Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Fading three LEDs consecutively over three days.  (Read 1324 times)
Offline Offline
Newbie
View Profile
WWW
Adjusted the fadeStepInterval to 338824 which should step through 255 levels of brightness over roughly 24 hours. But it seems that LED1 waits the duration of 338824 milliseconds and then just starts to fade quickly to off, followed by LED2 and LED3, all taking roughly 30 seconds each to fade out completely.
Also - now the RFID reader refuses to scan until the last LED is midway through dimming??? Strange behavior!  smiley-cry
Here's the entire code:
Code:
int RFIDResetPin = 13;
void(* resetFunc) (void) = 0; //declare reset function @ address 0
//Register your RFID tags here
char tag1[14] = "046F3AB283603";
int dayOne = 5;  // pin 5
int dayTwo = 6;  // pin 6
int dayThree = 9;   // pin 9
int completed = 0;
unsigned long fadeStepInterval = 338824;
unsigned long prevFadeTime = 0;
int brightnessa = 255;
int brightnessb = 255;
int brightnessc = 255;
void setup(){
  pinMode(RFIDResetPin, OUTPUT);
  digitalWrite(RFIDResetPin, HIGH);
  //ONLY NEEDED IF CONTROLING THESE PINS - EG. LEDs
  pinMode(2, OUTPUT);
  pinMode(dayOne, OUTPUT);
  pinMode(dayTwo, OUTPUT);
  pinMode(dayThree, OUTPUT);
void loop(){
  char tagString[13];
  int index = 0;
  boolean reading = false;
  while(Serial.available()){
    int readByte = Serial.read(); //read next available byte
    if(readByte == 2) reading = true; //begining of tag
    if(readByte == 3) reading = false; //end of tag
    if(reading && readByte != 2 && readByte != 10 && readByte != 13){
      //store the tag
      tagString[index] = readByte;
      index ++;
  checkTag(tagString); //Check if it is a match
  clearTag(tagString); //Clear the char of all value
  resetReader(); //eset the RFID reader
  unsigned long currTime = millis();
if (brightnessa != 0)
   if(currTime - prevFadeTime >= fadeStepInterval)
     brightnessa--;
if (brightnessa == 0 && brightnessb != 0)
     brightnessb--;
if (brightnessb == 0 && brightnessc != 0)
     brightnessc--;
analogWrite(dayOne, brightnessa);
analogWrite(dayTwo, brightnessb);
analogWrite(dayThree, brightnessc);
void checkTag(char tag[]){
//Check the read tag against known tags
  if(strlen(tag) == 0) return; //empty, no need to contunue
  if(compareTag(tag, tag1)){ // if matched tag1, do this
    lightLED(2);
       delay(100);
    resetFunc();
void lightLED(int pin){
//Turn on LED on pin "pin" for 250ms
  Serial.println(pin);
  digitalWrite(pin, HIGH);
  delay(250);
  digitalWrite(pin, LOW);
void resetReader(){
//Reset the RFID reader to read again.
  digitalWrite(RFIDResetPin, LOW);
  delay(150);
void clearTag(char one[]){
//clear the char array by filling with null - ASCII 0
//Will think same tag has been read otherwise
  for(int i = 0; i < strlen(one); i++){
    one[i] = 0;
boolean compareTag(char one[], char two[]){
//compare two value to see if same,
//strcmp not working 100% so we do this
  if(strlen(one) == 0) return false; //empty
  for(int i = 0; i < 12; i++){
    if(one[i] != two[i]) return false;
  return true; //no mismatches
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Put each { on a new line. Then, use Tools + Auto Format.
Then, tell me why you call checkTag(), clearTag(), and resetReader() on every pass through loop.
This:
Code:
     brightnessa--;
     brightnessb--;
     brightnessc--;
is unnecessarily complicated.
This:
Code:
      brightnessa--;
    else if (brightnessb != 0)
      brightnessb--;
    else if (brightnessc != 0)
      brightnessc--;
is a lot simpler.
Logged
Offline Offline
Newbie
View Profile
WWW
Okay, I did the auto-format. Not positive what that does, but I did it  smiley-razz
Also, replaced the unnecessarily complicated code with the simpler code you showed me. Lights still fade as expected, but I've yet to test the three day timing.
The reason I assume I call checkTag(), clearTag(), and resetReader() through every loop is because that's how it scans the RFID hardware for potential tag swipes. That chunk of code came from a RFID sequencing project, seen here: http://bildr.org/2011/02/rfid-arduino/
Still - the RFID refuses to read any swipes until it gets to the last LED, which is odd.
Here is the revised code:
Code:
int completed = 0;
unsigned long fadeStepInterval = 50;
int brightnessa = 100;
int brightnessb = 100;
int brightnessc = 100;
  pinMode(2, OUTPUT);
  char tagString[13];
  int index = 0;
      //store the tag
      index ++;
      brightnessa--;
      brightnessb--;
      brightnessc--;
    lightLED(2);
    delay(100);
    resetFunc();
  delay(250);
void resetReader()
  delay(150);
    one[i] = 0;
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
You missed a part...
Code:
So, you know a tag was swiped, because there is data.
Code:
You know that you have found the end of the tag's data. Would this be a good time to call checkTag(), clearTag(), and resetReader()?
Code:
      index ++;
If you null terminated the array, you could use strcmp() below, instead of comparing one character at a time.
Code:
Your stored tag has 13 characters. You are only comparing the first 12. Why?
Code:
Wouldn't matching names, like day3 and brightness3 make more sense?
Quote
I'm not understanding this. On each pass through loop, you are checking for serial data from the RFID reader, possibly adjusting one or more brightnessX values, and writing three values to three pins. Of course you can't read again until the value has been written to the last pin, but that should happen in a few hundred nanoseconds.
Logged
New Jersey
Offline Offline
Edison Member
View Profile
Code:
      brightnessa--;
      brightnessb--;
      brightnessc--;
Shouldn't there be a prevFadeTime = currTime ; somewhere between those braces?
Logged
Albenga (SV) / Torino, Italy
Offline Offline
Newbie
View Profile
Hi, maybe it's all wrong, but it's simple and should work (compiled, but not tested)
Code:
// Led to pin 9 10 and 11
#include <avr/sleep.h>
int i=0;
int led=9;
void setup(){
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  digitalWrite(9, HIGH);
  digitalWrite(10, HIGH);
  digitalWrite(11, HIGH);
  for (i=255; i>=0; i--)
    analogWrite(led, i);
    delay(338824);
  led++;
  if (led==12)
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    sleep_enable();
    sleep_mode();
Plug a button or what you want to the reset pin and I think it's done... or it's all a big fail, i don't know
« Last Edit: February 14, 2012, 06:04:21 am by Albee » Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Good idea. It was missing from the code I simplified, so I overlooked the need.
Logged
Offline Offline
Newbie
View Profile
WWW
I've narrowed down the issue to my three analogWrite() instructions.
This is my code, and even with the instructions for altering brightness1, 2 and 3, the RFID instruction works flawlessly:
Code:
int completed = 0;
unsigned long fadeStepInterval = 864000;
int brightness1 = 100;
int brightness2 = 100;
int brightness3 = 100;
void setup(){
  pinMode(2, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(9, OUTPUT);
void loop(){
  char tagString[14];
  int index = 0;
      //store the tag
      index ++;
  resetReader(); //reset the RFID reader
    if (brightness1 != 0)
      brightness1--;
    else if (brightness2 != 0)
      brightness2--;
    else if (brightness3 != 0)
      brightness3--;
    prevFadeTime = currTime;
    lightLED(2);
    delay(250);
    resetFunc();
  //Turn on LED on pin "pin" for 100ms
  analogWrite(pin, 255);
  delay(100);
  analogWrite(pin, 0);
void resetReader(){
  delay(150);
    one[i] = 0;
If I add the following to my loop:
Code:
 analogWrite(dayOne, brightness1);
  analogWrite(dayTwo, brightness2);
  analogWrite(dayThree, brightness3);
...Then the leds light up and fade as instructed, which is great, but the RFID fails to read data. Is this a conflict? Can I not do analogWrites and digitalWrites simultaneously? I even changed the lightLED function on pin 2 to an analogWrite to see if that might help, but to no avail.
« Last Edit: February 16, 2012, 09:29:28 am by kkachurak » Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
  // Read the data and note the presence of start and end markers
Then:
Code:
I can't understand why you won't put this code in the "yes, there is serial data" block, so that you don't do this unless you just read a tag.
Logged
Offline Offline
Newbie
View Profile
WWW
Turns out, this was a hardware issue. I connected the proper resistors prior to the LEDs within my circuit and things seem to be working swimmingly so far.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
