Author Topic: read two values  (Read 242 times)
Hi  guys
Im trying to control 2 stepper motors using the function read().
I must give in serial monitor 2 values , one for each motor ,and they must move to the specified angle (go-to mode). My code  doesn't seem to  work...
im a terrible  programmer smiley-red  , so  pleaaaaase  have patience..
if (buttonState == HIGH) {
     Serial.println("GO-TO MODE");
    // send data only when you receive data:
        if (Serial.available()) {
                // command to stepper1
                 stepper1.step(Serial.read());
              Serial.println(" stepper1:");
              Serial.print(Serial.read());
                  Serial.println("stepper 2");
                // command to stepper2
                 stepper2.step(Serial.read());
              Serial.println(" stepper2:");
                  Serial.println("end go-to  mode");
    buttonState == LOW;
Seattle, WA USA
Seattle, WA USA
There is no function read(). There are several classes that have read() methods. I'm being picky here, because it is important to know which class' read() method you are trying to use.
Stepper motors do mot move to specific angles. They step a specified number of times. If you compute the correct number of steps, the stepper motor will rotate to the correct position.
You know that there is serial data available. What are you waiting for?
Serial.read() reads one byte. It is unlikely that the character/byte you read is the number of steps to step. What is sending the serial data?
You checked that there was at least one byte to read. You read that one byte. Now, you are reading and printing another byte. Why?
Reading serial data pops the value off a stack (effectively). It is no longer available to be read again.
    buttonState == LOW;
This is performing a (useless) comparison, not an assignment. You probably don't need to do this, since you (presumably) assign buttonState a new value when loop() executes again.
so ... my code is crap smiley-zipper expecting this...
actually go-to mode is one of the modes im using activated by a switch. So it seemed logic to  wait  so there is time for the previous action to be completed.
I didn't know that.So how can i read an integer positive or negative , and maybe read 2 of them ?since we are talking about to steppers.Maybe with a "," semicolon separator? And how can i assign these two numbers to  2 variables so i can use them in   stepper1 and stepper 2?
 stepper1.step(variable1);
 stepper2.step(variable2);
Seattle, WA USA
Seattle, WA USA
OK. But, if that is truly what you want to do, you would wait whether there was serial data or not.
The sending application needs to add start and end markers to the packet. If the sender sends something like "<25, -100>", then code like this can read the data:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
       break;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Where it says "Process the packet", strtok() can be used to get the two tokens ("25" and "-100") and atoi() can be use to convert the tokens to numbers (25 and -100) that can be passed to the step() methods.
THANK YOU!(did not understand well the code, but.... )
so you mean something like
strtok( inChar, "," ) ;
int step1 = atoi(inData[1]);
int step2 = atoi(inData[2]);
Seattle, WA USA
Seattle, WA USA
No. The code I posted collects the data in the array called inData. That array is what strtok() parses. Did you look at the strtok() documentation? If you had, you would see that it returns a pointer to a token. It is that pointer that gets passed to atoi().
actually i  did... I didn't understand many things though...   Im trying here, ok?
So
strtok( inData, "," ) ; is the first command
 now what i must put into atoi?
Seattle, WA USA
Seattle, WA USA
So
No. The strtok() function returns a value. You are throwing the result away.
int step1 = 0, step2  =0;
char *token = strtok(inData, ",");
if(token)
   step1 = atoi(token);
   token = strtok(NULL, ",");
   if(token)
      step2 = atoi(token);
// Now, you can use step1 and step2.
to  test the code
#define SOP '<'
#define EOP '>'
bool ended = false;
char inData[80];
byte index;
int k;
int i;
   // Other stuff...
    pinMode(13, OUTPUT);
  Serial.println("test");
  delay (1000);
    if(inChar == SOP)
       index = 0;
       started = true;
       ended = false;
       ended = true;
       break;
      if(index < 79)
        index++;
if(token)
   k = atoi(token);
   if(token)
// test with led13
for (i=0; i<k; i++){
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
    started = false;
    ended = false;
    index = 0;
although it compiles fine the led doesn't blink.... Am i missing something?
PS i changed the baud rate because freezes my serial motitor
« Last Edit: February 14, 2012, 11:29:32 am by pyrforos » Logged
Seattle, WA USA
Seattle, WA USA
Debug output.
sorry, no idea how to do that ..
could you please help me out?
« Last Edit: February 14, 2012, 12:53:08 pm by pyrforos » Logged
Seattle, WA USA
Seattle, WA USA
Serial.print("Some name: ");
Serial.println(someVariable);
ok if i modify the code like so
#define SOP '<'
#define EOP '>'
bool ended = false;
char inData[7];
byte index;
int k;
int i;
   // Other stuff...
  Serial.println("goto mode");
  delay (1000);
    Serial.println(inChar);
    if(inChar == SOP)
    {Serial.println("SOP");
       index = 0;
       started = true;
       ended = false;
    {Serial.println("EOP");
       ended = true;
       break;
      if(index < 7)
        Serial.println("(index < 7)");
        index++;
if(token)
   k = atoi(token);
Serial.println(k);
   if(token)
     Serial.println(step2);
 Serial.println("led-loop");
    started = false;
    ended = false;
    index = 0;
and insert   4,2
i get
goto mode
goto mode
4
(index < 7)
(index < 7)
2
(index < 7)
Seattle, WA USA
Seattle, WA USA
You are supposed to send "<4,2>", not "4,2". The < and > are what the program uses to see that a packet started and ended.
feeling sooo stupid.. Thanks one more time PaulS..
Works fine
