Topic: ArduinoISP not Working (Read 8358 times) previous topic - next topic
StuartP
I'm trying to use arduinoISP to install a bootloader on a 1284p without much success.
However for repeatability, I have performed the details below using a 328p
ISP Board - Arduino diecimila atmega168
Target Board - Arduino diecimila atmega328p
Arduino IDE 1.0 for macosx
arduinoisp.ino from https://github.com/rsbohn/arduinoisp
1 - Program the ISP board bootloader using usbtinyISP
tools->board->arduino deicimila w/ ATmega 168
tools->programmer->usbtinyISP
tools->burn bootloader
Debug / verbose output http://pastebin.com/QmdKzLVt
This leads to a board with pulsing pin13 LED
2 - Program ISP board with ArduinoISP
Download ArduinoISP.ino from github as above
Open in arduinoIDE
Verify  - output http://pastebin.com/hNLRCR82
Upload - http://pastebin.com/9Z1jasCu
3 - Connect target board to ISP Board.
Connections as per http://arduino.cc/en/uploads/Tutorial/arduinoisp.png
4 - Program targetboard bootloader
tools->board->arduino duelimnova w atmega328
tools->programmer->arduino as isp
this leads to "Error while loading bootloader" full output here http://pastebin.com/QZEdzBS9
I believe this to be down to the autoreset of the diecimila, adding a 110ohm resistor between 5v and reset on the ISP board, repeating the programming step I now get
Code: [Select]
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega168 -cstk500v1 -P/dev/tty.usbserial-A4001l0H -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x00:m -Uhfuse:w:0xdd:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/swp/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbserial-A4001l0H
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: ser_recv(): programmer is not responding
avrdude done.  Thank you.
johnwasser
ArduinoISP use the STK500v1 protocol.  Larger chips (like the 1284p?) require the STK500v2 protocol.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
StuartP
Could be, but as I can't program an arduino atmega328 using arduinoISP it's not the issue.
johnwasser
Quote
avrdude: verification error, first mismatch at byte 0x0000
         0x3f != 0x00
You didn't disable auto-reset on the Arduino running ArduinoISP.  The board was rest and avrdude was talking to the bootloader.  It speaks a variant of STK500v1.  It's happy to say "OK!" when you set the lock bits but always returns 0x00 when reading them back.
Connect a small (1 to 10 microfarad) capacitor between Reset (+) and Ground (-).  This absorbs the reset pulse.
StuartP
ok.With a 10uF capacitor between reset and gnd on the programmer. I get the following
http://pastebin.com/uASZS5tS
maniacbug
That one reports failure due to this:
Code: [Select]
avrdude: Device signature = 0x1e9406
According to that, the chip you're programming onto is a 168 not a 328.
StuartP
168 is in the arduino board being used as the programmer, 328 is in the target board.
Osgeld
#7
Feb 13, 2012, 10:59 pm Last Edit: Feb 13, 2012, 11:03 pm by Osgeld Reason: 1
Quote
theres your problem stk500v1 != avrisp
how do you fix it? I dunno I usually get pissed and just do it myself from the command line, or if I dont need a bootloader Ill just add a entry to boards.txt
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
StuartP
Ok.
I'm now really confused.
http://arduino.cc/en/Tutorial/ArduinoISP
States 'Use the Burn Bootloader > Arduino as ISP command.'
This implies that either the instructions for arduinoISP are incorrect, OR the arduino IDE isn't doing the correct thing ?
Osgeld
Quote
that would be my guess
StuartP
Ok.
Is anyone able to suggest a suitable alternative to using an arduino deicimila to program an 1284p ?
Osgeld
are you just trying to program it or bootload itso you can program it later using a serial connection?
StuartP
Bootload to allow serial  later.
For info I tried changing the programmer type using avrdude on the command line
http://pastebin.com/59K400NP
Same result.
Argggg!
Osgeld
#13
Feb 14, 2012, 12:42 am Last Edit: Feb 14, 2012, 12:44 am by Osgeld Reason: 1
I share the feeling, I tend to cuss atleast once whenever messing with it
ok so how is the 328 clocked right now? like was it set for a external clock before and its now trying to run on an internal clock?
(also what os are you using, is that linux or mac?)
StuartP
16MHz crystal for the 328 (which is what it was previously)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
