
int LASER_PIN = 5;
int FLASH_PIN = 4;
int SENSOR_PIN = 0;
int SENSOR_THRESHOLD = 430;
    pinMode(FLASH_PIN, OUTPUT);
        digitalWrite(FLASH_PIN, LOW);
        pinMode(LASER_PIN, OUTPUT);
        digitalWrite(LASER_PIN, HIGH);
              int sensorVal;
              sensorVal = analogRead(SENSOR_PIN);
      if (sensorVal > SENSOR_THRESHOLD) //If we sense a shadow:
      digitalWrite(FLASH_PIN, HIGH); // fire flash
      delay(10);
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
analogRead() is very slow.  Figure out how to bias your sensor to provide a 3V or high signal so you can use a digitalRead() instead.  digitalRead() is also kind of slow, so at that point you could use direct port manipulation.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Newbie
View Profile
Thanks. I'll try.
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Does this light sensor use a CdS cell? If so you should expect a slow response.
An IR detector (phototransistor) would work much better.
Logged
Offline Offline
Newbie
View Profile
It has Cds Photoresistor as a light sensitive element. I recently got IR barrier kit - I probably could use it! Though I am still uncertain what kind of IR sensor it uses.
Logged
Offline Offline
Newbie
View Profile
I used the phototransistor and it works!!! Thanks a lot! I'll try it on something faster than a piece of wire in my fingers.
Logged
Pages: [1]   Go Up
Print
Jump to:
