Loading...
Pages: [1]   Go Down
Author Topic: Acceleration sensor from the smartphone is used to drive the robot forward backw  (Read 1308 times)
Offline Offline
Newbie
View Profile
Acceleration sensor from the smartphone is used to drive the robot forward backwords left and right
http://youtu.be/1uLr0o4bpm4
1. http://www.amarino-toolkit.net
    1.1 http://code.google.com/p/amarino/downloads/detail?name=Amarino_2_v0_55.apk&can=2&q=
    1.2 http://code.google.com/p/amarino/downloads/detail?name=AmarinoPluginBundle.apk&can=2&q=
Code:
//Acceleration sensor from the smartphone is used to drive the robot forward backwords left and right
//inspired from http://www.arduino.cc/playground/Code/HTCDesire
//arduino + amarino + HTC Wildfire
#include <MeetAndroid.h>
#define IDLE 0
#define RINGING 1
#define OFFHOOK 2
MeetAndroid meetAndroid;
int EN1 = 6;
int EN2 = 5;  //
int IN1 = 7;
int IN2 = 4; //
  void Motor1(int pwm, boolean reverse)
    analogWrite(EN1,pwm); //set pwm control, 0 for stop, and 255 for maximum speed
    if(reverse)
    digitalWrite(IN1,HIGH);
    digitalWrite(IN1,LOW);
  void Motor2(int pwm, boolean reverse)
    analogWrite(EN2,pwm);
    if(reverse)
      digitalWrite(IN2,HIGH);
      digitalWrite(IN2,LOW);
  void Forward(int speed)
      Motor1(speed,true); //You can change the speed, such as Motor(50,true)
      Motor2(speed,true);
  void Backward(int speed)
      Motor1(speed,false); //You can change the speed, such as Motor(50,true)
      Motor2(speed,false);
  void Right(int speed)
      Motor2(speed,true);
  void Left(int speed)
      Motor1(speed,true);
  void Stop()
      Motor1(0,false);
      Motor2(0,false);
    meetAndroid.registerFunction(phoneorient, 'A');
      int input=0;
      int i;
    for(i=5;i<=8;i++)     //For Arduino Motor Shield
    pinMode(i, OUTPUT);    //set pin 4,5,6,7 to output mode
    meetAndroid.receive(); // you need to keep this in your loop() to receive events
  void phoneorient(byte flag, byte numOfValues)
    //Phone Orientation Controller
    int values[]={0,0,0};
    meetAndroid.getIntValues(values);
  int Steer=values[1];   //
  int Delta=values[2];   //
  int Heading=values[3];    //
  if (Steer >=5)
    {   //left
      Motor1(220,true); // M1 forward when accelerometer is set to 0 -10...0 0
      Motor2(220,false); // M2 forward when accelerometer is set to 0 10 0
  else if (Steer <=-5)
  { //right
    Motor1(220,false);
    Motor2(220,true);
   else if (Delta >=5) { //forward
    Motor1(220,true);
    Motor2(220,true);
     else if (Delta <=-5) { //back
    Motor1(220,false);
    Motor2(220,false);
    Motor1(0,false);
    Motor2(0,false);
    Serial.println(values[1]);  //Throttle  , Pitch
    Serial.println(values[2]);  //Steering, Roll
    Serial.println(values[3]);  // Heading, degree
« Last Edit: February 08, 2012, 12:20:40 pm by valim » Logged
UK
Offline Offline
Tesla Member
View Profile
Was there a question?
Logged
Offline Offline
Newbie
View Profile
no question, just for anyone that needs this ...
Logged
Offline Offline
Newbie
View Profile
What parts did you use exactly?
Logged
Offline Offline
Newbie
View Profile
I just need to know how you connected the bluetooth module to the arduino and where to connected.. I'm a total noob when it comes to this but I really want to make this project.
Logged
Pages: [1]   Go Up
Print
Jump to:
