Topic: NTP Alarm Clock (wifi) (Read 7513 times) previous topic - next topic
boelle
I have been thinkering with the idea and did a search but seems nobody has done it before
how would be the most pratical way to do it with as less hacking as possible? i guess a wifi shield and either a LCD or LED display and then a arduino board...
maybe a small solar cell and a 9V rechargeable battery
but hit me with ideas
jwatte
I would add a DS3232 or similar temperature-compensated real-time-clock. The ChronoDot is a good example device to do this.
Then I would set it up so it's mostly in sleep mode, to save power. You can use the ChronoDot to wake up when needed.
The NTP only needs to sync the real-time clock every once in a while -- say, every hour would be plenty.
I don't like 9V batteries for power. They aren't generally rechargeable, and you have to "burn off" half of their energy to regulate down to 5V.
Try a LiPo battery at 3.7V. You may be able to drive the Arduino directly (at 3.3 Volts) or use a boost power regulator to get to 5V. It's also rechargeable.
The biggest question is the user interface. How would you enter the 64 hex digits of the WiFi security key so the clock can connect to the network?
liuzengqiang
For the sake of everyone that is reading, Network Time Protocol (NTP). I didn't even know what that was. I bet I'm not alone. If are using LCD or LED, any reasonable operating time would need an AC adapter. I would not use a battery. The real time clock can use a backup battery.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
jwatte
LCD watches run for years on a single coin cell battery. Typically powered by something less draining than an AVR microcontroller, to be sure, but it's the backlight that's the real drain. With a solar cell, and a solar battery charger, you can probably run the clock for a long time without AC.
A LiPo rider, plus a battery, plus a solar cell, will probably run about $30 or so. Seeedstudio has one: http://www.seeedstudio.com/depot/lipo-rider-p-710.html?cPath=155
boelle
good point... my first answer would be when programming... seems the most easy way
boelle
but yeah backup battery in some way is needed...but as an alternative i would go for a lipo pack (thanks for pointing out the 9v to 5v issue)
letting the wifi module sleep and only having it powered for the time it takes to sync every hour or so, would help preserve battery time. so during the daytime it can charge
to keep interface simple 3 push buttons. 1 held down when setting the alarm time and the 2 others advance hours and mins. hitting the first button for less than X secs could kill an alarm.
could the arduino not handle the charging?
jwatte
The Arduino is not a charging controller. It cannot provide enough current, for one. You can probably use a sense resistor to an analog in and some switchable external circuitry to properly manage the charging of the battery, but then you have to keep the Arduino on more, which draws more power.
If you start with a wall wart version, you can add the battery stuff later, perhaps...
boelle
yeah, there are ups and downs to it all, but what i had i mind was a small alarm clock that you could place anywhere in the house. Of course for the solar cell idea to work right it was to stay in a room with enough light during the daytime.
using lipo (below 5V) is a resistor relly needed, i mean can the ADC input not handle up to 5V ?
a transistor of course to "disconnect" the solar cell when there is enough charge on the battery...
just thinkering with a hardware list:
Arduino  board
Wifi Shield
Lipo battery pack
Pizo speaker
LCD Display
3 Push Buttons
1 Transistor
Solar Cell
Small Transparent Case
florinc
Quote
That is maybe because it is not very practical.
An DS3231 keeps a very accurate time (+/- 1 minute a year at a stable room temperature), you may need to synchronize it once a year. Why pay $50 more for a WiFi shield used just to get the time once on a while?
BTW, you can also get the time from GPS. Price would be in the same range (as the WiFi module), but handling it would be much easier (no network configuration, less string parsing (TinyGPS lib is already written, tested and available)).
unhappyelf
Quote
Also the GPS could be used to determine DST in the area your currently in.
florinc
Quote
Arduino  board
Wifi Shield
Lipo battery pack
Pizo speaker
LCD Display
3 Push Buttons
1 Transistor
Solar Cell
Should also add the LiPo charger to the list.
boelle
then it't limited to where it can view sat's surfing the sky....
boelle
so can NTP  :smiley-eek:
boelle
#13
Feb 20, 2012, 11:33 pm Last Edit: Feb 20, 2012, 11:38 pm by boelle Reason: 1
thats what the solar cell is for ? solar cell has to match a single lipo cell (max 4,2 V)
florinc
Quote
I thought so too. But apparently not true. Unless you use your clock (with GPS) in a Faraday cage.
It works just fine in my normal house, away from the window.
Quote
If it was that simple, there would be no need for chargers :)
Something would need to stop the charging when the battery is fully charged (so it does not explode). Among other roles.
