Topic: Interrupts from IR Receiver? (Read 1 time) previous topic - next topic
Demonic69
Hi All
I was wondering if anyone's managed to get interrupts working properly with an IR receiver? I'm still fairly new to the arduino and haven't implemented any interrupts yet.
What I'm hoping to do is loop through a function until an IR code is received, increment a variable by 1, then run the corresponding function until a new code is received.
I've got some IR code that works, switching pins from low to high as needed, from another project.
I'm still working on the functions (animations on 2 TLC5904s) so am really fishing to see if my idea would work and hoping someone has a successful implementation I could have a nosey at :D
Thanks
DuaneB
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
Grumpy_Mike
Quote
something like this ?
http://www.ladyada.net/learn/sensors/ir.html
Is that link down?
I haven't been able to access it for a couple of weeks. But you can still get it cached in Google.
DuaneB
   I am able to access it directly, however it may be cached on my machine. I don't want to clear the cache to find out so lets see if the OP can have a look for us.
Duane B.
Read this
then watch this
dxw00d
I got straight through to the link. I know I don't have it cached.
Demonic69
The link is up for me.
That might do what I need, or at least give me some ideas thanks.
I've been using the IR library by Ken Shirrif, that works really well too but I can't get my head around getting it to interrupt and increment when I receive a signal.
Cheers for the help.
PaulS
Quote
Get what to interrupt?
To interrupt what?
To increment what?
When you receive a signal from what?
I presume that the answer to the last one is "from the IR transmitter", but other ones do not seem to have answers.
Demonic69
Hi Paul
Sorry, I lost my code moving from machines.
I've copied it below, though I'm still writing the functions.
I'm - obviously - not the best at coding but I can usually get my head around code once I figure out what it does.
This code is really basic but it makes sense to me :D I just loops to variable anim based on the code from the remote, then runs the corresponding function.
Currently it would have to wait for the function to finish before starting the loop again, probably missing the read, I was hoping I could interrupt the current function, read the code from the remote, increment or decrement anim and then run the corresponding function.
Code: [Select]
[code]#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
int anim = 1;
unsigned long last = millis();
  if (irrecv.decode(&results)) {
    // If it's been at least 1/4 second since the last
    // IR received, toggle the relay
    if (millis() - last > 250) {
      if (results.value == 0x4cb92) { // Sony DVD play
        anim + 1;
      else if (results.value == 0x1cb92) { // Sony DVD stop
        anim  - 1;
    last = millis();
    irrecv.resume(); // Receive the next value
  if (anim = 0) { // looping anim if it goes below 1
    anim = 4;
  else if (anim = 5) { // looping anim if it goes above 4
    anim = 1;
  else if (anim = 1) {
    // run function 1
  else if (anim = 2) {
    // run function 2
  else if (anim = 3) {
    // run function 3
  else if (anim = 4) {
    // run function 4
[/code]
PaulS
Code: [Select]
    anim = 4;
    anim = 1;
    // run function 1
    // run function 2
    // run function 3
    // run function 4
I think that you are missing a few ====================. Luckily, I have some to spare. Copy and paste these into your code, as required.
An interrupt, if you create one, will not stop the long functions from running. You need to re-think how you code them, to not be blocking functions. At the very least, they need to check, periodically, to see if there has been IR input, and end if there is.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
