Loading...
Pages: 1 2 [3] 4 5   Go Down
Author Topic: Arduino as a Pic Programmer!  (Read 31875 times)
0 Members and 2 Guests are viewing this topic.
ਪੰਜਾਬ
Offline Offline
Edison Member
WANTED! A Girl with LOVE for me and Arduino!
View Profile
WWW
Ok that is fine.
Logged
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
France
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Updated C# code and arduino code, should work with many pics (doesn't support config word yet...).
Don't forget to reset PIC before reading/writing. If the prog says "access to COMX denied", just close and re-open the prog.
« Last Edit: March 03, 2012, 12:54:03 pm by Soranne » Logged
ਪੰਜਾਬ
Offline Offline
Edison Member
View Profile
WWW
Thanks! i will get back to you with the results.
Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
France
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Ok! smiley
I'm not sure about writing, but reading should work fine smiley-wink
Logged
ਪੰਜਾਬ
Offline Offline
Edison Member
View Profile
WWW
How can the Read software be saved?
Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
France
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Not implemented yet but you can still copy/paste the text from the output window...
Does reading work for you?
Logged
Offline Offline
Newbie
View Profile
Hey, just wanted to give you two thumbs up for this project!
I've spent some time looking for a way to program pic through arduino and only found some (pretty arrogant) guys saying that it's not possible.. I wanted to make a PicKit2 clone, but needed something to burn hex to 16f2550, and it seems that your solution is exactly what I was looking for. It's unfortunate that I won't have time to try it soon, but keep up the good work!
Logged
Offline Offline
Newbie
View Profile
Hey Sorraine,
This is a nice project. Does this work for PIC24 (PIC24FJ256GA110) ?
Logged
Caen, France
Offline Offline
Newbie
View Profile
WWW
Hi, Soranne !
As I said on the french topic of your project - http://arduino.cc/forum/index.php/topic,93067.0.html - I'm trying to reproduce the same kind of project with a PIC18F2550.
When i'll finish it, i'll share it on this topic, attached with a report. I expect that will help everybody else to adapt this project to their favorite microcontroller.
Cordially,
Watchi~
Logged
Parma
Offline Offline
Edison Member
View Profile
Very interesting project!
Logged
Dublin, Ireland
Offline Offline
Newbie
View Profile
WWW
Ditto... must keep an eye on this as my Pic programmer uses serial and my new PC doesn't... smiley-wink
Keep it up Soranne, nice project...
Mike
Logged
Netherlands
Offline Offline
Newbie
View Profile
Hi, watchinofoye
I was also trying to build an Arduino PIC programmer for the PIC18F2550. So far without much success.
Here is my code:
Code:
 * Trying to build an arduino pic programmer for the PIC18F2550
 * Programming specifications: http://ww1.microchip.com/downloads/en/DeviceDoc/39622L.pdf
 * Author: Ingmar Jager
//Pin layout
int pgc = 9;  // program clock
int pgd = 8;  // program data
int pgm = 10;  // program mode
int MCLR = 11; //Master Clear Reset / Vpp
  pinMode(pgc, OUTPUT);
  pinMode(pgd, OUTPUT);
  pinMode(pgm, OUTPUT);
  pinMode(MCLR, OUTPUT);
  enterProgramming();
  tableRead(0x3F, 0xFF, 0xFF);
  exitingProgramming();
 * @param: three bytes which form the tablepointer address
void setTablePTR(int addr_upper_byte,int addr_half_byte,int addr_lower_byte)
 Serial.print("Set TablePTR to: 0x");
 Serial.print(addr_upper_byte, HEX);
 Serial.print(addr_half_byte, HEX);
 Serial.println(addr_lower_byte, HEX);
 writeBits(4, 0x0); // 4 bit command
 writeBits(16, 0x0E00 + addr_upper_byte); // 16 bit data payload: load address
 writeBits(4, 0x0);
 writeBits(16, 0x6EF8);  // set TBLPTR_U to addr_upper_byte
 writeBits(4, 0x0);
 writeBits(16, 0x0E00 + addr_half_byte);
 writeBits(4, 0x0);
 writeBits(16, 0x6EF7); //TBLPTR_H
 writeBits(4, 0x0);
 writeBits(16, 0x0E00 + addr_lower_byte);
 writeBits(4, 0x0);
 writeBits(16, 0x6EF6); //TBLPTR_L
 * Read byte from the given address
void tableRead(int high_byte, int mid_byte, int low_byte)
  setTablePTR(high_byte,mid_byte,low_byte);
  writeBits(4, 0x8); //1000 = Read and no increment
  writeBits(8, 0x00);
  pinMode(pgd, INPUT);
  delayMicroseconds(5); //P6
  byte data = 0;
  //actual read
  Serial.print("Read bits from LSB to MSB: ");
  for (int i = 0; i < 8; i++)
    digitalWrite(pgc, HIGH);
    delayMicroseconds(3); //P14
    if (digitalRead(pgd)==HIGH)
      Serial.print("1");
      data += (1 << i);
      Serial.print("0");
    digitalWrite(pgc, LOW);
  delayMicroseconds(5); //P5A
  Serial.print("Reading result: ");
  Serial.println(data);
/* Write LSB to MSB
 * @param n = number of bits to write
 * @param value = value to write in n bits
void writeBits(int n, int value)
  for (int i = 0; i < n; i++) {
     if( (boolean) ((value >> i) & 1))
        digitalWrite(pgd,HIGH);
  digitalWrite(pgd,LOW);
 * Entering low voltage programming signals
void enterProgramming()
   digitalWrite(pgd, LOW);
   digitalWrite(pgm, LOW);
   digitalWrite(MCLR, LOW);
   delayMicroseconds(20);
   digitalWrite(pgm, HIGH);
   delayMicroseconds(3);//P15
   digitalWrite(MCLR, HIGH);
   delayMicroseconds(3);//P12
   Serial.println("Entered Low Voltage Programming");
 * Exiting low voltage programming signals
void exitingProgramming()
   delayMicroseconds(1); //P16
   delayMicroseconds(1); //P18
   Serial.println("Exiting Low Voltage Programming");
I'm trying to read the deviceID on address 0x3FFFFF. According to the programming specifications the DEVID1 = 010x xxxx and DEVID2 = 0x12.
When I run my program, this is the output:
Code:
Set TablePTR to: 0x3FFFFF
Read bits from LSB to MSB: 00000000
Reading result: 0
Read bits from LSB to MSB: 00011111
Reading result: 248
So the first time I try to read the ID register it returns 0. However the second time the result is 00011111 (248). If I read it a third time it is 0 again. So I'm not quite sure what is happening here.
Have you got some better results?
« Last Edit: April 30, 2012, 04:59:16 am by ijager » Logged
Offline Offline
Newbie
View Profile
I have been having issues with the GUI version.
When I Burn a hex to the pic, it seems to work (tx light on usb adapter flashes, etc) and the program says "Finished!" after a short time.
However, when I hit "Read from PIC" all lines (0-49) say 00000000000000
I'm using a PIC16F628A
Logged
Offline Offline
Sr. Member
View Profile
ive been looking for something like this for a long time; great work!
Logged
http://dduino.blogspot.com all my Arduino/electronic projects!!!
{NEW} Getting Started, Learning, Reference + FAQ PDF!!:
http://arduino.cc/forum/index.php/topic,79026
Offline Offline
Newbie
View Profile
I wrote a similar sketch for the PIC18F2550 ( a slight modification can adopt it to almost all pic18F2/4 family). the sketch and the instruction can be found over here:
https://sites.google.com/site/thehighspark/arduino-pic18f
Logged
Pages: 1 2 [3] 4 5   Go Up
Print
Jump to:
