Topic: Convert .brd to other formats (Read 7734 times) previous topic - next topic
deathbyte
Hey, does anybody know how to convert .brd files to .jpg or any other simpler format which could be opened easier on any PC??
Please explain :)
johnwasser
Download Eagle:  http://www.cadsoftusa.com/downloads/
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
deathbyte
Duh...
i have eagle already :\
I dont have printer. In order to print layout i must get a print from others. If my file was .jpg or .bmp it would be easier to mail them.
mmcp42
alt-PrntScrn copies the current screen to the clip board
open paint
ctrl-v pastes the clipboard
save as <<fill in your favourite image type>>
or file::export::image
there are only 10 types of people
them that understands binary
and them that doesn't
KirAsh4
As mmcp42 suggested, you can Export it as a PNG image, which can be opened by just about any image viewer, including a web browser.  You can export the full board, or just the part you are zoomed in to on screen.
florinc
westfw
Or do CAM output as postscript.  Which is likely to be the most accurate.
(Though, EAGLE does do a very good job of "printing" actual size board layouts.)
KirAsh4
You can also print as PDF.
This is only valid if they have a PDF print driver installed.  I always assume the very minimum, meaning someone might not have that.
westfw
Quote
EAGLE has PDF output generation in its "print" command whether or not you have one of the special PDF print drivers installed, if that's what you meant.  Postscript too (separate from the Postscript CAM generation I mentioned before, apparently.)
Being able to print the resulting .pdf file is more common.
