Topic: U8glib: Graphics Lib for LCDs and OLEDs (Read 215357 times) previous topic - next topic
olikraus
to my understanding your pic seems to be correct (according page 20 of the st7687 datasheet).
I will create also a 8bit interface,
Oliver
rotceh_dnih
:) thanks man i replyed to your email address
rdeweerd
Thanx for the great lib! it works great with my DFRobot ST7920 128X64 display.
I've got one question. I use software SPI on pins 9 and 8, but it looks like that it interferes with my hardware SPI which I want to use to communicate with a DS3234 RTC.
olikraus
Good to know, that the DFRobot display is fine with the lib. Thanks for the feedback.
Regarding the RTC: What is the problem: Display does not work, RTC does not work, both do not work?
Maybe you can post the setup code for your display and your RTC: What are the involved pin numbers for both devices?
Oliver
bperrybap
Can't both use the hardware spi if you use separate pins for the slave selects?
rdeweerd
I must have been verry sleepy yesterday evening because it works now!
But for the others how to connect the DFRobot to the ARduino:
This is my innitialization string:
U8GLIB_ST7920_128X64 u8g(9, 8, 3, U8G_PIN_NONE); // SPI Com: SCK = en = 9, MOSI = rw = 8, CS = di = 3
And this is how I connected it:
Arduino pin = function = DFRobot pin
Pin 9 = SCK = e
Pin 8 = MOSI = rw
Pin 3 = CS = rs
olikraus
Thanks for the information.
Oliver
olikraus
Release v1.02 is available vor download.
* Support for LC7981 controller
* drawCircle, drawDisc
* Ported "little rook chess", a full playable chess engine with graphical user interface
Oliver
NeOCzx
hi and good day..
thx for the wonderful library, works great on my DS-LCD-TG12864E (ST7920 controller) in spi mode. (R/W = MOSI, E= CLK , PSB =LOW, RS=HIGH)
speed is quite ok in spi, gotta try the parallel mode soon. the liquid crystal itself may be limiter.
Hmm..is possible can u make point to point drawline (x1,y1,x2,y2) available? :D
thx again :)
olikraus
Hi
I will add a drawLine procedure with the next release.
Oliver
NeOCzx
Thx for the feedback, looking forward for it :)
in progress in porting the GLCD lib into u8glib now. :3
it is any procedure is equivalence to GLCD.ClearScreen for u8glib?
now using drawBox procedures for clearing screen :P
olikraus
Hi NeOCzx
There are some imporant differences between GLCD v3 and U8glib. While porting is for sure possible, there are some restrictions on U8glib, which are not present for GLCD lib. GLCD and U8glib have two completly different programming concepts. It might require much more than just replacing the drawing primitives.
I suggest reading the article here, before porting:
http://code.google.com/p/u8glib/wiki/tpictureloop
Also, Bill's library is highly optimized and much faster than U8glib. On the other hand, U8glib should be more flexible regarding the graphics hardware.
One result of the different concepts is that there is no clear screen available in U8glib. The screen is cleared as soon as you enter the "picture loop".
Oliver
NeOCzx
thx for the claraficatiion  & tips olikraus :D
if it doesnt work out well maybe i will as well try to use 2 LCD display with different library on a same arduino board. it is possible to be done or someone here had done it before?
just curious :)
olikraus
It should be possible to use more than one display, but i never tried.
Oliver
olikraus
Hi
Release v1.03 is available for download. It includes the requested drawLine procedure.
http://code.google.com/p/u8glib/downloads/list
Oliver
