Topic: Confused over ISP Programmer (Read 2099 times) previous topic - next topic
Osgeld
try upping the resistor, 120ohm sounds a bit low, and the image you show has a 1k
often I dont even bother with the resistor, the reset pin very weakly pulls itself up, but that is not good practice as its so weakly pulled up, a bird farting outside of your window could cause it to toggle heh
GregM
The pullup on the breadboard is a 10k.
The 120R is recommended as per this article:
http://arduino.cc/playground/Main/DisablingAutoResetOnSerialConnection
Osgeld
are you using windows or other?
GregM
#18
Feb 09, 2012, 08:44 pm Last Edit: Feb 09, 2012, 08:46 pm by GregM Reason: 1
Windows 7.
I've also tried cutting the Reset-EN track on the Uno - doesnt make any difference. Also tried the latest ArduinoISP code from github. Also managed to turn on verbose mode if this helps:
Binary sketch size: 1026 bytes (of a 30720 byte maximum)
C:\Electronics\arduino-1.0\hardware/tools/avr/bin/avrdude -CC:\Electronics\arduino-1.0\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM3 -b19200 -Uflash:w:C:\Users\Greg\AppData\Local\Temp\build9174164316540479171.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Electronics\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: Recv:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
Coding Badly
Does an LED (with series resistor) on pin 9 display a "heartbeat"?
Osgeld
good that is what I was going to suggest is a verborose output, I think here is the problem
open boards.txt
add
my328.name=My Board
my328.upload.protocol=avrisp
my328.upload.maximum_size=30720
my328.upload.speed=19200
my328.build.mcu=atmega328p
my328.build.f_cpu=16000000L
my328.build.core=arduino
my328.build.variant=standard
be sure to change your clock speed, I cant remember if your target board is 16 or 8 mhz, save and restart the ide, choose that listing under boards and give it a go
GregM
@Osgeld: Wooo hooo!!! That did it - its working!!
avrdude: 1026 bytes of flash verified
Not sure what you put in that board file - but thanks!
Osgeld
