Topic: ionisiation? (Read 7621 times) previous topic - next topic
Joes
how would i wire it for high voltage?
diagram
Grumpy_Mike
Just put a high voltage on one terminal, with a 1K resistor in seriese with the input. Then wire a zenner between input and ground. The other end of the sensor goes to ground.
Grumpy_Mike
No like this.
Joes
ok thanks
what do we call high voltage?
PaulS
Quote
Dangerous.
Grumpy_Mike
#20
Mar 05, 2012, 08:48 pm Last Edit: Mar 05, 2012, 08:50 pm by Grumpy_Mike Reason: 1
Anything higher than 5V.
The higher the voltage the more current the flame will conduct.
Making the resistor higher will make any change in current a larger change in voltage and the easier it is to detect.
Joes
sorry to bring this back up again i had got this working but its extremely unstable as there is not much movement on the arduino, i was using 1500k resistor to even get it to work i cant seem to add any more than that or it seems to go the other way so i dont know how else we could make this work more reliably and give us more of a range on the arduino
i measured the resistance of the probe and flame was 1400k and my supply voltage i was running 17.11 and im getting back on the other end 1.65V so hell of a drop?
Grumpy_Mike
You need to use an op-amp to make the signal from the flame bigger.
Start of with a gain of about 100 and see how you get on.
Joes
ok thanks for that i have had a bit of a play and come up with this
http://s906.photobucket.com/albums/ac270/Joes-110/?action=view&current=Untitled.png
but now we have gone to the other way now it is to sensitive and can not seem to dye down any idea?
Grumpy_Mike
Three things wrong with that circuit.
1) It only has a gain of 2, see how to calculate the gain of a non inverting op amp here:- http://en.wikipedia.org/wiki/Operational_amplifier
2) You in effect have a floating input, that is the input is very high impedance and is picking up all sorts of interference.
3) That sort of circuit will only amplify voltages, you are in effect putting a variable resistance on the input you are not inputting a voltage.
Try this. +ve input of amp connected to two 1M resistors, one goes to +5 and the other ground. Then feed this point and ground at your flame.
Change the resistor that goes from the -ve input to ground to a 10K. What sort of op amp are you using.
Joes
thanks for the reply i am using a LM358 as this is what i had lying around.
ok can you draw that as this is all a bit now to my and will be easier to understand thanks
Grumpy_Mike
You might have to play about with the value of the top 1M
Grumpy_Mike
Sorry I forgot about the DC bias. Take the resistor that goes to the -ve of the op amp to ground and disconnect it from ground an put it to the wiper of a 10K pot with the two ends to ground and +ve.
This will allow you to adjust the output to be mid range with no flame, then you should see it move in the flame.
Joes
like that?
Grumpy_Mike
#29
Nov 24, 2012, 10:41 pm Last Edit: Nov 24, 2012, 10:43 pm by Grumpy_Mike Reason: 1
No the end of the pot goes to the +ve supply not the +ve input of the op amp.
And the 100K still goes to the -ve input of the op amp.
And you still need the 10K resistor going between the wiper and the -ve input of the op amp.
