Author Topic: Servo  (Read 185 times)
Wales
Don't take things too seriously
I'm trying to use a servo to jingle a bell directly attached to the servo.
In my code I do a variation on this:-
  press1 = digitalRead(button1);
  if (press1 == LOW)
    servo1.write(160);
  else {
    servo1.write(20);
Q1. How do I know the extremities of my servo? I've looked at the datasheet but I couldn't see any information there. I had to modify the above writes of 160 and 20 to other values before the servo was happy and didn't sort of hum or get stuck. I've also found I could make a bigger movement by increasing the 160 value - but how do I know where to stop?
Q2. If I use the code without a delay (which I cannot have in my project) then the servo darts only half way across the distance it would if there was a delay. Is there a way to get it to only begin moving back when it's reached the destination? Or do I have to use a millis style delay? Ideally, is there a library or function that would help with this?
Q3. Sometimes the servo chatters or moves a tiny bit independently of anything it's told to in the code. Is this normal for a cheap servo? Also, when powered from a battery it doesn't work as well as when powered from USB. This is with a brand new 9v battery. Confusing.
THANKS
UK
Q1: Use zoomkat's code to figure out the limits.
Q2: The servo library can only command the servo to a position, but it cannot know when it gets there (and servo slew rates vary), so yes, either a delay, or have a look at blink without delay to see how to eliminate delays.
Q3: Please don't encourage 9V battery proliferation. Get a proper supply.
Wales
Hi AWOL, thanks very much for answers A.1-2. I'll see if I can find the zommkat code.
A.3, not so much.   (doesn't consider what is happening and why, just states an opinion) smiley-grin smiley-razz
« Last Edit: February 17, 2012, 09:35:05 am by Dane » Logged
Code you can use to test your servo limits.
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
put in key search words,
