First of all Thank you all for your help !
I am trying to create a text messenger ! I will pressent the code in a sec ! Now everything works just fine ( if i press the same btn agen it changes characters in the same cursor point, if i press another one the cursor moves 1 point to the right and does the same thing, when it reaches the end of a row to the lcd screen goes to the next) everything is perfect. BUT ..... i want to have a function that counts the time between btn press when i press the same bt, so if it is less than a sec to continue changing the characters but if it more than a sec to move the cursor 1 point to the right and start the same all over agen.
Here is the code so far :
#include <Keypad.h>
#include <ctype.h>
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
// Define the keymaps. The blank spot (lower left) is the space character.
char alphaKeys[ROWS][COLS] = {
{ 'a','d','g', },
{ 'j','m','p', },
{ 's','v','y', },
char numberKeys[ROWS][COLS] = {
{ '1','2','3', },
{ '4','5','6', },
{ '7','8','9', },
{ ' ','0','#', }
boolean alpha = false; // Start with the numeric keypad.
char* keypadMap = (alpha == true) ? makeKeymap(alphaKeys) : makeKeymap(numberKeys);
byte rowPins[ROWS] = {48, 49, 50, 51}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {40, 41, 43, 42}; //connect to the column pinouts of the keypad
//create a new Keypad
Keypad keypad = Keypad(keypadMap, rowPins, colPins, sizeof(rowPins), sizeof(colPins));
unsigned long startTime;
const byte ledPin = 13;
int i = 0;
int j = 0;
int flag = 0;
long LastDebounceTime = 0;
long FirstDebounceTime = 0;
void setup(){
lcd.begin(16, 2);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW); // Turns the LED on.
keypad.addEventListener(keypadEvent); // Add an event listener.
keypad.setHoldTime(500);
void loop(){
FirstDebounceTime = millis();
char key = keypad.getKey();
if (alpha && millis()-startTime>100) { // Flash the LED if we are using the letter keymap.
digitalWrite(ledPin,!digitalRead(ledPin));
startTime = millis();
char waitForKey();
// Take care of some special events.
void keypadEvent(KeypadEvent key) {
static char virtKey = NO_KEY; // Stores the last virtual key press. (Alpha keys only)
static char physKey = NO_KEY; // Stores the last physical key press. (Alpha keys only)
static char buildStr[12];
static byte buildCount;
static byte pressCount;
switch (keypad.getState())
case PRESSED:
if (isalpha(key)) { // This is a letter key so we're using the letter keymap.
if (physKey != key) { // New key so start with the first of 3 characters.
pressCount = 0;
virtKey = key;
physKey = key;
else { // Pressed the same key again...
LastDebounceTime = millis() - startTime;
if ((LastDebounceTime - startTime)>1000){
virtKey++; // so select the next character on that key.
pressCount++; // Tracks how many times we press the same key.
i--;
if (pressCount > 2) { // Last character reached so cycle back to start.
pressCount = 0;
virtKey = key;
if (i == 16 & flag == 0 & j == 0){
i = 0;
j = 1;
flag = 1;
lcd.setCursor(i,j);
Serial.print(i); // Used for testing.
Serial.print(j); // Used for testing.
lcd.print(virtKey);
if (i == 15 & j == 1){
i = 0;
j = 0;
flag = 0;
else {
i++;
if (isdigit(key) || key == ' ' || key == '.') lcd.print(key);
if (key == '#') Serial.println();
break;
case HOLD:
if (key == '#') { // Toggle between keymaps.
if (alpha == true) { // We are currently using a keymap with letters
keypad.begin(*numberKeys); // and want to change to numbers.
alpha = false;
else { // Or, we are currently using a keymap with numbers
keypad.begin(*alphaKeys); // and want to change to letters.
alpha = true;
else { // Some key other than '#' was pressed.
buildStr[buildCount++] = (isalpha(key)) ? virtKey : key;
buildStr[buildCount] = '\0';
Serial.println();
Serial.println(buildStr);
break;
case RELEASED:
if (buildCount >= sizeof(buildStr)) buildCount = 0; // Our string is full. Start fresh.
break;
} // end switch-case
} // end keypad events
it doesnt work
any help ?
Moderator edit:
[code] [/code] tags added.
