Topic: Need help to modify clock code (Read 913 times) previous topic - next topic
joe73
I had build clock from plans I found online and want to add 12/24 hour time and alarm to it.I am new to arduino and programming in general.Can someone modify code for me.For $$ or exchange for clock.
Here is link to clock build plans  http://www.vonnieda.org/tc18
Thanks
PaulS
If you want to make the clock display the hour in the range 1 to 12, instead of 1 to 24, the fix is simple. Change:
Code: [Select]
  byte h = Wire.receive();
to
Code: [Select]
  if(h > 12)
    h -= 12;
"Adding an alarm" is not as trivial. The Arduino that is powering the clock certainly knows the time, and could sound an alarm at a specific time. But, setting that time requires user input, as would enabling, disabling, and silencing the alarm. Not to mention the need to add a noise maker. How will that user input be supplied?
Jack Christensen
If you want to make the clock display the hour in the range 1 to 12, instead of 1 to 24 ...
Ummm, how about 0 to 23?
joe73
I'm adding piezo to PB1 and PB2 thats pin 13 and 14 on atmega and want to set everything with rotary decoder.
PaulS
Quote
Sure, that would work.
