Hello, i have a 2 digit 7 segment display which is common anode. I am using the code and circuit diagram from here
http://www.sweeting.org/mark/blog/2011/11/27/arduino-74hc595-shift-register-and-a-7-segment-led-display. However i have modified the code slightly as follows :
const int latchPin = 5; // Pin connected to Pin 12 of 74HC595 (Latch)
const int dataPin = 6; // Pin connected to Pin 14 of 74HC595 (Data)
const int clockPin = 7; // Pin connected to Pin 11 of 74HC595 (Clock)
unsigned long t1;
unsigned long t2;
int i = 0;
int swch = 0;
// Describe each digit in terms of display segments
// 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, A, B, C, D, E, F
const byte numbers[10] = {
0b11111100,
0b01100000,
0b11011010,
0b11110010,
0b01100110,
0b10110110,
0b10111110,
0b11100000,
0b11111110,
0b11100110
// initialisation time
t1 = millis();
//set pins to output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(2, OUTPUT); //Connects to right character common anode
pinMode(3, OUTPUT); //Connects to left character common anode
if(swch==0)
digitalWrite(3, LOW);
digitalWrite(2, HIGH);
show(numbers[1]);
swch=1;
swch=0;
digitalWrite(3, HIGH);
digitalWrite(2, LOW);
show(numbers[2]);
void show( byte number)
// Use a loop and a bitwise AND to move over each bit that makes up
// the seven segment display (from left to right, A => G), and check
// to see if it should be on or not
for(int j = 0; j <= 7; j++)
delay(1);
byte toWrite = number & (0b10000000 >> j);
// If all bits are 0 then no point writing it to the shift register,
// so break out and move on to next segment.
if(!toWrite) {
continue;
// Otherwise shift it into the register
shiftIt(toWrite);
void shiftIt (byte data)
// Set latchPin LOW while clocking these 8 bits in to the register
digitalWrite(latchPin, LOW);
for (int k=0; k <= 7; k++)
// clockPin LOW prior to sending a bit
digitalWrite(clockPin, LOW);
// Note that in our case, we need to set pinState to 0 (LOW) for
// “On” as the 74HC595 is sinking current when using a common
// anode display. If you want to use a common cathode display then
// switch this around.
if ( data & (1 << k) )
digitalWrite(dataPin, LOW); // turn “On”
digitalWrite(dataPin, HIGH); // turn “Off”
// and clock the bit in
digitalWrite(clockPin, HIGH);
//stop shifting out data
//set latchPin to high to lock and send data
digitalWrite(latchPin, HIGH);
// put delay here if you want to see the multiplexing in action!
//delay(1000);
The problem is that when displaying a one the numbers blur together so if trying to display 21 it looks like this (appologies for the terrible art)
Upon slowing it down what happens is that when it switches from lighting the one to lighting the two one of the LEDS briefly flashes on in this case the bottom right LED. Does anyone know how i can fix this or is what i am doing a bad way of doing things?
Thanks for your help.
