Topic: Your latest purchase (Read 418831 times) previous topic - next topic
cr0sh
Thanks. Well, if anyone has a 311-1192-00 10K pot w/switch in their back pocket, I'd be interested in that. and the 2 knobs that go on it. It works, at least as far as I can tell just turning it, but the center stem is bent, so there's a catch, where turning the switch stem moves the pot, and vice versa.
That may or may not be an easy pot to find; old tek equipment can be hit and miss finding parts. Here's the manual for it, anyhow:
http://bama.edebris.com/manuals/tek/475adm44/
You might be able to find something here:
http://www.qservice.tv/vpasp/shopdisplayproducts.asp?id=59&cat=TEKTRONIX+Potentiometers+-+Switches+-+Connectors
I had to order an implosion shield for my Tek 2213 scope (the one that came with the scope was blurred by somebody having sprayed something on it); I think the shield I got came from Eastern Europe or something, but it was the part I needed.
See if you can find the part - or if you can't, email them - maybe they can find you the part you need?
Good luck!
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
justjed
Good luck!
Thanks cr0sh. I actually tried to order from them, but wound up not proceeding, based on the 3 strikes rule:
- required creating an account
- no info on shipping method (I use different addresses for USPS vs. UPS/Fedex)
- Paypal
Too picky? Well, I keep a minimum amount in my Paypal account, and never intended to use it for anything other than incoming. And my CC doesn't work via Paypal -- I guess my carrier just disallows them. I pretty much feel that a real business ought to be able to take cards directly. So, in the short term, I made a wierd face and bent the stem back to straight, but it still catches. Didn't break anything, that I can tell. Might be a function I'll never use anyway. I just like to have things "right".  :smiley-roll:
Sphere Research looks better to me. But they don't have one. :( But I feel more comfortable shooting them an e-mail asking if they can let me know when they find another.
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
robtillaart
book - http://www.amazon.com/Arduino-Workshop-Hands-On-Introduction-Projects/dp/1593274483/ -
well written tutorials, projects are build up in complexity. Good book to help explain why Arduino is so much fun.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
John_Smith
As an old fart, I had put off buying the FTDI cable ( $ 20 )  to allow in circuit programming, but I had to buy a USB/ttl module at the weekend, for $4, and it has all the pins available, so I fitted a cap for resetting and the project can be reprogrammed via its USB lead.
I bought  spare one at that price, so I saved $16 on the lead for in circuit programing for future projects
45 years of editing projects with a knife and soldering iron, then I found Arduino !
retrolefty
Ever do ICSP sketch uploading using a 'hardware' programmer? It gives one additional options/trade-offs. E-bay has USBasp types for around the same price as the module you bought and often throw in a usb cable.
TomGeorge
Hi, my workplace had to order 100 12way PCB mount screw terminals.
One of the online suppliers gave us the price we were looking for with 6 day delivery.
On the due day the satchel turned up and out popped the contents in the first picture, a box of 50, a bag of some and a smaller box.
The supplier had to go to, by the looks of it, three different locations in their network to get the required numbers.
Well the bag had 49 items, the small box, I'll let the second picture explain.
Everything runs on smoke, let the smoke out, it stops running....
graynomad
#801
Feb 13, 2014, 02:48 am Last Edit: Feb 13, 2014, 02:49 am by Graynomad Reason: 1
ha ha.
Sounds like E14, they often fill your order with parts from all over the world. It boggles the mind that they can make money getting one connector from Timbuktu. I guess they don't really but have to be seen to be able to fulfil orders and be a one-stop-shop, or you go elsewhere.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
TomGeorge
Give that man a prize....
Exactly, loose on one and hopefully win a lot on another.
I was in supermarket the other day, major one, got a bag of ice (frozen H2O), got home and found out that it came from interstate, not from local ice maker.
How much energy to make, keep frozen from NSW to VIC, must be some carbon tax in there somewhere, but it was 50cents cheaper than local product.
I usually buy local product but didn't want to get out in heat for just a bag of ice, will think next time.
Tom...... :)
JoeN
I bought about $25 worth of "old junk" at Goodwill today to tear it down and pull off parts.  I got an Iomega Zip drive with a nice stepper motor, very odd servo (it opens the disc cartridge door, and a few good parts, an XM receiver, two DSL modems/routers with some nice bits, a Walkman CD player (two motors, a bunch of ASICs that I can find datasheets on but are probably useless), a scanner (want to mess with the sensor) and a broken down PS2.  There is an old Atmel controller on one of these, pre-AVR, presumably an 8051, a Renasas controller, several EEPROMs and flash memories, a bunch of crystals and oscillators and regulators, lots of inductors of various types, and one very interesting part I didn't know existed.  It's  apparently 16 transformers inside one surface-mount, approximately quadruple-height chip:
http://www.ic72.com/pdf_file/p/136610.pdf  (PN PH406003).
Ever use one of these?  I guess that 1/4 of the chip is used for each Ethernet channel.  There was a separate integrated transformer package for the DSL input.
I will never ask you to do anything that I wouldn't do myself.
Paul__B
#804
Feb 13, 2014, 10:14 pm Last Edit: Feb 18, 2014, 09:56 pm by Paul__B Reason: 1
I got an Iomega Zip drive with a nice stepper motor, very odd servo (it opens the disc cartridge door), and a few good parts,
Arguably more useful as parts than as a reliable data storage medium.   :D
Well, that makes sense, doesn't it?  Why waste space?
SirNickity
That's awesome.  At least it was well-protected!
At an old job, we ordered a NAS (that is, a datacenter NAS with 24 hard drives in a 3U rack shelf) from our typical reseller.  The first thing to arrive was a box about the size of a pair of work boots.  Opened it up, took out the foam supports, and found a smaller box inside.  Opened that, and nestled safely within eggshell padding adhered to the box, was a single sheet of paper:  The software license agreement.
This box was overnighted, BTW.
Since it was a private company bidding on a government contract that required the equipment purchase, that right there is our tax dollars at work.  Makes ya feel all warm and fuzzy inside, don't it?   :smiley-roll:
SirNickity
and one very interesting part I didn't know existed.  It's  apparently 16 transformers inside one surface-mount, approximately quadruple-height chip:  Ever use one of these?  I guess that 1/4 of the chip is used for each Ethernet channel.  There was a separate integrated transformer package for the DSL input.
Isolation transformers.  They're on every Ethernet device, although many of the physical RJ45 jacks have them integrated, so there won't be a separate part on the board.  They provide balanced, differential signaling and remove the likelihood of ground loops and DC offset by having the transceivers electrically isolated from each other.
Paul__B
What you can get on eBay!
(Check out the shipping to Australia!)
(No, I'm not bidding against you!   :D)
TomGeorge
What do you expect it is Worldwide Saver Rate.... :)
Paul__B
Marketing?
(Something I do not need - is non-working LCD monitors.  There are at least a dozen monitors sitting on the floor here albeit not necessarily 19", a significant proportion of which are faulty in some way.  The wife is not at all happy.  She would be really happy if I  could flog off any of them for $9.99 plus postage, least of all the non-workers.)
