Topic: Problem in CODE for WiShield v1.0 (Read 3564 times) previous topic - next topic
Nishant_Sood
Feb 16, 2012, 10:04 am Last Edit: Feb 16, 2012, 10:07 am by NI$HANT Reason: 1
This the Simple Server code:
* A simple sketch that uses WiServer to serve a web page
#include <WiServer.h>
#define WIRELESS_MODE_INFRA 1
#define WIRELESS_MODE_ADHOC 2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,1,2}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
const prog_char ssid[] PROGMEM = {"ASYNCLABS"}; // max 32 bytes
unsigned char security_type = 0; // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"12345678"}; // max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, // Key 0
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 1
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 2
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 // Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
// End of wireless configuration parameters ----------------------------------------
// This is our page serving function that generates web pages
boolean sendMyPage(char * URL) {
   // Check if the requested URL matches "/"
   if (strcmp(URL, "/") == 0) {
       // Use WiServer's print and println functions to write out the page content
       WiServer.print("<html>");
       WiServer.print("Hello World!");
       WiServer.print("</html>");
       // URL was recognized
       return true;
   // URL not found
   return false;
 // Initialize WiServer and have it use the sendMyPage function to serve pages
 WiServer.init(sendMyPage);
 // Enable Serial output and ask WiServer to generate log messages (optional)
 Serial.begin(57600);
 WiServer.enableVerboseMode(true);
void loop(){
 // Run WiServer
 WiServer.server_task();
 delay(10);
These are the problems im facing:
SimpleServer.cpp.o: In function `loop':
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:74: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:74: undefined reference to `Server::server_task()'
SimpleServer.cpp.o: In function `setup':
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:64: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:64: undefined reference to `Server::init(unsigned char (*)(char*))'
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:68: undefined reference to `Server::enableVerboseMode(unsigned char)'
SimpleServer.cpp.o: In function `sendMyPage(char*)':
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:50: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:51: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:52: undefined reference to `WiServer'
SimpleServer.cpp.o:C:\Users\nishant\AppData\Local\Temp\build6414769034696593230.tmp/SimpleServer.cpp:52: more undefined references to `WiServer' follow
what possibly could be causing this, i have checked the functions in the WiServer.h things seem pretty much ok, have a copy of WiServer.h as an attachment.
However i got this working pretty much fine:
* Web Server
* A simple web server example using the WiShield 1.0
#include <WiShield.h>
#include "WiServer.h"
//#include "wiring.h"
//#include "Arduino.h"
//#include "Wiserver"
unsigned char local_ip[] = {192,168,137,5}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,137,4}; // router or gateway IP address
const prog_char ssid[] PROGMEM = {"WinacroWii"}; // max 32 bytes
// WEP 128-bit keys
// sample HEX keys
unsigned char wireless_mode = WIRELESS_MODE_ADHOC;
WiFi.init();
// This is the webpage that is served up by the webserver
const prog_char webpage[] PROGMEM = {"HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<center><h1>Hello World!! I am WiShield</h1><form method=\"get\" action=\"0\">Toggle LED:<input type=\"submit\" name=\"0\" value=\"LED1\"></input></form></center>"};
WiFi.run();
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
johnwasser
For some reason your compile is finding WiServer.h but not the library containing WiServer.cpp.
It's not clear if the library should be named WiShield or WiServer.  If the only include file is called WiServer it may be necessary to name the library WiServer.  Perhaps WiShield.h should be included before WiServer.h?  Very confusing.
Nishant_Sood
Hi John , WiServer and WiShield are two separate libraries existing in the same repository and also both WiServer and WiShield cpp files are also there , Arduino 1.0 problem it seems
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
johnwasser
I think Arduino 1.0 finds the libraries to build by matching .h filenames to library folders.  I suspect the library folder is called "WiShield" and not "WiServer".  Perhaps if you added a "#include <WiShield.h>" before the "#include <WiServer.h>" it would build and link the full library.
Nishant_Sood
Now im using the Arduino IDE version 0022 and now i get the following error's:
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:74: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:74: undefined reference to `Server::server_task()'
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:64: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:64: undefined reference to `Server::init(unsigned char (*)(char*))'
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:68: undefined reference to `Server::enableVerboseMode(unsigned char)'
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:50: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:51: undefined reference to `WiServer'
C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:52: undefined reference to `WiServer'
SimpleServer.cpp.o:C:\Users\nishant\AppData\Local\Temp\build2704773252878641827.tmp/SimpleServer.cpp:52: more undefined references to `WiServer' follow
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
Got the code compiling with 0022 but with Arduino 1.0 still facing the following:
D:\Removable Disk\arduino-1.0\libraries\WiShield\WiServer.cpp:212: error: prototype for 'void Server::write(uint8_t)' does not match any in class 'Server'
D:\Removable Disk\arduino-1.0\libraries\WiShield\/WiServer.h:198: error: candidate is: virtual size_t Server::write(uint8_t)
never mind im using the 0022 to work with WiShield but to sharpen concepts it should be known that why this is causing problems in Arduino 1.0, Any one comes to know , Please make me understand as well!
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
SurferTim
I have not looked at the shield code, but there were some changes made to the v1.0 ethernet shield write functions. The function that accepted a zero-terminated string was no longer in the library.
Instead of "Server.write(MyString)", try "Server.write(MyString, strlen(MyString))".
fresheStF
#7
Mar 08, 2012, 02:16 am Last Edit: Mar 08, 2012, 02:34 am by fresheStF Reason: 1
Did anyone find a fix for the two errors NI$HANT reported? I'm getting the same errors when compiling the SimpleTweeter example. I tried SurferTim's suggestion but it just yielded more errors. I'm using Arduino 1.0.
Changing (in WiServer.cpp):
void Server::write(uint8_t b)
to
void Server::write(uint8_t b, strlen(uint8_t b))
Gave these errors:
C:\Desktop\arduino-1.0\libraries\WiShield\WiServer.cpp:212: error: 'strlen' is not a type
C:\Desktop\arduino-1.0\libraries\WiShield\WiServer.cpp:212: error: prototype for 'void Server::write(uint8_t, int (*)(uint8_t))' does not match any in class 'Server'
C:\Desktop\arduino-1.0\libraries\WiShield\/WiServer.h:198: error: candidate is: virtual size_t Server::write(uint8_t)
Nishant_Sood
#8
Mar 08, 2012, 05:47 am Last Edit: Mar 08, 2012, 05:50 am by NI$HANT Reason: 1
If you refer to my above post as i quoted (look above for it in details) you will get to know that i solved the problem long time ago, please look above to solve these problems and use 0022 IDE not Arduino 1.0 it has some code problem's.
EDIT:
You just need 2 things to care here about:
1) Use 0022 Arduino IDE.
2) Replace the apps-config.h with the one i provided you in the attachment.
further you may contact me on nishant@winacro.com if you aren't able to make it work.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
fresheStF
The apps-conf.h file you attached isn't any different than the one I already have with the 1.0 version. I'm still getting the same two errors.
Nishant_Sood
#10
Mar 08, 2012, 03:04 pm Last Edit: Mar 08, 2012, 03:06 pm by NI$HANT Reason: 1
I'm assuming you checked the file i sent but didn't used the 0022 IDE
The apps-conf.h file is not related with 1.0 version its just this that the way Arduino 1.0 IDE deals with the WiShield library is different the 0022 IDE deals with the same. so please use 0022 IDE with this WiShield implication. first try with 0022 IDE then if things are fine then in that case put the same code in IDE 1.0 and try to sort out things there.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
garcara
I think you need to go into Server.cpp and change this:
to this:
PaulS
I think you need to go into Server.cpp and change this...to this...
You do, but you also need to add a return statement at the end of the function to return the number of bytes actually written.
