Topic: sensor pause (Read 2012 times) previous topic - next topic
cas2406
Feb 08, 2012, 08:56 pm Last Edit: Feb 08, 2012, 08:58 pm by cas2406 Reason: 1
Hi there everybody
i am trying to make a wall avoiding robot using a HC-SR04 ultrasonic sensor, a dagu channel4, a dagu rover 5 and a servo.
but is isn't going that well.
i want to let the ultrasonic sensor to continuously (or take very fast samples)meassure the distance in front of it while it is driving forward.
and when it get's below a set distance to stop the sensor reading and move the servo to the right and meassure the distance, then move to the left and meassure the distance.
and then decide which way to go.
so far i did manage to make it stop when there is a wall in front of it.
but when i try to move the servo, the servo goes all crazy, because it keeps meassuring  and then it thinks the distance is more then the set distance and so moves the servo back.
this is my code so far
#include "Ultrasonic.h"
#define  TRIG_PIN  6
#define  ECHO_PIN  7
Ultrasonic OurModule(TRIG_PIN, ECHO_PIN);
#define PwmPinMotorA 53
#define PwmPinMotorB 51
#define DirectionPinMotorA 52
#define DirectionPinMotorB 50
int pos = 0;
#include <Servo.h>
Servo myservo;
pinMode(PwmPinMotorA, OUTPUT);
pinMode(PwmPinMotorB, OUTPUT);
pinMode(DirectionPinMotorA, OUTPUT);
pinMode(DirectionPinMotorB, OUTPUT);
myservo.attach(9);
void forward(){
digitalWrite(DirectionPinMotorA, HIGH);
analogWrite(PwmPinMotorA, 150);
digitalWrite(DirectionPinMotorB, LOW);
analogWrite(PwmPinMotorB, 150);
void backward(){
digitalWrite(DirectionPinMotorA, LOW);
digitalWrite(DirectionPinMotorB, HIGH);
void left(){
void right(){
analogWrite(PwmPinMotorA, 255);
analogWrite(PwmPinMotorB, 255);
void pause(){
analogWrite(PwmPinMotorA, 0);
analogWrite(PwmPinMotorB, 0);
void pos1() {
OurModule.Ranging(CM);
void pos2() {
    pos = OurModule.Ranging(CM);
    myservo.write(90);
    if (pos <30) {
    forward();
    else{
    pause();
    myservo.write(10);
robtillaart
you must make a statemachine, here the concept, not complete but you should get the idea
int state = MOVING;
  switch (state)
    case MOVING:
      doMove();
      break;
    case DETERMINE:
      doDetermine();
      break;
   default:
      stop();  // for safety
      break;
doMove()
  distance = Measure();
  if (distance < 30)
    state = DETERMINE;
    stop();
    forward();
doDetermine()
  // rotate servo left
  distanceLeft = Measure();
  // rotate servo right
  distanceRight = Measure();
  if (distanceLeft <= distanceRight)
    right();
    // delay(100); ???
    left();
    // delay(100); ???
  state = MOVING;
YOu can make the doDetermine() more intelligent, not just looking left and right but at every angle and choose the one with the most space. And of course it should move backwards if there is no left or right space.... (homework)
Rob Tillaart
cas2406
thank you very much
i will go work on that, and probably upload it by suaterday
cas2406
I have tried to fit a switch case machine in my code and i came up with this so far.
but it doesn't work yet
the error i am getting is this one:
In function 'void doMove()':
error: void value not ignored as it ought to be In function 'void doDetermine()':
At global scope:
In function 'void loop()':
and an other error i am getting is that it can't find MOVING in: int state = MOVING ;
#define  TRIG_PIN  6
#define  ECHO_PIN  7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
int distanceLeft = 0;
int distanceRight = 0;
myservo.attach(9);
void forward(){
void backward(){
void left(){
delay(300);
void right(){
delay(300);
void pause(){
void Measure() {
void doMove()
  if (distance < 30)
    state = doDetermine;
    stop();
    forward();
void doDetermine()  // optie 2 het bepalen van de afstand links en rechts.
  myservo.write(10);
  delay(400);
  delay(20);
  myservo.write(170);
  delay(400);
    right();
    left();
  state = MOVING;
   switch (state)
    case MOVING: // optie 1 rijden
      doMove();
      break;
    case doDetermine: // optie 2 afstanden bepalen
      doDetermine();
      break;
   default:   // standaard: sta stil
      break;
wildbill
You need to define MOVING and DETERMINE (and use it) e.g.
#define MOVING  1
#define DETERMINE  2
You have tried to use doDetermine instead of DETERMINE as Robtillart had it.
PaulS
void Measure() {
Measure the distance, but don't return the distance. Now, there's a useful function!
cas2406
i noticed too that i forgot the void's before Determine etc
i changed the code again and made this of it
but now getting this error:
error: declaration does not declare anything In function 'void Move()':
At global scope:
and the this line is then highlighted: void Measure() {
#define  TRIG_PIN  6
#define  ECHO_PIN  7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
#define MOVING;
#define Measure;
#define Determine;
#define state;
  myservo.attach(9);
void forward(){
void backward(){
void left(){
  delay(300);
void right(){
  delay(300);
void pause(){
void Measure() {
void Move()
  if (distance < 30)
    state = Determine;
    stop();
    forward();
void Determine()
  myservo.write(10);
  delay(400);
  delay(20);
  myservo.write(170);
  delay(400);
    right();
    left();
  state = MOVING;
  int state = MOVING;
  switch (state)
  case MOVING:
    Move();
    break;
  case Determine:
    Determine();
    break;
  default:
    stop();
    break;
AWOL
Unless you really know what you're doing, don't put semicolons on #defines
cas2406
deleted the semicolens. but still getting the same error.
could my changing of the cases be wrong ?
AWOL
What is "Measure"?
A function, or an empty macro?
cas2406
with measure, it should meassure the distance with an ultrasonic sensor.
when i replace all the Measure(); for just  OurModule.Ranging(CM); (i think this might just be easier)
when i compile i get:
error: expected primary-expression before '=' token At global scope:
with     state = Determine;     highlighted. removing the semicolon doesn't do anything
AWOL
state is a macro, you can't assign a value to it.
Post your code.
PaulS
#define state;
even with the semicolon defines a name, not a variable where you can store a value.
Well, of course you do. Removing the ; did something (useful), just not what you wanted.
Why are you using #define at all?
cas2406
#define  TRIG_PIN  6
#define  ECHO_PIN  7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
#define MOVING
#define Determine
#define state
  myservo.attach(9);
void forward(){
void backward(){
void left(){
  delay(300);
void right(){
  delay(300);
void pause(){
void Move()
  distance =  OurModule.Ranging(CM);
  if (distance < 30)
    state = Determine;
    stop();
    forward();
void Determine()
  myservo.write(10);
  delay(400);
  distanceLeft = OurModule.Ranging(CM);
  delay(20);
  myservo.write(170);
  delay(400);
  distanceRight = OurModule.Ranging(CM);
    right();
    left();
  state = MOVING;
  int state = MOVING;
  switch (state)
  case MOVING:
    Move();
    break;
  case Determine:
    Determine();
    break;
  default:
    stop();
    break;
PaulS
    state = Determine;
You can't assign a value to a name!!!
Make state a variable:
int state = 0;
  myservo.write(10);
  delay(400);
  delay(20);
  myservo.write(170);
  delay(400);
Have you timed how long it actually takes the servo to move?
#define Determine
void Determine()
Do you want Determine to be a name or a function? Don't try to use the same name for two different things.
