Topic: Temp, Humidity CO2 sensor and library. (Read 136444 times) previous topic - next topic
DirtGambit
I dont know rob, I havent opened the sensor to find out, also i dont know if they have altered the firmware of sensor to stop outputting null values if the sensor has no ldr fitted, the sensors output is always rh,Temp,unfiltered co2, filtered co2.
badwheels thats quite a demand from any all in one sensor, the cozir does most of what you need, if you were to have all those separate you would have quite a breadboard and be in wire/lib hell, your project sounds cool though good luck.
serdargoksal
Hi all,
Does anyone have an idea where to get COZIR.h library ?
robtillaart
#17
Jan 10, 2013, 05:33 pm Last Edit: Jan 10, 2013, 05:48 pm by robtillaart Reason: 1
yes.
the lib is attached on the first post (it includes the .h file)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
latest version I have is 1.03 - see attachment - but it is a long time since I edited in it. there may be some work in progress on some points in it.
Note that the calibration functions must be used careful and do not use them if you don't understand their impact.
#all disclaimers apply ;)
If you have comments remarks let us know.
Rob Tillaart
plantgrower
the attachment returns Error 503 Service Unavailable
Do you have code that works on an arm nxp lpc1769 ?
My CO2 readings seem high what's the best way to calibrate this device. I only have outside air to calibrate against.
many thanks
DirtGambit
Just calibrate via fresh air which gives a value of about 380, maybe your in an area of high co2, I have a main road next to my house with a lot of traffic and average values were 420-450, are your values wildly out of range?
nschmal1
What program did you use to display the graphs of the temperature, humidity, co2?
foxlox
hi!
I'm using a COZIRâ„¢ Wide Range Sensor, http://www.gassensing.co.uk/wp-content/uploads/2013/02/COZIR_-WideRange_-Datasheet_GSS.pdf, and I tried to use the cozir.h library as mentioned in the first post, but without success. Must I observe some particular attention? I'm tryng it with only usb cable attached to my Arduino UNO, perhaps I need an external 12V input for Arduino? I need only 3.3v to power the sensor.
I receive nothing from sensor, all zeroed values...
I tried also the sample from Cozir for this sensor to read byte-to-byte from serial but I receive only 255 and never 0x0A for end transmission.
please help me thx.
   [fortunato]
robtillaart
One often occuring problem with rs322 devices is that rx and tx need to be reversed. Did you try that?
Furthermore the sensor high bit is only 3.3Volt. The UNO needs at least 4.5 volt to recognize it as a HIGH signal. Check this with a voltmeter.
You might need a 3.3<->5 voltage converter for this.
Furthermore you could check if the analog out gives a (changing) voltage. Can you check?
Rob Tillaart
foxlox
Hi robtillaart
which pin I could check for analog voltage?
I have an external max3232 interface, which pins I must connect? I found that:
sensor tx: t1n
sensor rx: r1out
arduino tx: r1n
arduino rx: t1out
it's correct? I receive nothing :-(
robtillaart
Quote
according to - http://www.gassensing.co.uk/wp-content/uploads/2013/02/COZIR_-WideRange_-Datasheet_GSS.pdf -
pin 9 is analogue
Quote
A voltmeter should be able to detect a signal from the TX pin of the sensor.
this is the way to connect serial devices.
sensor TX --> Arduino RX
senosr RX <-- Arduino TX
(disclaimer, I don't have this sensor myself)
Rob Tillaart
foxlox
Hi robtillaart,
I connected the sensor as you hint, with 5v instead of 3.3v and it works correctely.
thx!!!
robtillaart
Good to hear that!
If you have remarks wrt the lib please post it in this thread
that might be things missing, buggy, etc ;)
Rob Tillaart
jjaroska
Does anybody have a picture of the inside of the enclosure or DirtGambit, would it be too much trouble to see the inside of the box?  Also, does anybody have a link for that enclosure?
Thanks
robtillaart
You can send him a PM with your request...
Rob Tillaart
