Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Arduino as a Pic Programmer!  (Read 34473 times)
ਪੰਜਾਬ
WANTED! A Girl with LOVE for me and Arduino!
Ok that is fine.
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
France
Updated C# code and arduino code, should work with many pics (doesn't support config word yet...).
Don't forget to reset PIC before reading/writing. If the prog says "access to COMX denied", just close and re-open the prog.
« Last Edit: March 03, 2012, 12:54:03 pm by Soranne » Logged
ਪੰਜਾਬ
Thanks! i will get back to you with the results.
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
France
Ok! smiley
I'm not sure about writing, but reading should work fine smiley-wink
ਪੰਜਾਬ
How can the Read software be saved?
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
France
Not implemented yet but you can still copy/paste the text from the output window...
Does reading work for you?
Hey, just wanted to give you two thumbs up for this project!
I've spent some time looking for a way to program pic through arduino and only found some (pretty arrogant) guys saying that it's not possible.. I wanted to make a PicKit2 clone, but needed something to burn hex to 16f2550, and it seems that your solution is exactly what I was looking for. It's unfortunate that I won't have time to try it soon, but keep up the good work!
Hey Sorraine,
This is a nice project. Does this work for PIC24 (PIC24FJ256GA110) ?
Caen, France
Hi, Soranne !
As I said on the french topic of your project - http://arduino.cc/forum/index.php/topic,93067.0.html - I'm trying to reproduce the same kind of project with a PIC18F2550.
When i'll finish it, i'll share it on this topic, attached with a report. I expect that will help everybody else to adapt this project to their favorite microcontroller.
Cordially,
Watchi~
Parma
Very interesting project!
Dublin, Ireland
Ditto... must keep an eye on this as my Pic programmer uses serial and my new PC doesn't... smiley-wink
Keep it up Soranne, nice project...
Mike
Netherlands
Hi, watchinofoye
I was also trying to build an Arduino PIC programmer for the PIC18F2550. So far without much success.
Here is my code:
 * Trying to build an arduino pic programmer for the PIC18F2550
 * Programming specifications: http://ww1.microchip.com/downloads/en/DeviceDoc/39622L.pdf
 * Author: Ingmar Jager
//Pin layout
int pgc = 9;  // program clock
int pgd = 8;  // program data
int pgm = 10;  // program mode
int MCLR = 11; //Master Clear Reset / Vpp
  pinMode(pgc, OUTPUT);
  pinMode(pgd, OUTPUT);
  pinMode(pgm, OUTPUT);
  pinMode(MCLR, OUTPUT);
  enterProgramming();
  tableRead(0x3F, 0xFF, 0xFF);
  exitingProgramming();
 * @param: three bytes which form the tablepointer address
void setTablePTR(int addr_upper_byte,int addr_half_byte,int addr_lower_byte)
 Serial.print("Set TablePTR to: 0x");
 Serial.print(addr_upper_byte, HEX);
 Serial.print(addr_half_byte, HEX);
 Serial.println(addr_lower_byte, HEX);
 writeBits(4, 0x0); // 4 bit command
 writeBits(16, 0x0E00 + addr_upper_byte); // 16 bit data payload: load address
 writeBits(4, 0x0);
 writeBits(16, 0x6EF8);  // set TBLPTR_U to addr_upper_byte
 writeBits(4, 0x0);
 writeBits(16, 0x0E00 + addr_half_byte);
 writeBits(4, 0x0);
 writeBits(16, 0x6EF7); //TBLPTR_H
 writeBits(4, 0x0);
 writeBits(16, 0x0E00 + addr_lower_byte);
 writeBits(4, 0x0);
 writeBits(16, 0x6EF6); //TBLPTR_L
 * Read byte from the given address
void tableRead(int high_byte, int mid_byte, int low_byte)
  setTablePTR(high_byte,mid_byte,low_byte);
  writeBits(4, 0x8); //1000 = Read and no increment
  writeBits(8, 0x00);
  pinMode(pgd, INPUT);
  delayMicroseconds(5); //P6
  byte data = 0;
  //actual read
  Serial.print("Read bits from LSB to MSB: ");
  for (int i = 0; i < 8; i++)
    digitalWrite(pgc, HIGH);
    delayMicroseconds(3); //P14
    if (digitalRead(pgd)==HIGH)
      Serial.print("1");
      data += (1 << i);
      Serial.print("0");
    digitalWrite(pgc, LOW);
  delayMicroseconds(5); //P5A
  Serial.println();
  Serial.print("Reading result: ");
  Serial.println(data);
/* Write LSB to MSB
 * @param n = number of bits to write
 * @param value = value to write in n bits
void writeBits(int n, int value)
  for (int i = 0; i < n; i++) {
     if( (boolean) ((value >> i) & 1))
        digitalWrite(pgd,HIGH);
  digitalWrite(pgd,LOW);
 * Entering low voltage programming signals
void enterProgramming()
   digitalWrite(pgd, LOW);
   digitalWrite(pgm, LOW);
   digitalWrite(MCLR, LOW);
   delayMicroseconds(20);
   digitalWrite(pgm, HIGH);
   delayMicroseconds(3);//P15
   digitalWrite(MCLR, HIGH);
   delayMicroseconds(3);//P12
   Serial.println("Entered Low Voltage Programming");
 * Exiting low voltage programming signals
void exitingProgramming()
   delayMicroseconds(1); //P16
   delayMicroseconds(1); //P18
   Serial.println("Exiting Low Voltage Programming");
I'm trying to read the deviceID on address 0x3FFFFF. According to the programming specifications the DEVID1 = 010x xxxx and DEVID2 = 0x12.
When I run my program, this is the output:
Set TablePTR to: 0x3FFFFF
Read bits from LSB to MSB: 00000000
Reading result: 0
Read bits from LSB to MSB: 00011111
Reading result: 248
So the first time I try to read the ID register it returns 0. However the second time the result is 00011111 (248). If I read it a third time it is 0 again. So I'm not quite sure what is happening here.
Have you got some better results?
« Last Edit: April 30, 2012, 04:59:16 am by ijager » Logged
I have been having issues with the GUI version.
When I Burn a hex to the pic, it seems to work (tx light on usb adapter flashes, etc) and the program says "Finished!" after a short time.
However, when I hit "Read from PIC" all lines (0-49) say 00000000000000
I'm using a PIC16F628A
ive been looking for something like this for a long time; great work!
http://dduino.blogspot.com all my Arduino/electronic projects!!!
{NEW} Getting Started, Learning, Reference + FAQ PDF!!:
http://arduino.cc/forum/index.php/topic,79026
I wrote a similar sketch for the PIC18F2550 ( a slight modification can adopt it to almost all pic18F2/4 family). the sketch and the instruction can be found over here:
https://sites.google.com/site/thehighspark/arduino-pic18f
Pages: 1 2 [3] 4 5 6   Go Up
