Loading...
Pages: [1]   Go Down
Author Topic: Serial Problems  (Read 234 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hallo
i have a compass that outputs uart data like that
Quote
$OHPR,21.2,2.3,-2.5,14.2,0.0000,370.48,-298.50,126.78,179.10,1.003,0.040,-0.043,1.002,-0.01*0C
$OHPR,21.2,2.3,-2.5,14.2,0.0000,370.47,-298.50,126.79,179.06,1.003,0.040,-0.043,1.002,-0.01*05
and i wrote this programm to capture them
Code:
while ( Serial.read () != '$' );
  BytesRead = Serial.readBytesUntil('*',SerialBuffer,127);
  for(Position=(BytesRead+1); Position<128; Position++)
    SerialBuffer[Position] = B0;
  for(Position=0; Position<128; Position++)
    OS4000Data[Position] = SerialBuffer[Position];
that works great
but when i copy the above to a bigger scetch
like that
Code:
  pinMode(3,OUTPUT);
  digitalWrite(3,HIGH);
  Serial.begin(UartBaudRate);
  Wire.begin(I2C_Address);
  Wire.onRequest(requestEvent);
  Wire.onReceive(ReceiveCommand);
  if (command == 'H')
    command = 'N';
    Capture_OS4000();
  else if (command == 'P')
    command = 'N';
  else if (command == 'p')
    digitalWrite(3,LOW);
    command = 'N';
  else if (command == 'R')
    Serial.write(27);
    delay(20);
    Serial.print("R");
    delay(20);
    CommandLow = Wire.read();
    CommandHigh = Wire.read();
    Command = ( ( (int)CommandLow<<8 ) | ( (int)CommandHigh ) );
    Serial.print(Command);
    Serial.write(13);
    command = 'N';
void  Capture_OS4000()
void ReceiveCommand(int howMany)
  command = Wire.read();
void requestEvent()
  Wire.write (OS4000Data, 127);
then the output is like that
Quote
OHPR,21.2,2.3,-2.4,14.6,0.0000,371.$OHPR,21.3,2.3,-2.4,14.6,0.0000,370.59,-298.45,126.93,179.31,1.003,0.041,-0.042,1.002,-0.01.ÿ
OHPR,21.2,2.3,-2.5,14.6,0.0000,370.40,-298.41,126.96,178.9$OHPR,21.2,2.3,-2.5,14.6,0.0000,371.01,-298.50,127.11,179.97,1.003,0.ÿ
OHPR,21.2,2.3,-2.5,14.6,0.0000,371.$OHPR,21.2,2.3,-2.5,14.6,0.0000,370.70,-298.69,126.98,179.11,1.003,0.041,-0.045,1.001,-0.01.ÿ
OHPR,21.2,2.3,-2.5,14.6,0.0000,370.76,-298.72,126.99,179.1$OHPR,21.2,2.3,-2.5,14.6,0.0000,371.11,-298.72,127.07,179.84,1.003,0.ÿ
OHPR,21.2,2.3,-2.5,14.6,0.0000,371.$OHPR,21.2,2.3,-2.5,14.6,0.0000,370.66,-298.63,127.00,179.10,1.003,0.041,-0.043,1.001,-0.01.ÿ
OHPR,21.2,2.3,-2.5,14.6,0.0000,370.73,-298.65,127.01,179.2.4,14.6,0.0000,371.15,-298.74,127.02,179.92,1.003,0.041,-0.042,1.001,ÿ
where i am wrong
thanks a lot
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
i changed the programm
so the slave always updates the OS4000Data
Code:
  if (command == 'P')
    command = 'N';
    command = 'N';
    Serial.write(27);
    delay(20);
    Serial.print("R");
    delay(20);
    Serial.write(13);
    command = 'N';
  Capture_OS4000();
void requestEvent()
and the master
Code:
void Read_Data()
  Wire.beginTransmission(2);
  Wire.requestFrom(2,127);
  Wire.endTransmission();
  for ( int i=0; i<128; i++ ) Serial.write(Wire.read());
  Serial.println("");
and its working
but how i will make to only do that
Code:
if that is completed
Code:
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
The for loop completes after iterating 128 times. If you want to do something after that happens, put the code after the for loop.
Code:
It takes exactly one NULL to terminate a string.
Code:
Why do you have two similar buffers? One would be enough. Do you have memory to waste?
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
the wire can't send a char string but only a byte string
and Serial can't buffer on a byte string but on a char
what else can i do?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Yes, Wire.send()/Wire.write() can send a char array, if you cast it properly.
A char and a byte are exactly the same size.
Code:
char buff[] = "Send Me!";
Wire.send((byte *)buff, strlen(buff));
Quote
Yes, it can, with the proper cast.
Code:
  byte stuff[10];
  int cnt = Serial.readBytesUntil('*', (char *)stuff, 10);
Logged
Pages: [1]   Go Up
Print
Jump to:
