Author Topic: Digital input frecuency??  (Read 966 times)
Lanus
Hi, my name is Nahuel and I want to make a proyect. I have digital pulses of 50microsec of duration that came from a detector. It's not regular pulses, the only thing that I know is that the signal will be in high for 50micosec but could be 100 pulses in 1s or 3 pulses in 1s. I wan't to make a counter that say's the number of pulses in one second. I don't know how fast is the digital read, how many samples it takes?
Thanks and sorry for my English
Online Online
About 4 to 5 us per call to digitalRead I think.  If you need faster then direct port manipulation is available...
Boston area, metrowest
Take a look at the pulseIn() function also, may do what you need already.
Lanus
YEEEEAHHHH, Thank's CrossRoads   smiley
Left Coast, CA (USA)
Measurement changes behavior
Not sure that will work. He already knows the width (50usec) of the pulses, he wants to know how many pulses occur in a fixed timed sampling period.
Lefty
So combine it with other stuff, maybe like this:
if ( digitalRead (startPin) == 0 ){
startTime = micros();
timeRunning = 1;
if (timeRunning == 1 & (micros() < (startTime + duration) ){
if ( pulseIn(pin, HIGH)){
pulsecount = pulsecount +1;
if (timeRunning == 1 & (micros() > (startTime + duration) ){
timeRunning = 0;
serial.print ("number of pulses ");
serial.print ln (pulsecount);
serial.print ("frequency = ");
float frequency = duration/pulsecount;
serial.println (frequency);
pulsecount = 0;
It is assumed that the time measured is small enough that the capacitance, COFFSET, provides a
valid voltage to the A/D Converter.
