Loading...
Pages: [1]   Go Down
Author Topic: PWM frequency problem  (Read 397 times)
Offline Offline
Newbie
View Profile
Hello,
I just bought an arduino mega ADK, and a couple of motors, http://www.robot-electronics.co.uk/htm/emg30.htm,
I want to control the speed of those motors with PWM but it seems that I can't change the PWM frequency, So is there any library that can help me here.
I'm using L298 for motor interfacing.
I have another issue, is it a problem to power the arduino from the PC while controlling motors.
thanks
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Why do you feel you need to change the PWM frequency?
You can power the Arduino from the same 12v source as your motors.  Connect +12v to the Vin pin or to the DC power jack.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
But the normal caveat applies - if your supply isn't able to supply the motor's max current requirements the Arduino will likely crash.  Also you want to be sure there are no high voltage spikes on the supply that might overload the Arduino's regulator.
As for PWM frequency I don't think there's a specific library but it can be done by reprogramming the relevant timer module directly.  If you want millis() and micros() to still work don't modify timer0.
Logged
Offline Offline
Newbie
View Profile
I used to work with PIC microcontroller and I used to test the best frequency that work with the motor cause it seemed to me through my personal experience that every motor has a specific pwm frequency that works great with it
I didn't want to do that, I don't know exactly how much current the motor will require and I don't know the max current that the 5v regulator in my arduino will support. I'm really new with arduino  smiley-confuse
I searched in the arduino site but I can't find any data sheet of arduino Mega ADK can you give me a link please.
Thank you all for your help.
Logged
Offline Offline
Jr. Member
View Profile
the jeremy blum arduino tutorial on youtube on motors and PWM might be of use too you.
Logged
Offline Offline
Newbie
View Profile
Thank you for your suggestion, I found his tutorial very interesting and amusing, and I think I found what is my problem, I didn't wire the arduino GND to the L298 GND so the the motor and the arduino don't have the same reference. I will try that as soon as I get to the lab tomorrow,
Logged
Offline Offline
Newbie
View Profile
Thank you all for your help, the Motors work great
Logged
Pages: [1]   Go Up
Print
Jump to:
