Loading...
Pages: 1 [2]   Go Down
Author Topic: Magnetic reader  (Read 1218 times)
Offline Offline
Newbie
View Profile
thanks a lot for the reply, in this project I've to use a magnetic head, not a pre-built reader so I'll have no clock data but that on the track itself, the encoding that I'll be dealing with (when I'm able to retrieve the F2F signal and the binary from that) is the ABA of the middle track of a credit card, however I've assemble the circuits on this forum and the one of this application note:
http://www.eettaiwan.com/ARTICLES/2001OCT/PDF/2001OCT04_AMD_CT_AN2112.PDF
However with both I'm having problems, the first (the one on this forum) the output changes from 0 to 1 even though I'm not swiping and when I pass the card it does nothing, the second one stays low all the time, and the voltages that I get are not the ones for the stable state presented in the app note, but I've built it three times from scratch with the same result every time
My magnetic head is working 'cause if I swipe it i can see the signal after amplification, however I'm unable to transform that signal to a F2F encoded wave smiley-sad
any help??
thanks a lot
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
comparator has a retro to the (-)input
What does that mean?
The circuits in that PDF had no component parts, so you draw a schematic of what you actually are trying to build with real components.
Quote
Looks like you keep making the same mistake then.
Logged
Offline Offline
Newbie
View Profile
Hi i meant the comparator of the circuit that was posted here on the topic, it's the second post, as far as for the PDF I know it has no components, but I assemble it with real components and it doesn't work, I don't know what can be wrong since it's just amplifiers and comparators, and i test each of the part separately and all is working it's just that it doesn't give the voltages for the steady state that the pdf shows, and I think that i can wire it fine, so I don't know what can be =S
Of the other circuit that i mention (the one posted here) if you check it the comparator has a wire from the (-) input to the output through a resistance, that's what i call retro and on a comparator I have never seen one (at least that I remember)
Thanks again smiley
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Never heard it called that before.
Quote
Yes it is used to control the hysteresis of the comparator.
Quote
Yes that is why I was asking for the schematic of what you are trying to make with real components an part numbers to see if you had made a mistake with the conversion into a real circuit. There could be a problem with the type of op amp you are using, the feedback components or anything, but just saying it doesn't work is not very conducive to trying to find out what is wrong.
Basically it is a digital circuit but made with analogue blocks of that anadigm device. So you could just as easily do it in the digital domain.
I suspect however that you are not even getting a signal out of the first amplifier, do you have a scope you can measure things with?
Logged
Offline Offline
Newbie
View Profile
I've made the schematic and there is the output after i swipe the card:
0
0
8
20
6
11
687
4
14
16
1
6
2
449
667
91
12
642
547
528
179
449
1
2
11
52
485
10
344
3
447
295
7
4
413
14
6
359
477
447
2
280
445
402
476
1
174
325
359
443
406
1
8
1
409
403
3
372
175
251
1
322
8
386
350
296
428
232
419
183
22
400
279
25
322
355
373
347
432
326
1
22
2
is this acurate? and if it is, how can i convert it to binary code?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
is this acurate?
How can anyone tell? What is the number supposed to be on the card?
Quote
It is already in binary, that is how it is stored in the computer. When you print it out it is converted to decimal.
Exactly what do you want to do with the number? If it is just to print it the look at the serial.print in the reference and see what you need to add to get it to output in binary.
Logged
Offline Offline
Newbie
View Profile
Do you think that is better to use a ADC IC instead of LM393 comparator?
Logged
Offline Offline
Brattain Member
View Profile
WWW
for what? you haven't said what circuit you have, generally though no.
Logged
Offline Offline
Newbie
View Profile
Using the schematic above, i think is better if i will use a ADC instead of LM393 comparator.
Logged
Offline Offline
Brattain Member
View Profile
WWW
No because what you need here is a comparator to detect a threshold value or not.
All an A/D will give you is a number that you will have to compare against to get a binary value. The same effect can be had by simply varying the gain of the amplifier.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
