Author Topic: *resolved* Serial Commands work from Serial Monitor but not from Processing.  (Read 566 times)
Hi guys, Im working on a project that takes OSC commands from my phone, parses them, then sends them to my arduino via 2 Xbees.
Im pretty sure I have everything set up right thus far but there seems to be some problem with the way my Processing sketch sends the serial data to the arduino.
The arduino sketch takes 6 characters, first 3 identify the command, second three are the value.
If I open up Arduinos serial monitor and type the command
led255
the led value is properly written. It works.
Using Putty I have to go to 'Terminal' settings and check the option 'Force On' for Local line ending. Then it works as well.
However when my Processing sketch sends the data its not being read. I feel like it has something to do with line endings or something.
The processing sketch first prints the values for debug before writing to terminal so Im pretty sure theyre right..
Here is the Processing sketch:
import oscP5.*;        //  Load OSC P5 library
import netP5.*;        //  Load net P5 library
import processing.serial.*;    //  Load serial library
Serial arduinoPort;        //  Set arduinoPort as serial connection
OscP5 oscP5;            //  Set oscP5 as OSC connection
boolean sliderNeedsRedraw = true;
boolean square4NeedsRedraw = true;
int [] sliderStrip = new int [5];
float [] fader = new float [6];
int redbutton = 0;
int red2button = 0;//  redbutton lets us know if the button is on or off
int greenbutton = 0;
int green2button = 0;
int [] button = new int [8];    //  Array allows us to add more toggle buttons in TouchOSC
  size(325,500);        // Processing screen size
  noStroke();            //  We don’t want an outline or Stroke on our graphics
    oscP5 = new OscP5(this,8000);  // Start oscP5, listening for incoming messages at port 8000
   arduinoPort = new Serial(this, Serial.list()[0], 9600);    // Set arduino to 9600 baud
void oscEvent(OscMessage theOscMessage) {   //  This runs whenever there is a new OSC message
    String addr = theOscMessage.addrPattern();  //  Creates a string out of the OSC message
    if(addr.indexOf("/1/toggle") !=-1){   // Filters out any toggle buttons
      int i = int((addr.charAt(9) )) - 0x30;   // returns the ASCII number so convert into a real number by subtracting 0x30
      button[i]  = int(theOscMessage.get(0).floatValue());     //  Puts button value into button[i]
    // Button values can be read by using button[0], button[1], button[2], etc.
  if(addr.indexOf("/1/fader") !=-1){ // one of the faders
       String list[] = split(addr,'/');
     int i = int(list[2].charAt(5) - 0x30);
     fader[i]  = theOscMessage.get(0).floatValue();
     int j = int(fader[i]*255);
     int fadeval = j; // map(j,0,100,0,255);
  String sendme = "led" +j;
   println(sendme);  // uncomment to see x values
    arduinoPort.write(sendme +" ");
void draw() {
 background(50);        // Sets the background to a dark grey, can be 0-255
   if(button[1] == 0){        //  If button button 1 if off do....
    arduinoPort.write("r");    // Sends the character “r” to Arduino
    redbutton = 0;        // Sets redbutton color to 0, can be 0-255
 if(button[1] == 1){        // If button button 1 is ON do...
  arduinoPort.write("R");    // Send the character “R” to Arduino
  redbutton = 255;        // Sets redbutton color to 255, can be 0-255
   if(button[2] == 0){        //  If button button 1 if off do....
    arduinoPort.write("w");    // Sends the character “r” to Arduino
    red2button = 0;        // Sets redbutton color to 0, can be 0-255
 if(button[2] == 1){        // If button button 1 is ON do...
  arduinoPort.write("s");    // Send the character “R” to Arduino
  red2button = 255;        // Sets redbutton color to 255, can be 0-255
   if(button[3] == 0){        //  If button button 1 if off do....
    greenbutton = 0;        // Sets redbutton color to 0, can be 0-255
 if(button[3] == 1){        // If button button 1 is ON do...
  greenbutton = 255;        // Sets redbutton color to 255, can be 0-255
   if(button[4] == 0){        //  If button button 1 if off do....
    green2button = 0;        // Sets redbutton color to 0, can be 0-255
 if(button[4] == 1){        // If button button 1 is ON do...
  green2button = 255;        // Sets redbutton color to 255, can be 0-255
fill(0,redbutton,0);            // Fill rectangle with redbutton amount
   rect(25, 450, 50, 50);    // Created an ellipse at 50 pixels from the left...
                // 50 pixels from the top and a width of 50 and height of 50 pixels
fill(0,red2button,0);
   rect(100, 450, 50, 50);
fill(0,greenbutton,0);
   rect(175, 450, 50, 50);
fill(0,green2button,0);
   rect(250, 450, 50, 50);
And the Arduino sketch:
PLEASE IGNORE COMMENTS
String readString, val1, val2;
const int led = 13;
  Serial.println("servo-test-21"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(10);
    if (Serial.available() >0) {
char c = Serial.read();  //gets one byte from serial buffer
readString += c; //makes the string readString
  if (readString.length() >0) {
Serial.println(readString); //see what was received
// expect a string like 07002100 containing the two servo positions
        val1 = readString.substring(0, 3); //get the first four characters
val2 = readString.substring(3, 6); //get the next four characters
Serial.println(val1);  //print ot serial monitor to see results
Serial.println(val2);
int n1; //declare as number
int n2;
char carray1[6]; //magic needed to convert string to a number
val1.toCharArray(carray1, sizeof(carray1));
char carray2[6];
val2.toCharArray(carray2, sizeof(carray2));
n2 = atoi(carray2);
if(val1 == "led") {
  analogWrite(led,'val2');
    readString="";
« Last Edit: February 10, 2012, 07:50:08 pm by paulakg4 » Logged
France
if(val1 == "led") {
Seems to be a bad way of coding, because analogWrite take as 2nd argument an unsigned char value (0-255)
try with :
if(val1 == "led") {
  analogWrite(led,n2);
you also don't use the value of val1 as you did with val2, may be you want to use : atoi for val1 .
I had tried different combinations of the various variable states and it seems that was the only way I could get it to work through the terminal. But I will go back and try again so I can report what happens.
Thanks for the reply.
Oh sorry, I must have posted the wrong version of my code. Originally I was using n2 as the value. That is what was working in the serial monitor but not from Processing.
Ok so this is wierd
I got it working... I thought by adding the port.write(10)
while messing with it I had noticed that when I shut the program down, terminating the connection the light would sometimes light up.. like it was processing the command when the serial connection ended.
So I did some test cases with different buttons sending different commands and finally success when sending 10.
I started messing with it and it seems to be working now even without the 10...
However im noticing that when I use the slider which sends 0-255 as I slide up and down the values are being recieved by the arduino because the xbee rx is flashing.. But it doesnt register them
However if I tap different positions on the slider it does register on the led.
Any thoughts? Maybe I need to adjust the delay in the arduino sketch?
Seattle, WA USA
Seattle, WA USA
It would be nice to see the new code...
You misspelled delete.
Ok I got it working pretty smoothly now. I played around with the delay in the Arduino sketch and put one in the Processing sketch as well.
You can test this out using the TouchOSChttp://hexler.net/software/touchosc app which is currently free (but limimted) for Android and a few bucks for IOS. Probably worth the money considering you can design your own controls etc (currently IOS only)..
Heres my working Arduino Sketch
const int led = 13;
  Serial.begin(57600);
  Serial.println("Lets Do Somethin");
   delay(1);
// Serial.println(readString); //see what was received
// Serial.println(val1);
// Serial.println(val2);
int n2;
// char carray1[6]; //magic needed to convert string to a number
// val1.toCharArray(carray1, sizeof(carray1));
char carray2[6];
n2 = atoi(carray2);
if(val1 == "led") {
  analogWrite(led, n2);
if(val1 == "tst") {
analogWrite(led, 125);
    readString="";
And the working Processing sketch
int redbutton = 0;
String command = "";
  size(325,500);
  noStroke();
   arduinoPort = new Serial(this, Serial.list()[0], 57600);
    command = "led" +j +"  " +0x0A;
    arduinoPort.write(command);
//    arduinoPort.write(0x0A);
//    addr = "";
    delay(5);
void draw() {
When you run the processing sketch it only shows 4 buttons not the slider which is the only value being looked for by the Arduino sketch. It works though. In the TouchOSC app i was using the 'Simple' template, tab 1.
« Last Edit: February 10, 2012, 07:11:07 pm by paulakg4 » Logged
PaulS if you are able to get this working smoothly without using delay please do let me know!
Also I did change the serial speed in the last version I posted but it was working at lower speeds also.
Seattle, WA USA
Seattle, WA USA
Piece of cake. You need to make two changes. In the Processing app, change this:
to:
    command = "<led" +j +" >";
Then, on the Arduino, run some code like this:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
       break;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Where it says "Process the packet", put your code to make use of the "ledN" string.
Notice that there is no need to wait for data to slowly trickle in, since there is not attempt to use the data until a specific character (">") arrives. Many iterations of loop() will have occurred by then. Hundreds, thousands, millions, even.
Awesome thanks! I have seen others that seemed wrap their commands in <>  but was unsure of how to implement it. That helps alot.
By the way.. Once I merged the working serial controls into my actual project I found that I was able to leave off the delay in processing and keep just the 1ms delay in the Arduino and everything worked ok.
Im pretty sure it was because I moved all of this:
if(val1 == "led") {
if(val1 == "tst") {
    readString="";
into a seperate function, so the readString is only getting flushed after the comparisons are made.
