Topic: Arduino as a Pic Programmer! (Read 210374 times) previous topic - next topic
aepiscis
Hi soranne,
sorry, I donĀ“t speak english very good
I know how to get 12V from USB port, There are two ways:
1.-With a coil and a zenner
2.- With capacitors, Diodes and a zenner
the first option are more easy but it is more difficult to get the coil.
I will post here how to make
reggards.
watchinofoye
Quote
I wrote a similar sketch for the PIC18F2550 ( a slight modification can adopt it to almost all pic18F2/4 family). the sketch and the instruction can be found over here:
https://sites.google.com/site/thehighspark/arduino-pic18f
Damn ! Project already done !
Well, I'll still try to do it, at least to understand the ICSP method and achieve implementation by myself.
But, even so I am disgusted ! >.< I was caught up again ! Just my luck !
Soranne
Hey all! sorry for answering so late but I have been busy with a lot of homework :s
I have to say I am not sure I will be able to work again on this project because it involves a lot of time (coding a programming method for nearly every pic!).
What Is suggest is that someone who is really motivated gathers all the programming methods for each pic to make one nice prog.
Hope I can help again!
mahk
hi soranne where i can find your program c# to load pic?
also what is latest state your project?
mahk
and soranne your project page (https://sites.google.com/site/thehighspark/arduino-pic18f )  is broken
is there any alternatif link??
Soranne
Dear mahk,
I am sorry this page is not my project.
mahk
hey soranne can you give me  alink for this project(circuit,program)
i need this project for my thesis in school
Soranne
All the infromation I have is on the first page
tekaikko
Hi!
A good project!
In case interested, I've created an Arduino programmer for PIC32 series. The details are found at http://code.google.com/p/ardupic32/.
Cheers!
diogo0880
Hi Soranne!
I think you save me! Please tell me that I can program a PIC18F452 or a PIC16F88 (with I prefer) using your project.
Soranne
Hi Soranne!
Hey!
Of course you can! But depending on the protocol they use you may need to adapt a bit the code.
Soranne
But personnaly I would prefer the beaglebone to the raspberry pi ;)
The beaglebone looks more like an arduino (you can easily access the inputs/outputs and and shields)  and is more powerful than a raspberry pi, even if it's a bit more expensive.
itchan
#57
May 24, 2012, 09:03 am Last Edit: May 24, 2012, 09:25 am by itchan Reason: 1
How do i connect the pic16f684? I checked the datasheet and it doesnt have pins labeled as RB4 RB6 AND RB7? :(
spunky
Hi all,
Mine is PIC16F887
Im trying to program it using your programmer (the .exe application) and have few question.
How to send the command "s" ? i want to program using low voltage.
and how to wire it? here's what I got from my PIC datasheet.(attached)
hoping someone can give me circuit suggesstion. thanks  :)
BlueGuzz
Hint: If you look at post #2 and there is no link to the *.exe file, you have to create a forum account and log in. An advise in post #2 would be nice.
