Topic: Si7020 humidity sensor library + breakout board (Read 1 time) previous topic - next topic
teoqba
Hi all,
I have written a library for Silicon Labs Si7020 relative humidity and temperature sensor.
It is first library I have created, mainly to learn stuff.
Along with the library I also attach Eagle design files for small PCB to play around with the sensor. The design is tested and it works.
You can find all at:
https://github.com/teoqba/Si7020
I hope you will like it.
rogerClark
I think this needs to go in the Gallery section.  I will ask the moderators to move it
Freelance developer and IT consultant
www.rogerclark.net
robtillaart
#2
Dec 05, 2014, 08:22 am Last Edit: Dec 05, 2014, 08:32 am by robtillaart
@Roger
For me it is OK to have arduino related libraries here, imho the gallery is more for final projects.
@teoqba
looks well done, some remarks
1)
makeMesurment()  => makeMeasurement()
2)
several places
Code: [Select]
uint16_t RH_Code = makeMeasurment(RH_HOLD);
float result = (RH_Code * (125.0/65536)) - 6;  // now compiler can optimze math compile time
return result;
3)
readTemp() and getTemp() are different, but the difference is not well reflected in the name
some suggestions
getPreviousTemperature()  - getLastTemperature() -getRHTemperarute()
the other just more descriptive getTemperature()
4)
getRH() ==> getHumidity()  // more descriptive name
5)
changeResolution(uint8_t i);
you could make an ENUM for the parameter  RES_LOW  RES_MED   RES HIGH  RES_MAX
6)
if the param is out of range you still change the resolution, think you should prevent that
Code: [Select]
bool Si7020::changeResolution(uint8_t resolution)
  if (resolution > RES_LOW) return false;
  return true;
7)
Wire.endTransmission();  return a value <> 0 in case of error. You could use that for robustness.
See the Wire lib for the details. YOu can use a private error flag to hold the last error.
8 )
The timeout of the makeMeasurement() return 0 in case of an timeout.
Does this not interfere with real measurements?  better use the error flag
9)
If the max delay = 22 msec you do not need to count to 100 msec for timeout,
25 or 30 should be enough.
10)
in makeMeasurement you sometimes ask for 3 bytes but you only read the first 2.
is the 3rd byte the CRC?
11)
(you could use less local memory making the footprint a few bytes smaller)
12)
Track version, if not used it doesn't take memory
#define SI7020_LIB_VERSION "0.1.00"
think that's enough feedback for one iteration :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
