Topic: Transistor Driven Relay (Read 884 times) previous topic - next topic
Mitchell Christensen
Hey,
I need to drive a relay from my Arduino, and I have the following design,
Here is the 2N5210 (NPN) Data Sheet http://www.fairchildsemi.com/ds/2N/2N5210.pdf.
According to the data sheet, I should expect the following,
hFE = 250; IC = 10mA, VCE = 5.0V
VCE(sat) = 0.7V; IC = 10mA, IB = 1.0mA
VBE(on) = 0.85V; IC = 1.0mA, VCD = 5.0V
Given all that, and the fact that the relay coil is 208 Ohms, I'm expecting the following:
IB = 2mA
ICE = 20mA
Am I even close?  I plan on building a bunch of these over the weekend, so any advice would be much appreciated.
-Mitch
mmcp42
reverse diode across the relay coil to absorb the spike
there are only 10 types of people
them that understands binary
and them that doesn't
PeterH
You need to add a flyback diode across the relay coil, otherwise the voltage spike when you switch it off will fry the transistor.
I only provide help via the forum - please do not contact me for private consultancy.
Oh, of course.  Got it...thanks.
I'm most concerned bout my expectations around the current through the coil/transistor.  I need 13mA minimum to activate the coil.  I should be fine with 20mA, but I need to make sure I'm at least in the ballpark.
-Mitch
mmcp42
the other question is what ddoes the relay say it needs?
Here is my updated schematic (adding the flyback diode).
Here is the data sheet for my relay http://www.pickercomponents.com/Data_Sheets/PC458_Data_Sheet.pdf.
The relay data sheet says 5V and 208 Ohms.  It doesn't say anything about current requirements so I called them and the guy told me it needs 13mA to operate.
Thanks so much for the help.
-Mitch
mmcp42
PeterH
By my reckoning, 5V through 208 Ohms results in about 25mA not 13mA. Perhaps that reply meant that the relay can be operated at a lower voltage than the nominal 5V. If it really only needs around 15 - 25mA, you could conceivably drive it directly from the Arduino as long as you have the flyback diode.
My original design drove and optocoupler directly from pin 4 of an Atmega328P (Arduino UNO).  For some reason I could only get 13mA out of the Atmega chip (see http://arduino.cc/forum/index.php/topic,90600.0.html) when the pin was HIGH.  Since the opto I was using had a CTR of 50%, this wasn't nearly enough to operate the relay.  Try as I might, I just couldn't figure out the low-output current (i.e. 13mA on pin 4) problem so I decided to use a transistor approach and eliminate the opto completely based on comments from members of this forum.  With a transistor I only need a couple of mA out of pin 4 to drive the coil at 20mA.
This does feel like putting a bandaid over the real problem, but I am otherwise stumped.
-Mitch
PS Keep in my that I'm no longer using an UNO.  I have migrated to my own board design based on an Atmega328.
PeterH
OK, that does make sense. I don't know what the impedance characteristics of the Arduino output pins are, but you can't assume they can supply max voltage and max current at the same time. If they won't supply enough power to operate the relay, that isn't an option. In any case driving the relay via a transistor is the correct solution. It is more or less safe to assume that the chip won't drive any mechanical devices directly, but the current you were quoting seemed so low that I just had to ask the question.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
