Topic: How to control the #define in a library? I mean... (Read 2609 times) previous topic - next topic
liuzengqiang
It's hard to describe in general terms so I'll use an example:
In a library I have a buffer. Its size should be the same as the width of the lcd. I have in the .h file:
#define phi_prompt_max_item_display_length 20
In the .cpp file:
char buffer[phi_prompt_max_item_display_length];
If someone uses a 40x2 LCD, I want to define phi_prompt_max_item_display_length as 40. I want the arduino sketch to be able to override the define in .h
I tried this in .h:
#ifndef phi_prompt_max_item_display_length      ///< Only define this if it has not been defined.
#define phi_prompt_max_item_display_length 20   ///< The render_list uses a buffer to render list item. 20 works for up to 20x4 displays to save SRAM.
#endif
I then have in arduino sketch #define phi_prompt_max_item_display_length 40 before it includes the .h
I get 40 in arduino sketch but I still get 20 in the library.
So are the define spaces separate between different .cpp files? How to do what I want to do? Thank you!
sixeyes
I'm not certain that you can do that given the way the Arduino build system works.
However if your library creates C++ classes, you could template the class, supplying the width of the LCD display as a template parameter.
Iain
robtillaart
You can add both - rows and colums - of the LCD as parameters of the constructor and malloc() the array.
Rob Tillaart
JChristensen
Evidently all great minds run in the same ruts XD
http://arduino.cc/forum/index.php/topic,92382.msg694031.html#msg694031
liuzengqiang
Thank you Jack! Seems like there is no simple solution as both of us initially experimented. I gather, every .cpp compiles separately. Without a make mechanism in arduino, such as define xxx as yyy in the make file, the only way to communicate with another .cpp is at execution time. I can add another parameter to my lib initialization to take a max_item_length parameter or just dare my lib users to change this define in the .h file.
sixeyes
Not so. C++ templates offer a compile time link.
Iain
liuzengqiang
Iain,
I am not familiar with the term C++ templates. I'm reading wiki and yes the concept does sound familiar after some reading. I need to read on. Would you be willing to show me a line or two pseudo code on passing a parameter to a template? Thanks.
Liudr
sixeyes
Does this help:
template <int length>
class Test
  int buffer[length];
  Test<20> shortLine;
  Test<40> longLine;
  Serial.println(sizeof(shortLine));
  Serial.println(sizeof(longLine));
Iain
liuzengqiang
