Loading...
Pages: 1 2 [3]   Go Down
Author Topic: ionisiation?  (Read 916 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
ok cool i got it now thanks, will have to get some resistors in and have a play
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
right i tried that and it didnt seem to work when adjusting the pot it just seemed to be all the way one way or all the way the other. i dont know if i need a higher rotation pot so i can be more accurate with it? im currently using something like a 300 degree at the moment
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
I really don't think you need an op amp for this. The Arduino pins have very high input resistance (around 100 Mohms), so detecting the difference between 1.7Mohms and infinity is easy. I used a voltage divider made from two 4.7Mohm resistors with an atmega328p in a recent project. However, you will need to take precautions against picking up interference. I suggest you connect your ionisation probe between the input pin and ground, use a 4.7Mohm pullup resistor to +5V, and also connect a 0.1uF capacitor between the input pin and ground.
« Last Edit: December 02, 2012, 04:33:27 am by dc42 » Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
You can get finer control by putting fixed resistors in the top and bottom of the pot so the wiper covers a smaller of voltages. Also try reducing the gain a bit.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
i did try this but did not seem to work
Quote
 i haven't altered the gain at all, i presume to lower the gain i reduce the value size of the 100k which is connected to the output of the op amp?
right i think i've got it working in a matter of speaking with out altering the gain the problem i have now is it seems to be too sensitive still so putting my finger between the probes is enough to activate it.
Logged
Online Online
Brattain Member
View Profile
WWW
Quote
That would be normal for a high gain high impedance circuit like you have here.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
