Topic: ArduinoCommander - android application to manage arduino board (Read 62056 times) previous topic - next topic
4ntoine
#30
Nov 14, 2012, 09:37 pm Last Edit: Nov 18, 2012, 06:11 am by 4ntoine Reason: 1
Also i'd like to announce Arduino Uno r3 support in ArduinoCommander 3.2 - you asked for it :)
PS. Please review your app rating  on Google Play (https://play.google.com/store/apps/details?id=name.antonsmirnov.android.arduinocommander) if you were not satisfied with no Uno r3 support, now it's done!
straddlethemoon
I've installed Google Play and installed the app through it. However, still no luck. Are there any log files that I could see to find out what's going wrong on my device?
4ntoine
Usually, wrong baud rate is the reason. Make sure you've set the same bad rate in app settings as you use in arduino sketch. Write me on email if it does not help.
4ntoine
Hi, all.
I'm happy to announce that starting v3.4 ArduinoCommander supports Arduino Mega board.
I was unable to test it carefully as i don't have Mega board so please report me if you have any problems.
4ntoine
Hello again!
Starting ArduinoCommander 3.6 you can generate PWM output using JavaScript script:
http://www.youtube.com/watch?v=fIfaQJhMWdY
Now you can use all JavaScript power in order to get PWM output you wish, for example:
Code: [Select]
function generate() {
  return 127 + 127 * Math.sin(
    new Date().getTime() / 5000 * 2 * Math.PI);
Find more information on feature page:
http://anettosoftware.co.uk/ac-pwm.php
How do you think, is it cool?  :)
4ntoine
Okay, it seems that this topic looks like ArduinoCommander blog  :)
So, please welcome to ArduinoCommander blog:
http://arduinocommander.blogspot.com
Starting this moment you can find news and features descriptions there.
Thank you.
PS. You can also vote for new features there.
BrianMoreau
I am trying to connect using USB OTG cable converter on Samsung Galaxy S3.
My UNO is discovered in USB devices as /dev/bus/usb/002/003
I also have the Standard Firmata sketch installed
I tried every baud rate but it won't connect.
Any ideas anyone?
carl47
If have an android phone spare so I thought I might use it for my weather station.
http://arduino.cc/forum/index.php/topic,8874.0.html
Much better than old 7 segment displays.
ArduinoCommander is a great application, I went through all the information and was really
impressed with the displays available.
Unfortunately my phone uses version 2.1 and ArduinoCommander sets version 2.2  as the  minimun.
So its not available on the  google Market for me and anyone else with 2.1 or lower.
I sent them an email to ask if it was possible to change to 2.1
It maybe there are some API's they need from 2.2 and  its not possible.
Anyone else with the same problem?
Raufe
I am Brazilian and not write english very well, but does anyone know how I can communicate to the arduino uno with a tablet Sansung through arduinocommander (android)?
I can only transmit data from arduino to the tablet, but can not issue commands arduinocommander to the plate.
pedroply
Quote
Any ideas anyone?
I have the same problem, I connect it to my tablet and my arduino turns on but it wont show up on the USB devices tab.
How can I fix that?
4ntoine
Quote
Any ideas anyone?
How can I fix that?
Hi, it's difficult to say actually. The most popular (and obvious reason) is that people just forget to upload StandardFirmata sketch or set the same baud rate in app settings that is set in sketch. Try it.
4ntoine
Please welcome another app from the ArduinoCommander author - ArduinoDroid.
It's Arduino IDE for Android. Read about it in blog:
http://arduinodroid.blogspot.com
JethroNull
Hey guys, great program, quick question though.  I am planning on using a phone that is not a USB host to run the program to control the arduino. Does it work to buy a USB host shield for the arduino and connect it that way?
straddlethemoon
I'd like to share a tip that may help people having problems making the app work with their tablets. The short story is that having a USB OTG port is not enough by itself, certain configuration files should be in place as explained here:
http://tabletrepublic.com/forum/novo-7-paladin/usb-host-ip-not-supported-1136-2.html
You can create them manually, but the easier solution is to use this great app https://play.google.com/store/apps/details?id=eu.chainfire.usbhostdiagnostics&hl=en&rdid=eu.chainfire.usbhostdiagnostics. After doing this step the ArduinoCommander app now works fine with me :)
Eng_Servento
hey straddlethemoon ,
You can install the app on any android tab without using Google play store.
You have to download the app first from any tab with Google play store and you need APK extractor application
then after the program is installed you can take the .apk file to your tab, install the application and enjoy ;)
AbdulRahman.
