Topic: ArduinoISP not Working (Read 9426 times) previous topic - next topic
Osgeld
I dont know how arduino acts on OSX (I have a mac but its 15 years old and only runs up to 10.2) so I dont know if you can just run avrdude from a command line without having to search for it ... in linux it installs a package that makes avrdude part of the path so you can execute it from anywhere but try running it from a command line, if it doesnt work you will have to hunt it down (which should be in the first couple lines of your pastebin)
anyway try running it from a terminal like
avrdude -p atmega328p -c avrisp -P /dev/tty.usbserial-A4001l0H -b 19200 -v
and make sure your reset is still disabled on the board
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
StuartP
Ok.
Without the 10uF capacitor
Code: [Select]
30:avr swp$ /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cavrisp -P/dev/tty.usbserial-A4001l0H -b19200
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/swp/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbserial-A4001l0H
         Using Programmer              : avrisp
         Overriding Baud Rate          : 19200
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel AVR ISP
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.07s
avrdude: Device signature = 0x1e9406
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
with the 10uF capacitor in place
Code: [Select]
Remove power to the 328 target
Code: [Select]
avrdude: stk500_getsync(): not in sync: resp=0x66
Osgeld
ok getting a little closer, load this on your arduino
http://code.google.com/p/mega-isp/downloads/detail?name=ArduinoISP.04.zip&can=2&q=
I remember someone saying that the isp on 1.0 is screwy, and I use this one all the time, then try avrdude again
StuartP
I'm using the latest ArduinoISP as mentioned in the first post
arduinoisp.ino from https://github.com/rsbohn/arduinoisp
StuartP
Ok, just given this a go with arduino022, 10uF capacitor. Still get the same result with the wrong chip being recognized.
StuartP
Ok.
Arduino 022 and the supplied arduinoISP sketch appears to work on the 328.
Testing with the 1284p, I get the following
avrdude: Device signature = 0x1e9705
johnwasser
That's the right signature for the 1284p.  Is the right processor being specified on the avrdude command line?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
StuartP
Well currently no, but thats deliberate.
At least I now know I'm able to probably get a bootloader onto my 1284p.
Going to try manibug's mighty-1284p package, which includes an optiboot derived bootloader
NicoHood
Its fixed in 1.5.7 (avrdude bug).
Also see this: https://github.com/NicoHood/Hoodloader
