Loading...
Pages: 1 2 3 [4] 5 6 ... 9   Go Down
Author Topic: U8glib: Graphics Lib for LCDs and OLEDs  (Read 14494 times)
Offline Offline
Newbie
View Profile
I'm using 1.04. When I said I made it work in 1.0-rc2, I was using 1.23.
You can replicate this error by just selecting the arduino leonardo board in the 1.0 IDE (uncomment its lines from /arduino-1.0/hardware/arduino/boards.txt if you haven't done it already) and try to compile any u8glib sketch (I haven't tried compiling it with other constructors than st7920 over SPI)
Code:
/arduino-1.0/libraries/U8glib/utility/u8g_com_arduino_port_d_wr.c: In function ‘u8g_com_arduino_port_d_wr_fn’:
/arduino-1.0/libraries/U8glib/utility/u8g_com_arduino_port_d_wr.c:80:7: error: ‘UCSR0B’ undeclared (first use in this function)
/arduino-1.0/libraries/U8glib/utility/u8g_com_arduino_port_d_wr.c:80:7: note: each undeclared identifier is reported only once for each function it appears in
Logged
Germany
Offline Offline
God Member
If you believe something is right, you won't see what's wrong (David Straker).
View Profile
Ok, thanks. I will fix this in the next release.
As a workaround, you can remove or comment out line 80:
Code:
// UCSR0B = 0;
Oliver
Logged
Germany
Offline Offline
God Member
View Profile
Hi
U8glib v1.05 is now available.
It includes some new icon fonts:
There is a new hardware state backup and restore procedure to solve conflicts
where pins are shared with other devices.
http://code.google.com/p/u8glib/wiki/userreference#setHardwareBackup
U8glib has also been tested with Arduino 1.0.1 IDE.
Additionally I have some experimental code for SSD1306 (Adafruit 128x64 OLED)
and SSD1322 based OLEDs inside the release. This code has not yet been confirmed
because i do not have access to these displays. Any confirmation or bug-reports on
these display types would be great.
Oliver
Logged
Germany
Offline Offline
God Member
View Profile
I had to release v1.06 because of the broken u8g.h file. This will fix the problem with U8G_PROGMEM.
Additional there is now support for SSD1306 (thanks to Yann) and SBN1661 (thanks to Alex).
Project page: http://code.google.com/p/u8glib/
Oliver
« Last Edit: June 15, 2012, 02:19:46 pm by olikraus » Logged
Offline Offline
Newbie
View Profile
I'm using the library for the DFRobot ST7920 128 X 64 LCD and it works without a problem, both in serial as in parallel mode. But the weird thing is, is that the parallel mode is a bit slower. In SW serial I got a refresh rate of 6 to 7 frames per sec and in 8bit it goes down to 4 to 5.
Is this normal behavior or am I doing something wrong?
Logged
Germany
Offline Offline
God Member
View Profile
Thanks for the hint. I will investigate this.
Oliver
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm trying to get NHD-C12864A1Z-FSB-FBW-HTT working with the u8glib, but I'm getting nothing the screen. It works fine with the Adafruit library. I've checked the pin mapping several times and I have connected to the Arduino correctly. I've unsuccessfully tried loading it as the following ST7565 devices: U8GLIB_DOGM128, U8GLIB_LM6059, U8GLIB_LM6063, and U8GLIB_DOGM132. Is there something I'm missing?
New Haven Display
http://www.newhavendisplay.com/nhdc12864a1zfsbfbwhtt-p-3895.html
Digikey link
http://www.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&keywords=NHD-C12864A1Z-FSB-FBW-HTT-ND%20&x=0&y=0&cur=USD
Manual
http://www.newhavendisplay.com/specs/NHD-C12864A1Z-FSB-FBW-HTT.pdf
Logged
Germany
Offline Offline
God Member
View Profile
Hi
So, the NHD display works with Adafruit Lib https://github.com/adafruit/ST7565-LCD/tree/master/ST7565 but not with U8glib, correct?
What is the constructor line (pin definition) for the Adafruit Lib? What is the constructor line for U8glib? Note that the pin order is different:
ST7565             (SID, SCLK, A0, RST, CS)    // Adafruit Lib
U8GLIB_LM6059(SCLK, SID, CS, A0 , RST)   // U8glib
Oliver
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Below is the code used in the Adafruit and u8glib sketches. The Arduino is connected the same in both cases. The Adafruit one works, but the other does not.
Adafruit
Code:
// pin 9 - Serial data out (SID)
// pin 8 - Serial clock out (SCLK)
// pin 7 - Data/Command select (RS or A0)
// pin 6 - LCD reset (RST)
// pin 5 - LCD chip select (CS)
ST7565 glcd(9, 8, 7, 6, 5);
u8glib
Code:
U8GLIB_LM6059 u8g(8, 9, 5, 7, 6);
The Adafruit library leaves the left most column of pixels garbled. There are a few activated pixels, the rest are inactive. This makes pixel (0,0) actually located at (1,0). The rest of the screen is fine. I don't know if this is relevant information
Logged
Germany
Offline Offline
God Member
View Profile
Seems ok. Can you use the following construcor call:
Code:
U8GLIB_LM6059 u8g(8, 9, 5, 7, U8G_PIN_NONE);
and connect the reset signal to 3.3V.
Will this work?
Oliver
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Awesome! Thanks a ton.
It looks like the paging is off. To get the Adafruit library pages in the right order I had to change the following line in ST7565.cpp from
Code:
const uint8_t pagemap[] = { 3, 2, 1, 0, 7, 6, 5, 4 }; // Adafruit original
to
Code:
const uint8_t pagemap[] = { 7, 6, 5, 4, 3, 2, 1, 0 }; // Adafruit changed
I poked around and I haven't found where I would define the page mapping.
Logged
Germany
Offline Offline
God Member
View Profile
Great. Now we need to correct the display and the Bias. I have seen that the Adafruit code and the NHD display do differ in that. I also guess that I need to implement another variant for this display. So, here is another request from me. Can you apply the U8GLIB_DOGM128 constructor?
Maybe you can also send a picture of the result with the DOGM128 constructor. Main questions are: Is the contrast as good as before? Is it better? I also expect that the wrong line will disapear but the display might be flipped (not a problem, because u8glib can rotate the screen by 180 degree) and probably the row mapping is still wrong.
If the row mapping is still wrong, i would like to use the DOGM128 as a template for further changes.
Thanks, Oliver
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm making an Arduino shield for this LCD, so I'd be thrilled to see these changes make it upstream. It would be nice to point folks to u8glib. I really appreciate the work you're doing to unify the graphics libraries. I'll match the pin mapping with the u8glib default pins.
To see graphics I had to change the contrast in ug8_dev_st7576_lm6059.c, line 70 from
Code:
0x018 /* contrast value*/
to
Code:
0x005, /* contrast value*/
I have tried the U8GLIB_DOGM128 constructor. The default contrast was also poor, so I changed the contrast in u8g_dev_st7565_dogm128.c, line 59 from
Code:
0x018, /* contrast value, EA default: 0x016 */
to
Code:
0x005, /* contrast value, EA default: 0x016 */
A contrast of 0x005 in the DOGM128 constructor seems a little more washed out than the LM6059 constructor.
I've cloned your google code repo and I'm able to run ...arduino/create_release.sh. Do you want to make the changes in there and I'll test it? I can also rewire my setup to be consistent with your library.
Logged
Germany
Offline Offline
God Member
View Profile
Thank a lot for the pictures.
So, this is what i understand:
- page mapping is ok now
- col offset wrong by 4 pixel
- contrast wrong
- dogm128 a little bit washed out
I have created a new device in the repo: NHD_C12864. So you need to update the repo.
I have added this to the U8gLogo.pde example only (at the moment)
line 75: http://code.google.com/p/u8glib/source/browse/sys/arduino/U8gLogo/U8gLogo.pde
The code for the display is here:
http://code.google.com/p/u8glib/source/browse/csrc/u8g_dev_st7565_nhd_c12864.c
At the moment, this is an exact copy of the DOGM128 code.
--> change line 79 to "0x004"
- contrast wrong
--> probably change contrast in line 68 to 0x005 (or maybe other values like 0x006 or 0x007)
--> you might also try to change the value in line 55 from 0x0a2 to 0x0a3
Once you find the best values, i would be really glad to add these values to the new device.
Also, let me know if there is something else wrong with the new NHD_C12864 device.
Thanks for testing, Oliver
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Changing line 79 to 0x004 worked. The pixels are aligned.
Changing line 61 (not 68) to 0x008 looked good for contrast. I played with several values. 0x009 also worked. 0x010 is where the background started getting funky.
Keep line 55 at 0x0a2. To get a reasonable screen using 0x0a3 I had to bring the contrast down to 0x003.
Some people might consider the display to be upside down, but this is the orientation in which I would like to use it. It allows buttons beneath the screen to be as close as possible. Are you cool with leaving it like this in the library? It would mean one fewer steps in my instructions.
Logged
Pages: 1 2 3 [4] 5 6 ... 9   Go Up
Print
Jump to:
