Topic: Your latest purchase (Read 419485 times) previous topic - next topic
GoForSmoke
I saw a Youtube the other day where a guy built a circuit that allowed him run "dead" CFLs.
Apparently what dies is something in the cheap planned-obsolescence electronics.
If something like that could revive LCD panels then that would be just smiley-dancey wouldn't it?
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Tasking: techniques make the trees, the sketch is the woods.
See the woods and the trees, comment both.
TomGeorge
Hi Paul, some LCD monitors die because of the power supply to the rear light system failing.
You can check by turning the monitor on and with some input that you know should be displayed, look at the monitor surface from the side while shining a torch on it.
If you can see the image then the backlight or its supply is u/s.
And you can get replacements on the tadaaaaa...****internet****  , wow isn't electronics wonderful.
Tom..... :)
Everything runs on smoke, let the smoke out, it stops running....
overkiller
Look what beautiful part I bought!
9V Solar Panel, with will charge batteries for me. (Or power up my Attinys), yellow banana plugs, 5 big yellow LEDs and Attiny2313A.
TomGeorge
Quote
At an old job, we ordered a NAS (that is, a datacenter NAS with 24 hard drives in a 3U rack shelf) from our typical reseller.  The first thing to arrive was a box about the size of a pair of work boots.  Opened it up, took out the foam supports, and found a smaller box inside.  Opened that, and nestled safely within eggshell padding adhered to the box, was a single sheet of paper:  The software license agreement.
This box was overnighted, BTW.
My aunt, deceased now, when she came to Australia for holiday said that when she worked at Slough Poly, she was a secretary, all software updates at the time was delivered by Sercuricor Deliveries in a similar way.
Big box, inside a very small box, loaded with floppies. This was back in the 70's so they would have been BIG floppies.( 8inch??)
Tom.... :)
GoForSmoke
Quote
Tom.... :)
Most likely 8's. And low capacity at that.
Of course the alternative may have been punched tape.
Paul__B
I know.   :D
There is a firm in Sydney who actually repairs monitors, strange thought that be.  The fellow turns up to the North Rocks markets, perhaps less regularly than he used to.  Some years ago, I bought a second-hand monitor from him (I mostly buy second-hand monitors - and computers - much cheaper that way) which failed - the backlight - with a bad smell.  I took it back to the markets and he said "no trouble - we will fix it"!  I was somewhat shocked - who repairs monitors these days?  Nevertheless, my son picked it up later from them in the backblocks round Auburn and it proceeded to work just fine.  (Replaced the inverter.)  I forget now just which one it was of course.
One monitor here - of the said many - is documented on the 'net to simply require replacement of the electrolytics - perhaps $10 from Jaycar.  The problem is - I pick up monitors at garage sales for less than that though the 24" I am presently using did cost all of that.  So that's the situation, I am just a little reluctant to trash the older ones until I have spent the time to conclusively determine they are BER (in the "experimenter" sense).
Constantin
#816
Feb 19, 2014, 03:59 am Last Edit: Feb 21, 2014, 05:45 pm by Constantin Reason: 1
Silicon Labs Si7020 I2C humidity and temperature sensor (see writeup in sensor section for longer description). Looks like a nifty replacement for the SHT21, and HTU21D series of DFN6-sized sensors (i.e. 3x3mm) at a great price point ($4 ea with dust shield!). I hope they stick around, and stay at this price point unlike their competitors (the HTU21D is in and out of stock constantly, and the price at Digikey raised 50% to $12.50 ea, a real headache!)
So I bought 5 with the dust shield.  :)
TomGeorge
Hi everybody, after the last packaging issue I posted the other week, we used the same people to purchase a particular SMPS 5 pin chip to repair a PLC.
Say the number was  yyy-2yyy, we had to wait 6-7 days cos it was not in stock in Australia, fair enough, we were repairing a batch of 15 of these PLC and only one needed this IC. So it was not urgent, ordered 10 units to keep in stock.
6 days later delivery turns up, plastic bag says  yyy-2yyy, but did not contain IC, contained SIM card socket.
Looked up SIM socket, part yyy-4yyy, okay picked up out of wrong bin, phoned supplier, told them situation, fine will send correct part.
4 days later (today) delivery, plastic bag, yyy-2yyy, contents  yyy-4yyy.
Phoned supplier, told story, very sorry, will ring back.
Rang back, sorry cannot supply IC out of stock not able to restock.
Now question, are they really out of stock, could be, or is the IC in some other bin, not yyy-2yyy or conveniently yyy-4yyy and they can't find it?
They are  supposed to have 180 units in stock ,somewhere but can't find them.
It seems this IC is located in one warehouse only ,so that narrows it true location down.
The value of ten of these ICs is $25, so not even worth sending a work experience kid into the warehouse with a cut lunch and a pith helmet, he/she would probably turn feral before  finding it.
They will, when new stock eventually arrives just put, them in the correct bin, (we hope).
There will at sometime out there be some poor sod like us, ordered a part and gets SMPS IC, hopefully not twice.
Tom... :)
westfw
Whoo hoo!  Used a charity auction as an excuse to buy the Android tablet I've been thinking of getting, justified by the Android Programming classes I'm taking (or trying to take.)  Tegra "Note 7."  More than I was planning to spend, but the cheap tablets don't seem to have Bluetooth, and it was for a good cause.
Also my first order from DipMicro (random parts including some tiny85s), and "Analysis of Algorithms" (Sedgewick and Flajolet) (which I think I despair of ever actually understanding.  Sigh.)  (Sedgewick's MOOC on (just) Algorithms is very good, though!)
GoForSmoke
Sounds scarey. They use examples? Have student exercises?
That's what got me through advanced maths. When I HAD to do the homework, it really helped!
graynomad
Yikes Tom, the perils of purchasing eh?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
graynomad
My latest purchase, another 20-foot container (the blue one, that's 3 now, I love shipping containers). This will be the GRAYnomad's man cave from which many exciting Arduino projects will emerge once I line the inside, cut some windows, make some benches and wire up 240 volts.
This was two days ago, I've since levelled it up.
pico
Does this mean the 'nomad has put down roots? Doesn't look like something you can easily tow...
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
graynomad
Sort of, we are not planning to go anywhere for a couple of years at least. Still living in the truck but it's parked on our land. We are buying a lot of "stuff" that normal people do, heck we even got a washing machine recently, so much for my minimalist approach to life :)
______
Rob
draythomp
Some of you will find this hard to believe.  I have a neighbor (roughly 3/4 mile south and 1/4 mile west) that built a huge garage.  What was interesting, besides being jealous of the garage) was that he had the foundation poured, inspected then he brought in 7 containers.  He then had a backhoe dig out the center of the foundation about 30 feet deep, and a crane lift 5 of the containers and put them in the hole.  Then he covered them all with plastic sheets, and buried them.  After running some equipment over the loose dirt to compact it, he poured the floor inside the foundation, and had the inspectors come out to inspect.
So, the garage is all finished now and looks pretty cool.  All of us are wondering what he is going to do with the containers buried under it.  The left over two containers are setting on the lot along with a few huge rolls of plastic.
So Nomad isn't the only one that love containers.
