Topic: Doppler Speed Radar (Read 44924 times) previous topic - next topic
GoForSmoke
Maybe some day I'll be able to listen to objects move again. It's a wonderful experience.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
dattasaurabh82
umm, Is there any way of putting the velocity at 0 mph when not detecting anything? Cause here(when I experimented with it) when I did not move my hand, it still showed 2 mph & that's not acceptable in some cases.
AWOL
What is the "it" of which you speak?
wwbrown
Russ,
If I can ask what did you pay for the MDU1720 modules and where did you get them?
Thanks
wade
dattasaurabh82
I'm staying in India & I got is in handy:
http://www.sunrom.com/sensors/speed/microwave-doppler-radar-sensor-for-motion-and-speed-sensing
Obviously I'm talking about the speed that get's printed in serial monitor.
GoForSmoke
Try testing with something that has no moving parts, like a cardboard box. With doppler a car with running engine 'moves' just by the vibration of the body.
dattasaurabh82
It's with the timer 2, that's for sure. But before I make the initial values as 0mph, I need an expert opinion on this & a better way of doing this.
& showing 2mph for a static body's sort of absurd. But that's mathematics going in there.
I confused myself on this. Just started studying Timers
dattasaurabh82
Is there a way of increasing the range of the Doppler radar? As in the data sheet of the Doppler radar(that I bought from an Indian market) shows a maximum sensing range of 20ms . But when I tested it on road, it gave me hardy1.5-1.8ms sensitivity. The parallex X-band sensor have a range 2.4-9m approx. I need to increase the range of my Doppler since I cannot get a parallex model whose sensitivity range can be controlled with a trim pot.
GoForSmoke
Can you give it more power?
Also what you reflect from, smooth metal is best and for testing a corner reflector will send the most back. If you take a box and cut so there are 3 sides together making a corner then line the inside of that with smooth foil (try not to wrinkle) you will have a cheap corner reflector. Make it not small. Even if the reflector is not pointing directly at the source, the geometry will send the waves back. It works with light, it should work with radar.
Last is movement. The object must move relative to the radar either toward or away though sideways can be mixed in.
dattasaurabh82
No 5 volts is maximum. & currently, since I'm using it for vehicle speed measurement, you can expect the worse conditions. Any type of vehicle's surface from Indian Roads shall be the reflecting surface.
cshsss
Hello everyone.
I am a Korean. I am interested in radar system.
I made Radar system. However, I encounter the serious problems.
If I start the below source code, it always have speed 60 Hz, Speed 840[m/s]
I am thinkg about this problems. In my opinion, whenever the counter happened, freq is not zero.
So freq has always 1.
If you have any solution, please help me.
X-tal : 8000000 Hz
TICK_CNT                   // 255-(8000000/1024/60) = 126
The interrupt has happened 60 times / 1 seconds
Code============================================
static unsigned int freq = 0;
static double speed = 0;
// timer0 : 8bit    as timer
// timer1 : 16bit   as counter
#pragma vector = TIMER0_OVF_vect              //off time
__interrupt void Timer0_Interrupt(void)
    freq = TCNT1;                               // edge clock count
    TCNT1 = 0;                                   // edge clock counter init.
    TCNT0 = 0x1C;                             // Timer init
   if(T2_Timer > 0) T2_Timer--;     // Use external Timer
#pragma vector = TIMER1_OVF_vect              //counter
__interrupt void Timer1_Interrupt(void)
void main( void )
    System_init();
    Delay_ms(100);
    Radar_Pulse_Enable();
    Delay_ms(10);
    TCNT1 = 0;
    TIMSK = 0x05;
    while(1)
        if(freq > 0)        // when the radar detect any product
            Radar_Pulse_Disable();
            freq = freq*60;                 // 60 interrupta per seconds
            speed = freq*0.014;         // unit [m/s]
            UART_String_Transmit(" Freq : ");
            Tx_HOST_Printf("%d[Hz]",freq);
            UART_String_Transmit(" Speed : ");
            Tx_HOST_Printf("%0.3lf[m/s]", speed);
            Tx_HOST_Char(LF);
            Tx_HOST_Char(CR);
             memset(Printf_Buff, 0, PRINT_BUF_SIZE);
             memset(com1_rx_data, 0, RX_BUF_LENGTH);
            freq = 0;   //reset
AWOL
#26
Mar 26, 2015, 08:41 am Last Edit: Mar 26, 2015, 08:41 am by AWOL
What's your local mains frequency?
Please remember to use code tags when posting code.
cshsss
Hello, This is the first time to write this web-page.
So, Could you tell me the code tags??
And, I use 10.525GHz radar(HB 100).
Thanks.
GoForSmoke
#28
Mar 26, 2015, 10:50 am Last Edit: Mar 26, 2015, 10:51 am by GoForSmoke
Thanks.
Quote this post and you will see this text inside of code tags.
You will also see this whole post and your post inside of quote tags, all html.
ayih94
hi, i'm new to this forum. I want to ask it is possible to have two hb100 microwave sensor to work on one arduino board? im using the sensors to detects car speed. if it is possible how do i assign which pins to use for  each sensor?
