Loading...
Pages: [1] 2   Go Down
Author Topic: Doppler Speed Radar  (Read 1900 times)
Offline Offline
Newbie
View Profile
Hi. I just started with Arduino last week and am loving it so far.
For this project, I'm trying to build a simple speed radar and am at a sticking point. Would love some help.
The sensor is a 10.525 GHz X-band doppler sensor: http://docs.microwave-solutions.com/createPdf.php?id=MDU1720
It outputs the doppler shift frequency.
I'm using an LM386 to amplify the signal with a gain of 200: http://www.ti.com/lit/ds/snas545a/snas545a.pdf (page 5, top right)
I've adapted my code from this tutorial's main code. And the second code example here.
My code currently looks like this:
Code:
// These are the counts needed for 250 msec interrupt
// using the timer prescaler settings set to 128.
const uint16_t TICK_CNT = 34286; // 65536-(16MHz/128/4Hz)
static uint16_t freq = 0;
double sped = 0; //"speed" seems to be a reserved term
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  noInterrupts();                     // disable all interrupts while we configure
  // init Timer1 - 16-bit timer/counter
  TCNT1   = 0;                                  // start count at zero.
  TCCR1B  |= _BV(CS12) | _BV(CS11) | _BV(CS10); // Increment T1 input on each positive edge
                                                // using an external source. Table 16-5, pg 139.
  // init Timer2 - 8-bit timer/counter
  TCNT2   = TICK_CNT;                 // preload Timer2 to interrupt every 250 msec
  TIMSK2  = _BV(TOIE2);               // enable the Timer2 overflow interrupt
  TCCR2B  |= _BV(CS22) | _BV(CS20);   // init clock prescaler to 128. Table 18-9, page 164.
  interrupts();                       // enable all interrupts
  Serial.println("Ready...");
ISR(TIMER1_OVF_vect) {
  // do nothing. this is just a dummy ISR in case it actually overflows.
  Serial.println("Inside Timer1 Overflow Interrupt.");
ISR(TIMER2_OVF_vect) {
  //Serial.print("TCNT1: ");
  //Serial.println(TCNT1);
  freq = TCNT1;
  //Serial.println(freq);
  TCNT1 = 0;
  TCNT2 = TICK_CNT;
  if (freq != 0) {
      freq = freq << 2;      // multiple the frequency * 4 (using leftshift 2 places). 250ms*4 = 1 sec.
      sped = freq * .03225;  // multiplying freq * 0.0325 will give speed in mph. 31Hz == 1 mph.
                             // see: http://www.microwave-solutions.com/contents/en-uk/d13_System_Design.html
      Serial.print("Freq: ");
      Serial.print(freq, DEC);
      Serial.print(" Hz, Speed: ");
      Serial.print(sped, 3);
      Serial.println(" mph");
I've found that the only pin that gives any output when the output of the amplifier is connected to it is Digital pin5. (I'm not sure why this is, and would love to know.)
When I wave my hand in front of or near the sensor, my output looks like this:
Code:
Ready...
Freq: 4 Hz, Speed: 0.129 mph
Freq: 16 Hz, Speed: 0.516 mph
Freq: 64 Hz, Speed: 2.064 mph
Couple of questions:
1. Why Digital Pin 5? I thought it would've been one of the analog pins.
2. I'm pretty sure I'm waving my hand faster than 2mph. Why does my output give such low speeds? When I hook up my multimeter, set to Hz, to the output of the amplifier, I'm getting readings > 100 Hz when I wave my hand. (I also get a standing frequency of 100Hz when connected to the output and 60Hz with just the ground connected and the positive floating in the air.)
3. From my understanding of what the code is supposed to be doing, it has set Timer1 to count rising edges from an input. Timer2 has been configured to wait 250ms, then interrupt and read the # of pulses into freq variable from Timer1, reset Timer1 back to 0, and preload to interrupt again in 250ms. Is my understanding correct?
4. Is there something wrong with my TICK_CNT (preload amount) and prescaler selection that is causing me to not count all of the pulses?
Thanks in advance!
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
One problem is that you don't set freq back to 0 after you display the speed.  This causes a count of 1 to be reported as 4, 16, 64.
It would be good to check Timer2 to see that it is actually triggering every 250 milliseconds.
Logged
Offline Offline
God Member
View Profile
When checking the speed it would probably be better to use something metallic to wave at the sensor to give a better reflection of the signal.
Pete
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
I changed the sketch to increment freq in the Timer2 ISR and ran for 10 seconds.  Got 245.1 interrupts per second, not 1 interrupt every 250 milliseconds (4 interrupts per second).  That's why your frequency counts are so low.
Logged
Offline Offline
Newbie
View Profile
Thanks for the replies.
Of course, after I posted, I realized that Timer2 is an 8-bit timer, not a 16-bit timer.
That means that my TICK_CNT is incorrect.
Now, I'm looking at 255-(16Mhz/1024/62Hz) for roughly 3 as a TICK_CNT preload.
Of course, this means I'm interrupting 62 times per second instead of 4, but 62 was the smallest number that I could work out where the TICK_CNT wasn't negative and it was close to a whole number. Maybe I'm thinking about this the wrong way though because it means I need to multiply the number of counted pulses by Timer1 by 62 in order to get an estimate of the speed.
The maximum speed that I'm looking to capture would be 200 mph. That means 31Hz * 200 = 6200 Hz, which should still be able to be captured even if I'm interrupting 62 times per second. Right?
Updated sketch:
Code:
const uint16_t TICK_CNT = 3; // 255-(16MHz/1024/62Hz)
  TCCR2B  |= _BV(CS22) |_BV(CS21) | _BV(CS20);   // init clock prescaler to 1024. Table 18-9, page 164.
  freq = TCNT1;
  TCNT1 = 0;
  TCNT2 = TICK_CNT;
  if (freq != 0) {
      freq = freq * 62;      // multiple the frequency * 4 (using leftshift 2 places). 250ms*4 = 1 sec.
      sped = freq * .03225;  // multiplying freq * 0.03225 will give speed in mph. 31Hz == 1 mph.
      Serial.print(sped, 0);
      freq = 0;
Updated output: Looking better!
Code:
Ready...
Freq: 62 Hz, Speed: 2 mph
Freq: 310 Hz, Speed: 10 mph
Freq: 186 Hz, Speed: 6 mph
Freq: 248 Hz, Speed: 8 mph
Freq: 124 Hz, Speed: 4 mph
Freq: 434 Hz, Speed: 14 mph
Freq: 992 Hz, Speed: 32 mph
Freq: 496 Hz, Speed: 16 mph
Freq: 372 Hz, Speed: 12 mph
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Doppler will only give you speed along the radar beam relative to the emitter. Waving your hand across the beam won't give you much frequency change. Wave you hand at the emitter instead.
Logged
Examples can be found at Learning in the Main Site and at the Playground
Offline Offline
Newbie
View Profile
Thanks. FWIW, that's what I am doing.
Logged
Offline Offline
Newbie
View Profile
Just wondering, is this the full code?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Hi, Just wondering, is this the full code?
The sketch compiles so it is probably complete.
Logged
Offline Offline
Newbie
View Profile
Ok, in this coding,where the code indicates signal come from.....?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
It's using the pulse counting feature of Timer/Counter 1.  That would be the signal called "T1" which on the ATmega328P is pin 5 of  Port D.  Arduino calls it Pin 5.
Logged
Offline Offline
Newbie
View Profile
i see......but i thought he want to analyse doppler frequency.so,instead analyse doppler frequency, is he analyse frequency by generates pulse from timer?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You can measure frequency by measuring pulses per unit time (or time per pulse).
Timer/Counter1 is counting pulses.  Timer/Counter2 is interrupting 62 times per second.  Each time Timer/Counter2 interrupts he grabs the count from Timer/Counter1.  Multiply that by 62 to get counts per second: frequency.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Is there somewhere that he is subtracting frequency of output to that received?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
That's usually already done in the mixer within the module.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Pages: [1] 2   Go Up
Print
Jump to:
