Loading...
Pages: 1 ... 31 32 [33] 34 35 ... 40   Go Down
Author Topic: Your latest purchase  (Read 30363 times)
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Anything else I forgot?
millis and its ilk will be off.
This... http://arduino.cc/forum/index.php?topic=70475.0 ...cures millis (for 20 MHz).
I can probably rustle up a fix for micros (which fixes delay) if you need it.  For delayMicroseconds I suggest using _delay_us from AVR Libc.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Now I can't say for sure that it is working perfectly...
I vaguely recall from the folks at avrfreaks that EEPROM writing is the first to "go" as the clock speed increases.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
It would be interesting to experiment with things where speed is the essence, like writing VGA output.
Running at 24 MHz is a 50% speed boost, which isn't too shabby.
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
you should look at some of the xmega's, arduino support is out there, no idea how perfect it is with libraries and whatnot, but the core is there to write your own. Anyway those things come in 8 and 16 bit flavors clocked up to 32Mhz.
I have a small strip of them and some 25.175Mhz crystals, the dot clock speed of 640x480 VGA, which easily divides for sync signals (not specificly for generating 640x480 graphics)
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I don't particularly care about recompiling the core because only a small number of things will be out. For example, baud rates, but you can compensate for that. And you could compensate for the readings returned by millis().
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
https://github.com/akafugu/Xmegaduino/blob/xmegaduino/README.md
Logged
Offline Offline
Sr. Member
View Profile
So you just popped out the 16Mhz crystal and replaced it with the 24Mhz?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
This was on one of my breadboard models, but yes, I shoved the crystal in, and reprogrammed the fuse to not use the internal oscillator, as shown:
The ICSP programming cable is visible.
Logged
Offline Offline
Sr. Member
View Profile
So I can use any existing 16Mhz bootloader (example: from Adafruit) with a 20/24 Mhz crystal, right? -- millis() timing may be off, but all the others should work fine as is.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
The thing about the core is, the processor doesn't really know what speed it is running at. So for example if you use the 8 MHz internal oscillator everything will just be half the speed. So a 9600 baud rate for the serial port will really be 4800 baud. And delay (1000) will really delay 2000 mS.
Now for the bootloader, the problem will be it expects a certain baud rate. However if you change boards.txt to reflect the difference, it should work. So for example, for the Uno:
Code:
uno.name=Arduino Uno
uno.upload.protocol=arduino
uno.upload.maximum_size=32256
uno.upload.speed=115200
uno.bootloader.low_fuses=0xff
uno.bootloader.high_fuses=0xde
uno.bootloader.extended_fuses=0x05
uno.bootloader.path=optiboot
uno.bootloader.file=optiboot_atmega328.hex
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.build.mcu=atmega328p
uno.build.f_cpu=16000000L
uno.build.core=arduino
uno.build.variant=standard
Since the upload speed is normally 115200 you would need to increase that to 115200 * 24 / 16, which is 172800, assuming the USB chip can handle that speed.
However in my case I programmed with ICSP (not the bootloader) so that didn't apply. So, disclaimer: I didn't test with a bootloader.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Could you bootload at one speed and run at different?
Logged
Examples can be found at Learning in the Main Site and at the Playground
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Absolutely. All the bootloader does is put the program into program memory. You could then turn the power off, replace the crystal, and power it up again.
Logged
Dallas, TX
Offline Offline
Sr. Member
View Profile
One of my offspring got one of these for Christmas. Have any of you seen them? Made in the UK and pretty nifty.
http://www.mikromart.com
Logged
Boston Suburbs
Offline Offline
God Member
I am above your silly so-called "Laws", Mister Ohm.
View Profile
WWW
Since when is Radio Shack reasonably priced?  Went to the MALL store and got a Seeed Studio Proto Shield for $9.99!
Okay- Credit where credit is due.
Seeedstudio-- the protoshield kit is awesome.  This is a great deal at ten bucks.
I expected the board headers and such, and not much else.  However, they also toss in an extremely useful collection of common components:  two red and two green LEDs, a bicolor LED, resistors for the LEDs, a 10k pot, two 40-strips of male pin headers, a 40-strip of female header, a 40-strip of long male headers, spare spacers, four tactile switches and two slide switches, and a USB socket.  That's a heck of a lot for ten bucks!!!
I will be grabbing these again!
« Last Edit: March 04, 2013, 07:41:19 pm by focalist » Logged
When the testing is complete there will be... cake.
Maine
Offline Offline
Sr. Member
Caution: Explosives in use.
View Profile
WWW
I finally bought an ISP for burning bootloaders, lol. Its apparently based on the USB ASP. Cost $7 on ebay.
I also bought a used server rack with UPS, 6 servers, a DAS, and a bunch of other junk. I'm probably going to use it to test an arduino based datacenter monitoring system.
Logged
"Anyone who isn't confused really doesn't understand the situation."
Arduino-based airsoft props -> www.nightscapetech.com
Pages: 1 ... 31 32 [33] 34 35 ... 40   Go Up
Print
Jump to:
