Author Topic: CP2102 and breadboard arduino  (Read 769 times)
I recently bought an USB to Serial adapter so i can send my sketches to atmega328, and has DTR pin available... so i dont need to manually reset the atmega chip
this is the pin layout
what i would like to know is:
if i have a breadboard arduino that is receiving power via external source that goes through the 7085 voltage regulator ... like this:
in order to use the adapter to send sketches to atmega328 do i still have to connect the +5v of the adapter to atmega's VCC ?! Or that would be only if i wanted to power the arduino via USB ?
Thanks
Boston area, metrowest
Connect CP2102 Vcc in place of 7805 output if you want to power the arduino via USB.
Make sure to connect ground up no matter what.
Thank you very much smiley
Actually i have one more question...
how could i implement a switch (manually or automatic ) so i could chose whether to use power from usb or external battery?
« Last Edit: February 10, 2012, 02:01:25 pm by Carlcox89 » Logged
Get a singlepole, double throw switch.
Connec the 2 power sources to the NC and NO contacts, and the Common to the 5V rail.
