SE USA
Offline
Faraday Member
@ssh0le
« Reply #390 on: October 05, 2012, 11:50:43 pm » |
HackaDay seem to be going down hill at a rate of knots!
yea ... I really should start writing for them again, then it will go down 3x as fast hehe
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Offline
Sr. Member
« Reply #391 on: October 06, 2012, 06:41:59 am » |
today i get my 68332 cpu Isn't that a bit old? Shouldn't you be looking at ColdFire microcontrollers instead? well, i do not like coldfire, too complicated, while the 332 is perfect for my hobbies i have realized a tiny 332 board with 1Mbyte nvram instead of flash and i am having a lot of fun I have a 68331 development board around somewhere. It's left over from an actual 68331 development project that I was pretty deeply involved in (the cisco-500 Terminal Server!)
tiny robotic stuff here with the 332 =P
Logged
CO, USA
Offline
God Member
« Reply #392 on: October 17, 2012, 05:19:17 pm » |
A total steer by wire would be pretty scary for me
Well, now now you can find out if it really would. Japan's Nissan Motor Co plans to equip some of its luxury cars with a system to control steering electronically, rather than mechanically, the first time so-called "steer-by-wire" technology will be used in mass-produced vehicles. And, in theory, you could hook an Arduino into that too!
Logged
... it is poor civic hygiene to install technologies that could someday facilitate a police state. -- Bruce Schneier
field road, jupiter creek
Offline
Sr. Member
Arduino rocks
« Reply #393 on: October 17, 2012, 07:21:32 pm » |
I broke down and bought a lamp/magnifier that has 36 white LED's rather than a weird circular flouro tube. It seems whiter than my last illuminated magnifier, maybe a tad brighter as well.
Certainly runs cooler than a flouro one!
Beginning to realise I need glasses!
Logged
nr Bundaberg, Australia
Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
« Reply #394 on: October 17, 2012, 07:34:19 pm » |
Beginning to realise I need glasses! Sad fact of life I'm afraid  Try one of the head-mounted magnifiers, they are great, a bit cumbersome but you can really see the small stuff clearly. ______ Rob
Logged
Central MN, USA
Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
« Reply #395 on: October 18, 2012, 12:10:57 am » |
Japan's Nissan Motor Co plans to equip some of its luxury cars with a system to control steering electronically, rather than mechanically, the first time so-called "steer-by-wire" technology will be used in mass-produced vehicles. And, in theory, you could hook an Arduino into that too!  They may be doing it to cut cost, like replacing tactile buttons with touch screens. By the way, I tested the MPG for my car. On highway if I use cruise control I can get the advertized 38MPG at 75MPH. I was on the other hand trying my best but only got 24MPG on local roads. They promised 27MPG. I was driving like a senior citizen. I think the CVT is very good at high speed. It shifts to a gear ratio that optimizes engine efficiency. My engine is running at 2,000 RPM or less at 75MPH. You want to always drive with cruise control otherwise if you step on the gas, the RPM goes up and ruins your MPG. But the same CVT is horrible at low speed, especially at stop to go. It easily revs at 2,000 when I was trying to get from 0 to 20MPH and then shifts down to 1,250RPM when I hit 30PMH. Maybe I need a tune-up.
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
I only know some basic electricity....
« Reply #396 on: October 18, 2012, 02:51:30 pm » |
Beginning to realise I need glasses! Sad fact of life I'm afraid  Try one of the head-mounted magnifiers, they are great, a bit cumbersome but you can really see the small stuff clearly. ______ Rob After getting the same advice from Grumpy Mike last year I went to Harbor Freight and checked theirs out. The one to get is the most expensive, almost $10 before the discount coupon -- I paid $7. It's got a light and has a box with 4 different double-lenses and clips on the visor I expect to hold the lens at 2 distances though you can put 2 lenses in at once (gets heavy) and maybe see germs with. The lens flips up or down, the visor does too (and occasionally needs tightening), it's always in the right position as you move your head and it leaves both hands free. I was using a magnifier with base but the visor is so much easier to work with I won't go back. It's well worth the money or even 2x-3x what I paid. This is the item, compare to the next cheaper one if you go there: http://www.harborfreight.com/head-strap-magnifier-with-work-light-95890.html
Logged
Examples can be found at Learning in the Main Site and at the Playground
Samplefinger
Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
« Reply #397 on: October 18, 2012, 02:58:56 pm » |
Beginning to realise I need glasses! Sad fact of life I'm afraid  Try one of the head-mounted magnifiers, they are great, a bit cumbersome but you can really see the small stuff clearly. ______ Rob After getting the same advice from Grumpy Mike last year I went to Harbor Freight and checked theirs out. The one to get is the most expensive, almost $10 before the discount coupon -- I paid $7. It's got a light and has a box with 4 different double-lenses and clips on the visor I expect to hold the lens at 2 distances though you can put 2 lenses in at once (gets heavy) and maybe see germs with. The lens flips up or down, the visor does too (and occasionally needs tightening), it's always in the right position as you move your head and it leaves both hands free. I was using a magnifier with base but the visor is so much easier to work with I won't go back. It's well worth the money or even 2x-3x what I paid. This is the item, compare to the next cheaper one if you go there: http://www.harborfreight.com/head-strap-magnifier-with-work-light-95890.htmlBased on comments on another thread I posted about working with surface mount parts, I bought this: http://www.amazon.com/gp/product/B0015IP380More expensive than Harbor Freight but hopefully it is worth it.
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #398 on: October 19, 2012, 08:08:31 pm » |
If it isn't, try the other as 4 different strength lenses to choose from is really nice.
Logged
Samplefinger
Offline
God Member
« Reply #399 on: November 16, 2012, 12:04:08 pm » |
Last night Adafruit had 10 Arduino Dues available. I got mine. All gone now, sorry.
They just shipped! WHOOT
Order Confirmation from Adafruit Industries
Thanks for shopping with us today!
The following are the details of your order. ------------------------------------------------------ Products ------------------------------------------------------ 1 x Arduino Due - assembled (Due) [ID:1076] = $49.95 ------------------------------------------------------ Sub-Total: $49.95 Sales Tax: $0.00 United States Postal Service (0.19lbs) (First-Class Mail incl. $0.75 insurance): $3.87 Total: $53.82
« Last Edit: November 16, 2012, 04:57:49 pm by JoeN »
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #400 on: November 16, 2012, 01:55:22 pm » |
I got 100 18mm piezos for $10.40.
They work but not so well as the ones I paid more for and they are flimsy, not suited for hard use but okay as vibration/touch sensors.
I haven't tried yet but I'm not sure they'd last as buzzers either, not after how one came apart.
As buttons, I think a diode will serve to debounce (real fast touch read) but maybe need 4 as a bridge to keep pin-safe?
I also got some CR2025 batteries for a remote and note DealExtreme shipped a 5 pack as ordered but with 1 missing. I won't raise hell over it (maybe 25 cents) but it's not a good sign at all.
Still waiting on 3 bare-board MP3 players with SD adapter and 3 breadboard-ready SD adapters.
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #401 on: November 26, 2012, 06:34:55 am » |
I got my SD Modules and MP3 players (which were not quite what I thought) and went looking for docs on the SD modules. But there's none posted so I emailed LC China Tech and they say they will datasheets on whatever they make. I'd like to get opinions of the things they do make, some of the modules psych me up a bit. Like the two that look like they can do USB hosting, and the nice MP3 module and others that should take care of those "Arduino hasn't got the speed" projects. http://www.lctech-inc.com/Hardware/I bought the SD modules through DealExtreme, $2.60 each for 3. So far it looks like all it will take to connect to an UNO is 8 female-to-male jumper wires. If I can work them out then just about anyone should be able to use them.  LC tells me they will beat the price on 1 or many without asking what I paid. Also they tell me they take PayPal. However their site looks like it needs help if it's to become hobby-friendly. Of course soldering up an SD adapter is probably even cheaper.
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #402 on: November 26, 2012, 09:20:49 pm » |
eh i dunno in single quantities I spent 2.90 for a socket, 52 cents on a level shifter, + board + time + header
Logged
Pittsburgh, PA, USA
Offline
Faraday Member
« Reply #403 on: November 26, 2012, 09:35:30 pm » |
Hey I -have- the SD modules. They did cost me $2.60 each though shipping on the total $48 order did run almost $2. What are the chances that China subsidizes electronics, like they do solar panels?
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #404 on: November 27, 2012, 01:23:51 am » |
its not a matter of being subsidized, its a matter of bulk
just order 10 of something save 30 cents a unit, now order 100,000 of them ...
Logged
