Topic: COLOR SENSOR TCS 230 (Read 3705 times) previous topic - next topic
anatol
Hello,
I would like to use this color sensor to control RGB led... is it possible, can you help me?
thank you
robtillaart
What are your requirements?
What is the goal?
What do you mean by control?
Do you have a datasheet of the sensor?
Many things are possible unless they are in conflict with the laws of nature (and even those are broken sometimes)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
anatol
hello,
this is the data sheet of sensor: http://pdf1.alldatasheet.com/datasheet-pdf/view/96470/ETC/TCS230.html
My intentions is used 3 led (red,blue and green) or 1 led rgb and when the color sensor tcs230  finds a color the correspondent led switch on....
..is there an arduino code ready?
thank you
robtillaart
check - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1201940761 -
Rob Tillaart
anatol
thank you for reply, but I didn't find examples ready to test the sensor!!! :( :( :( :(
Grumpy_Mike
#5
Feb 20, 2012, 07:12 pm Last Edit: Feb 20, 2012, 07:17 pm by Grumpy_Mike Reason: 1
Quote
So you want someone to have already done the project for you and you just want to copy it, is that right?
Try:-
http://letsmakerobots.com/node/18533
or learn how to use google.
Oh and cross posting is not appreciated on this site even if you do it in another language.
